Hi, I’ve just flashed an Avatto 1 Gang light switch using the GUIFlashTool and everything was clean, I’ve configured the device to be discovered by home assistant and it was recognized right. My question is, Is there any way you could configure an admin password for the config webpage like you do for tasmota? I just want to secure the devices so nobody in the LAN can get into those config pages and mess around with the configuration.
I have created new uf2 files for the 3 possible options for that chip with Esphome 23.9.0b1a and get the same error with all of them. I’m pretty sure I have the serial stuff connected correctly and power is OK as I I can read from the device.
I can’t access my Discord account for some reason so I created an issue on the LibreTiny github and added the dump of the original firmware.
Just to finalise this, after a lot of assistance from the LibreTiny folks on github I have successfully loaded ESPHome on this smart plug and it works fine.
The process was a bit more complicated and required the writing of the separate OTA1 &2 files with a different software package. It also needed the smallest generic board type as the flash is only 1Mb.
The internal connections to the RTL8710BX module in the Tenda Beli SP3 plug are:
Relay1&2 GP12 Pin2
LED D6 GP22 Pin11 Red
LED D7 GP19 Pin12 Blue
Button1 GP11 Pin4
INFO ESPHome 2023.9.0b1
INFO Reading configuration /config/esphome/tenda-test22468.yaml...
INFO Starting log output from tenda-test22468.local using esphome API
INFO Successfully connected to tenda-test22468.local
[21:10:00][I][app:102]: ESPHome version 2023.9.0b1 compiled on Sep 15 2023, 13:16:12
[21:10:00][C][wifi:546]: WiFi:
[21:10:00][C][wifi:382]: Local MAC: 50:2B:73:F6:xx.xx
[21:10:00][C][wifi:383]: SSID: [redacted]
[21:10:00][C][wifi:384]: IP Address: 10.0.0.146
[21:10:00][C][wifi:385]: BSSID: 80:2A:A8:D1:CF:D5[redacted]
[21:10:00][C][wifi:387]: Hostname: 'tenda-test22468'
[21:10:00][C][wifi:389]: Signal strength: -31 dB ▂▄▆█
[21:10:00][C][wifi:393]: Channel: 1
[21:10:00][C][wifi:394]: Subnet: 255.255.0.0
[21:10:00][C][wifi:395]: Gateway: 10.0.0.1
[21:10:00][C][wifi:396]: DNS1: 10.0.0.1
[21:10:00][C][wifi:397]: DNS2: 10.0.0.1
[21:10:00][C][logger:357]: Logger:
[21:10:00][C][logger:358]: Level: DEBUG
[21:10:00][C][logger:359]: Log Baud Rate: 115200
[21:10:00][C][logger:361]: Hardware UART: UART2
[21:10:00][C][mdns:115]: mDNS:
[21:10:00][C][mdns:116]: Hostname: tenda-test22468
[21:10:00][C][ota:097]: Over-The-Air Updates:
[21:10:00][C][ota:098]: Address: tenda-test22468.local:8892
[21:10:00][C][ota:101]: Using Password.
[21:10:00][C][api:138]: API Server:
[21:10:00][C][api:139]: Address: tenda-test22468.local:6053
[21:10:00][C][api:143]: Using noise encryption: NO
[21:10:00][C][lt.component:013]: LibreTiny:
[21:10:00][C][lt.component:014]: Version: v1.4.0 on generic-rtl8710bn-2mb-468k, compiled at Sep 15 2023 13:15:57, GCC 10.3.1 (-Os)
[21:10:00][C][lt.component:015]: Loglevel: 3
There are some great tutorials on the internet
I used the above one and the updated video
I already flashed 3 lights.
Now I’m wondering if I should give it a try flashing the vacuum cleaner.
Or wil it destroy my device if ltchiptool doesn’t recognize it.
I also have the same labeled chip and flash the 2mb 468k board size.
Didn’t have to use separate software just the ltchiptool.
How stable is the wifi connection on the plug so far?
Has anyone tried to rename a device from the 3 dot menu the ESPHome addon ?? I just tried on my new RTL8710 based smart plug and it went through the hoops and uploaded something but the name stayed the same.
Also tested it on a random ESP based device and that worked as I expected.
Updating /config/esphome/tenda-test22468.yaml to /config/esphome/tenda-plug-1.yaml
Edit: OK the renamed device did show up in HA with the new name but the stuff in the ESPHome addon did not get updated to the new name. I had to create a new device with the new name and paste the old yaml into and manually rename it.
yes,
But flashing a device with esphome and having a working device are 2 different things,
After I have esphome running I would like to have the vacuum working.
It might be easier then I thought before, Earlier I thought Turning left/right and stopping based on sensors should be developed.
but checking out this branche
I think I only need to send the correct datapoints and just use tx/rx/
I’m not interested in keeping the tuya app working, I don’t use it now. So I should be good overwriting, still I think there is a lot which can go wrong and brick my vacuum cleaner.
