@Hi Tinkerer: I enabled the HA logger with no options; that should show everything.
My setup is to have 3 ceiling lights switched on when the front door opens. Normally when dark only, but for now the condition is not used.
It took actually 23 seconds to see action after the trigger. In debug that is at the following times:
- RFXTRX signal is received at 15:58:42
- confirmation form HA is seen at 15:59:05
- Script starts at 15:59:05
What’s your opinion?
Best regards,
OWK
Marmitec DS-90 sensor configured:
- platform: rfxtrx
automatic_add: False
devices:
08200065cbc4040059:
fire_event: True
082000672b24840259:
fire_event: True
Automation used:
- alias: 'Hallway spots on when dark and frontdoor opens'
initial_state: 'on'
hide_entity: false
- platform: state
entity_id: sensor.voordeur_sensor_status
to: 'Alarm'
# condition:
# - condition: state
# entity_id: sun.sun
# state: 'below_horizon'
- service: light.turn_on
entity_id:
- light.gang_plafond_1
- light.gang_plafond_2
- light.gang_plafond_6
brightness: 25
- service: notify.pushover_owk6s
data_template:
message: "Voordeur open"
title: "Home-assistant VS21"
- delay: '00:02:00'
- service: light.turn_off
entity_id:
Debug result for opening the front door:
15:58:42 DEBUG (Thread-2) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: cbc40432 Class: RFXtrxDevice Sub: 0, Pkt_id: 08200005cbc4040259)
15:58:42 INFO (MainThread) [homeassistant.core] Bus:Handling <Event signal_received[L]: entity_id=sensor.voordeur_sensor_status>
15:59:05 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.voordeur_sensor_status, old_state=<state sensor.voordeur_sensor_status=unknown; unit_of_measurement=, friendly_name=Voordeur Sensor Status @ 2017-09-30T15:56:29.985920+02:00>, new_state=<state sensor.voordeur_sensor_status=Alarm; Sensor Status=Alarm, Battery numeric=9, Rssi numeric=5, unit_of_measurement=, friendly_name=Voordeur Sensor Status @ 2017-09-30T15:59:05.608981+02:00>>
15:59:05 INFO (MainThread) [homeassistant.components.automation] Executing Hallway spots on when dark and frontdoor opens
15:59:05 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: name=Hallway spots on when dark and frontdoor opens, message=has been triggered, domain=automation, entity_id=automation.hallway_spots_on_when_dark_and_frontdoor_opens>
15:59:05 INFO (MainThread) [homeassistant.helpers.script] Script Hallway spots on when dark and frontdoor opens: Running script
15:59:05 INFO (MainThread) [homeassistant.helpers.script] Script Hallway spots on when dark and frontdoor opens: Executing step call service
15:59:05 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=light, service=turn_on, service_data=brightness=25, entity_id=[‘light.gang_plafond_1’, ‘light.gang_plafond_2’, ‘light.gang_plafond_6’], service_call_id=3040848880-6>
15:59:05 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2926113552: Sending {‘id’: 2, ‘type’: ‘event’, ‘event’: {‘event_type’: ‘state_changed’, ‘data’: {‘entity_id’: ‘sensor.voordeur_sensor_status’, ‘old_state’: <state sensor.voordeur_sensor_status=unknown; unit_of_measurement=, friendly_name=Voordeur Sensor Status @ 2017-09-30T15:56:29.985920+02:00>, ‘new_state’: <state sensor.voordeur_sensor_status=Alarm; Sensor Status=Alarm, Battery numeric=9, Rssi numeric=5, unit_of_measurement=, friendly_name=Voordeur Sensor Status @ 2017-09-30T15:59:05.608981+02:00>}, ‘origin’: ‘LOCAL’, ‘time_fired’: datetime.datetime(2017, 9, 30, 13, 59, 5, 609171, tzinfo=)}}
15:59:05 DEBUG (SyncWorker_9) [phue] {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_9) [phue] PUT /api/HueAPIKey/lights/10/state {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_9) [phue] [[{‘success’: {’/lights/10/state/on’: True}}, {‘success’: {’/lights/10/state/bri’: 25}}, {‘success’: {’/lights/10/state/alert’: ‘none’}}]]
15:59:06 DEBUG (SyncWorker_6) [phue] {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_6) [phue] PUT /api/HueAPIKey/lights/12/state {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_6) [phue] [[{‘success’: {’/lights/12/state/on’: True}}, {‘success’: {’/lights/12/state/bri’: 25}}, {‘success’: {’/lights/12/state/alert’: ‘none’}}]]
15:59:06 DEBUG (SyncWorker_2) [phue] {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_2) [phue] PUT /api/HueAPIKey/lights/16/state {‘on’: True, ‘bri’: 25, ‘alert’: ‘none’}
15:59:06 DEBUG (SyncWorker_2) [phue] [[{‘success’: {’/lights/16/state/on’: True}}, {‘success’: {’/lights/16/state/bri’: 25}}, {‘success’: {’/lights/16/state/alert’: ‘none’}}]]
15:59:06 DEBUG (SyncWorker_8) [phue] GET /api/HueAPIKey None
15:59:06 DEBUG (SyncWorker_8) [homeassistant.components.light.hue] Getting group 0 from bridge
15:59:06 DEBUG (SyncWorker_8) [phue] GET /api/HueAPIKey/groups/0 None
15:59:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.gang_plafond_1, old_state=<state light.gang_plafond_1=off; friendly_name=Gang plafond 1, supported_features=41 @ 2017-09-30T15:56:36.096144+02:00>, new_state=<state light.gang_plafond_1=on; brightness=25, min_mireds=154, max_mireds=500, effect_list=[‘colorloop’, ‘random’], friendly_name=Gang plafond 1, supported_features=41 @ 2017-09-30T15:59:06.447149+02:00>>
15:59:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.gang_plafond_2, old_state=<state light.gang_plafond_2=off; friendly_name=Gang plafond 2, supported_features=41 @ 2017-09-30T15:56:36.045163+02:00>, new_state=<state light.gang_plafond_2=on; brightness=25, min_mireds=154, max_mireds=500, effect_list=[‘colorloop’, ‘random’], friendly_name=Gang plafond 2, supported_features=41 @ 2017-09-30T15:59:06.509860+02:00>>
15:59:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.gang_plafond_6, old_state=<state light.gang_plafond_6=off; friendly_name=Gang plafond 6, supported_features=41 @ 2017-09-30T15:56:35.867249+02:00>, new_state=<state light.gang_plafond_6=on; brightness=25, min_mireds=154, max_mireds=500, effect_list=[‘colorloop’, ‘random’], friendly_name=Gang plafond 6, supported_features=41 @ 2017-09-30T15:59:06.574477+02:00>>
