Depending on your setup, you could also put your sticks on a separate Pi and use already supported MQTT to get the data into home assistant instead of USB over IP. I did this in my setup, you can read more about it here if you like.
I don’t run HA on a Pi, I run it on a NUC, which is in a rack in the office. Therfore I didn’t put the stick there as the range is limited. In addition when Home Assistant fails for some reason or I need to restart the host, I don’t need to shutdown the Zigbee and Z-Wave network.
You can run it all on the same Pi, This was my setup before I moved to the NUC. Pi 3 with Home Assistant a ConBee ZigBee stick and a Aeotec Z-Wave stick.
I have the same requirement: HA as an virtual instance on a NUC. Both Zigbee (Conbee II) and Zwave (Aeotec) are on the USB ports of the NUC but the reach of the Zigbee stick is not ok.
I have multiple Zwave devices in my house to build a reliable network, but with Zigbee and the number of powered devices the network is poor.
I have red the possibility for using a pi and configure it for USB over IP, but not yet implemented… allthough using mqqt is an option it is not my preferred option… so if anyone has a working nuc with usb over IP implementation… please share
With the ConBee and deCONZ you don’t need MQTT or USB over IP. DeCONZ already supports running on a different machine than Home Assistant out-of-the box. The connection is done via Websocket.
let’s call it ‘age’
I’m used now of using the deconz add-on and don’t want to set-up my Zigbee network over again.
So my thought is: replacing Conbee to a Pi using some kind of software telling my VM to look in another place than the standard USB port (/dev/ttyACM1)
I will check the websocket part… running the Conbee on a Pi3
See my detailed guide here, how I setup a ConBee II and an Aeotec Z-stick on a separate Pi, Home Assistant is running inside a VM on an Intel NUC far away from the Pi.
Hi Burningstone, thanks for the guide. It was easy to follow. Only downside for me: when I have installed the integration in HA and go to http://myip:8080/pwa it doesn’t give me the option to go to the advanced settings of the gateway.
When I go the url I need to create a password, next get to connect lights. When I proceed without lights I receive a ‘Network was not found…’ screen.
Any idea what’s causing this… I have gone over the steps multiple times, but I can’t find a mistake
following your detailed description “Create docker-compose.yml file and directory deconz to store the config”. Do I need to create de deconz directory and put the docker-compose.yml file in it or will the directory deconz automatically be created by just copy your lines into ssh (only I changed was the super secret password)
if all the steps are followed and the udev path is the issue, what do I need to change (where to find an put the actual path)? Do I need to skip the SUBSYSTEM line? Do I only add the actual path to the docker-compose.yml?
The docker-compose.yml file is not in the ddconz folder, it’s on the same level. You can just create an empty folder, later when you start the docker deconz, it will write the database, config, etc. to this folder, because it is mounted in the docker-compose file.
Replace /dev/zigbee with the actual path, (something like /dev/ACM0) in the docker-compose file (it appears two times, make sure to change both).
If I only change the path /dev/zigbee to /dev/ttyACM0 i get an error on the docker-compose. I think it has something to do with the 99-usb-serial.rules I created.
Do I need to skip this file creation or do I need to have a different line in this file? (changing SUBSYSTEM==“ttyACM0” or something like this)
