I´m using the “call service” node in many flows. I don´t know exactly since when, but right now I get an API-Warning and an Error when using these nodes. Must have been one of the last updates. For example an easy test:
Setting a input number with service “set value” and the data “{“value”: 100}”.
This results in:
“Deprecated API warning: Calls to RED.util.evaluateJSONataExpression must include a callback. This will not be optional in Node-RED 4.0. Please identify the node from the following stack and check for an update on npm. If none is available, please notify the node author.”
and
"Error: ↵ at Object.evaluateJSONataExpression (/opt/node_modules/@node-red/util/lib/util.js:775:18)↵ at CallService.evaluateJSONata (/config/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:266:30)↵ at CallService.onInput (/config/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/call-service/controller.js:63:50)↵ at CallService.preOnInput (/config/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:411:18)↵ at /opt/node_modules/@node-red/runtime/lib/nodes/Node.js:210:26↵ at Object.trigger (/opt/node_modules/@node-red/util/lib/hooks.js:166:13)↵ at callServiceNode.Node._emitInput (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:202:11)↵ at callServiceNode.Node.emit (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:186:25)↵ at callServiceNode.Node.receive (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:494:10)↵ at deliverMessageToDestination (/opt/node_modules/@node-red/r..."
There have been a number of changes recently, so updates to Home Assistant and Node-RED should be followed with corresponding (and matching) updates to the HA websocket nodes, and to the NR Companion integration.
This seems to be a problem.
I have NR 16.02 (latest) in HA → NR 3.0
This should already include Websocket 0.58.02 (since NR 15.1.1). When I look in NR under Palette, there´s Websocket 0.61 updateable but it needs NR 3.1.1. So I can´t update.
For my understanding the error shouldnt appear, becaus eit´s already fixed in WS 0.58.
I have the standard current issue NR addon, which is 16.0.2
My NR pallet shows my HA Websocket nodes currently at 0.57.4. These are indeed manually updateable to 0.61.0, but yes I am not updating just yet since this might break something.
My NR Companion is currently 3.0.1 (again I’m leaving it at that).
Updating the Websocket to 0.61.0 definitely breaks a lot. I tested it in a test environment…
Because the NR Version in NR addon 16.0.2 is 3.0.
So Websocket won´t start and all HA Nodes are beeing removed during startup.
The conundrum is that we have to keep on updating otherwise things stop working, but when we do, things stop working, and if we only update one thing in a group of interconnected things, something else stops working.
