I bought mine from Mediamarkt (99:- a piece). Kinda expect it’s the same hardware revision though. Bought a P02 a few weeks back from Styrahem, only to realize they switched to a Realtek SOC instead of ESP. I started to suspect they switched to Realtek in these as well, but I just looked up the vendor from it’s MAC address and it was Espressif, so it should be ok.
So far I have only opened and tried one. At some point I figured that I try one just to see and perhaps return the other ones if I had no luck. I did activate this one and added it to the DELTACO app, so I’m gonna try flashing it again.
Got a 3pk SH-P01-3P but also no go with tuya convert.
new client on port 443 from 10.42.42.15:19033
ID: 0242416f68626d64366147393149465231a29185a61862a0e3a08b63639651d30cb778467fb5138551f3a9693fce36a9c0
PSK: a2348bad936e6bfe01e64f3893920f43e2b7883a5565dc98bdb7b857b89e94fa
could not establish sslpsk socket: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:1056)
Is there a breaking and entering guide to these? at a glance there are just two pieces to the shell and no accessible screws under non-existing stickers etc.
Edit:
Damn, its glued or welded pretty much 360° around and after getting through that the prongs are soldered to the board with only a cutout to unscrew one of the two prongs. I.e. you have to de-solder the other prong to extract the board. At a glance I couldn’t see any test pads for programming without pulling the board out.
Edit2: adding pictures as this seems different to SH-P01
How did you manage to open the sh-p01e? The blog post doesn’t exist anymore. Looking to flash two of these via serial since tuya-convert doesn’t work anymore.
Not sure if this helps any of you, but I have a bunch of Deltaco smart plugs that I wanted to get into Home Assistant. I got a tip to try to add them to Tuya directly in the phone app without doing anything – and it worked.
Deltaco SH-P01E Teardown:
There is a “plug” that can be removed (pried off) to reveal screws.
then simply unscrew, and pull the top, off of the bottom.
This one uses a TYWE2S packge, it contains an ESP8285 according to some documentation i found.
Thanks, sorry for not updating, I just tried a few times more the day after and it worked.
Don’t think there is any need to flash the Deltaco plugs to get them into HA, I’ve at least been able to just add them to Tuya and through that integration to HA.
But that of course includes creating an account etc that some don’t, but I don’t care that mcuh about that.
If you have the round one linke i posted here https://community.home-assistant.io/t/deltaco-smarthome/146101/51 then you quite possible can’t open it non-destructively. I just revisited this to extract the TYWES2 module to use in another Nedis plug from Kjell&Co that had an incompatible module, at least i can salvage something as the shell was destroyed from opening.
If you have the square one others have shown then looks ike just the two screws under the cover.
I’m curious when was the ones that worked with tuya convert purchased; everything I’ve got the last year or so have either been patched or downright incompatible.
I also got a power strip, with this SWB2-1 (LM1) chip inside. For pinout, see this. Flashing went easily, but it behaves very strange, it can be flashed after every power-cycle, regardless of the GPIO0 state. Basically every code works on it until a restart.
how do I load new firmware into this module SWB2-1? do you have any instructions?
Help FTL232RL and windows esphome flasher
My log lists:
Using 'COM5' as serial port.
Connecting........_____....._____....._____....._____....._____....._____....._____
Unexpected error: ESP Chip Auto-Detection failed: Failed to connect to Espressif device: Timed out waiting for packet header
