What is the difference between disabling, hiding and removing entities?
Disable effectively makes an entity not exist. It technically still exists so Home Assistant and the integration that created it know itâs not missing and doesnât try to recreate it but from the perspective of the user it doesnât exist anymore. It wonât show up anywhere, itâs state is not being tracked and recorded, you canât reference it in automations, scripts, templates, etc.
Remove actually deletes it. As you would expect it also no longer shows up anywhere. However if you somehow remove an entity that an integration expects to exist then it may come back. Generally remove is for entities that you yourself made directly (like helpers, automations and scripts) rather then things made for you (like sensors and such created by an integration).
Hide is really just for the UI. And specifically only for the autogenerated UI that you get when you first make a dashboard. Hidden entities wonât show up in autogenerated dashboards. But unlike disabled they do still show up everywhere else, their state is still being tracked and recorded and you can still use them in automations, scripts and anywhere else in HA like normal.
Cool that makes sense! So for entities that get added like âpingâ or ânode_statusâ those are all entities that clutter up the interface and I should probably âdisabledâ them (not delete)?
Well either that or hide. If you donât use them at all then yea disable is best. But sometimes with entities like that you want to keep them around you just donât want them to appear in your main UI. Some examples of when hide is better:
- You still want to be able to go to the device page and see those details when debugging something
- You have an admin/dev dashboard that displays tech details of things that you use for debugging
- You still want to be able to use those entities in an automation (like notify if ping speed becomes too low or if the node status is anything but available and healthy).
But yea both of those probably fit better then delete if the entity is made by an integration.
Oh! Something I forgot before (was just reading the section on this in the release notes) - hide also keeps an entity from being exposed to HomeKit, Alexa and Google Home by default. Figured I should mention that for completeness.
How do you unhide ? If I select enable again HA reports it will available again â but remains hidden ?
Yes, My hidden entities are not being Unhid. I select them, click on âEnable Selectedâ, Box confirms will be added in 30 seconds - they arenât.
you have to hit update after you enable it.
That message of being added is intended for entities previously being disabled. To have thenm added to an autogenerated dashboard, the dashboard needs to be fully refreshed.
youâll know itâs unhidden when the status column shows a -. If itâs hidden it will show an eyeball thing. And as edwin said, youâll have to refresh for it to add to your autogenerated ui.
Hello all,
I have hidden some entities but they are still present into the search of my dashboard.
I need this entities are invisible in this dashboard because I used them into a button with pin.
What Iâm wrong? any way to fix it?
