Display custom text on MAX7219
Hi there,
I want to display custom text on my MAX7219 via ESPHome. So I created a input_text helper, which I want to update and the updates text should then be displayed on the matrix.
This is my ESPHome device config:
spi:
  clk_pin: D5
  mosi_pin: D7
display:
  - platform: max7219digit
    cs_pin: D4
    num_chips: 4
    intensity: 15
    lambda: |-
      it.printf(0, 0, id(digit_font), "%s", id(matrix_text).state);
font:
  - file: "common/pixelmix.ttf"
time:
  - platform: homeassistant
text_sensor:
    entity_id: input_text.matrix_text
Can this work? I get this error on compile:
src/main.cpp: In lambda function:
src/main.cpp:262:59: error: cannot pass objects of non-trivially-copyable type 'std::string {aka class std::basic_string<char>}' through '...'
       it.printf(0, 0, digit_font, "%s", matrix_text->state);
src/main.cpp:262:59: warning: format '%s' expects argument of type 'char*', but argument 6 has type 'std::string {aka std::basic_string<char>}' [-Wformat=]
Can somebody tell my what I need to change in order to get this working?
Thanks!
Hi Zoker!
Seems here the answer - https://esphome.io/components/text_sensor/mqtt_subscribe.html
it.printf(0, 0, id(font), "The data is: %s", id(mysensor).state.c_str());
Yes thanks, now it compiles and does not throw any issue anymore. But the matrix just stays empty. Do you have any idea why?
The entity does have this value:
Looks like alignment issue?!. Try to play with font size and TextAlign::BOTTOM_LEFT
I will try the same on my test matrix panel.
UPDATE:
Checked. Works correctly in my case. I’m using codi.ttf font - https://www.dafont.com/codi.font
Your yaml does not include the API.
Did you forget that or is it excluded from your copy paste here?
I actually forgot to add the ESPHome device to HA (I didnt notice before, because the time component seemed to work without adding it).
Yes I forgot to copy it, but it was/is there :slight_smile:
:smile: I caught it myself.
Another good check is:
if (id(matrix_text).has_state()) {
   it.printf(0, 0, id(digit_font), "%s", id(matrix_text).state.c_str());
} else {
   it.printf(24, 0, id(digit_font), "Nothing to show");
Can you give some instructions for this? The letters are on the half top left.
Here its written AAAAAA. I have tried everything BOTTOM, CENTER, BASELINE, BOTTOM_RIGHT, but when i put any of this the letters disappear. Any thoughts?
This is a bug in the current version. A fix for it is already on the way:
In the mean time you can solve this by including the TextAlign parameter:
it.printf(0, 0, id(digit_font), TextAlign::TOP_LEFT, "%s", id(matrix_text).state.c_str());
Hope this help :slight_smile:
Thanks, i will try it.
Works great. Thanks
Cool! How I missed that! This really help with my issue - MAX7219 text alignment confused me
But I still confused which alignment does font has by default. :roll_eyes:
That’s why I love forums. Everyone helps everyone :smiley:
I think all it should use TOP_LEFT, but maybe there are some more bugs here.
@machine2669 BTW: The text disappears on different text alignment, because the position must be adjusted as well. So if you for example set TOP_RIGHT, the text will be gone, since it starts on pixel 0 and from there the text grows to the left (so into a area, where is not pixels). I hope this is in any way understandable :sweat_smile:
