For background: This post follows on from issues described here Finding disconnected zigbee devices (ZHA) and here:
ConBee II after hardware change. In brief: It looked like the coordinator and/or Raspberry Pi failed, so I’ve now moved to new Raspberry Pi and a new zigbee dongle (Sonoff). I somehow managed to migrate the network to the new dongle (see previous posts).
(EDIT:) Prior to the failure, the system worked perfectly, no dropouts (using Conbee ii).
However - since the migration/rescue (now running off sonoff) - there are some devices that keep disconnecting from the Sonoff and become ‘unavailable’ - the devices can be paired, and then work in HA, but then after a few hours become unavailable. The devices aren’t all the same or all the same brand - some Tuya dimmers, some door sensors. It seems to affect devices individually: E.g., one Tuya dimmer works perfectly (at some distance from the coordinator) while a Tuya dimmer in the same room as the coordinator keeps becoming unavailable.
I guess I have several choices: (1) Keep resetting the devices in question… well, I’ve done that a fair few times, including full resets where possible, and the behaviour doesn’t change. (2) Reset my whole network (with the assumption that something in the migration/rescue didn’t quite work out) - but… it’s always the same devices that become unavailable… so unless there’s somehow a clash with an ID, not sure that resetting the network would really help. (3) I guess I could replace the affected devices… but it’s quite a few…
Any thoughts or ideas?
MANY THANKS!!!
