Description of automation in the 'more info' section
For an automation you can add a description. I have some switches on the dashboard to enable/disable automations. When you tap just the name instead of the switch, you get the more information page with history etc. It would be nice if you could see the description of the automation in this section.
Just a heads up that you forgot to vote for your own feature request.
I’ve upvoted this request and found many similar requests:
WTH - Automation dashboard needs description column - Month of “What the heck?!” - Home Assistant Community (home-assistant.io)
WTH are automation descriptions not displayed in the automations list? - Month of “What the heck?!” - Home Assistant Community (home-assistant.io)
Automations - add description text - Feature Requests - Home Assistant Community (home-assistant.io)
Description of automation in the ‘more info’ section - Feature Requests - Home Assistant Community (home-assistant.io)
Description in the automations overview - Feature Requests - Home Assistant Community (home-assistant.io)
Automation list - Add “description” and “open in new tab” - Feature Requests - Home Assistant Community (home-assistant.io)
