Device tracker - Owntracks
I am using Owntracks on my Iphone and on my two Ipads. It works, but I have not found an ideal setting for this to work.
If I choose to let owntracks app update to often (move mode), it will drain the batteries very fast. So I have choose to use the “significant change” mode. This resulting in that the battery status and gps location is not updating very often. Should I use another method to make this work better? I dont want to drain the batteries to fast.
I use this and it works great
Hi! Unfortunately I didn’t do a very good job with the first post in that topic, so you have to read through quite a few posts before you find where I keep the latest & greatest info on this custom component. You can find it on my github pages here.
