ESPHome Text Sensor does not get updated with Input_Text Helper from HA
ESPHome is really fun to play around, but as much fun it is, the faster you hitting a imaginary dead end :wink: but I know you are here to help - so this is another ESPHome mystery I could not solve with “search”
I created an input_text helper in HA. (screenshot below)
I populated some data to it using the “Dev Tools” (screenshot below)
I created a ESPHome Config with a display attached and static text works fine, also reading any other “sensor” also works but reading from the “input_text Helper” results in nothing. As you als can see in the screenshot looking at the sensor.notification_display which is pushed by the ESPHome Device.
I am struggling to figure out why the data is not getting pulled by the ESPHome device, or more specific, why only this helper sensor is not getting pulled.
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
# Sync Time with Home Assistant
time:
  - platform: homeassistant
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "${upper_devicename}"
    password: !secret wifi_ap_password
captive_portal:
# Enable Web server
web_server:
  port: 80
  auth:
    username: admin
    password: !secret web_server_password
i2c:
  sda: GPIO0
  scl: GPIO2
display:
  - platform: lcd_pcf8574
    dimensions: 16x2
    address: 0x27
    lambda: |-
      //it.printf(id(notification_display).state.c_str());
      it.printf(0, 0, "Data: %s", id(notification_display).state.c_str());
text_sensor:
  - platform: version
    hide_timestamp: true
  - platform: wifi_info
    ip_address:
      icon: mdi:ip-network
    mac_address:
      icon: mdi:network
    entity_id: input_text.notification_display
    attribute: state
grafik
Reference Posts
I created an input boolean that I switched on then off when input text changes.
The reason that the display timed for 1 minute is because the display is usually a clock, and the boolean is called news because I have an RSS feed from the BBC that I send to the input text
You also have to create input_boolean.news or whatever you are going to name it in HA.
I’m convinced there must be an easier way, but this works fine for me.
- action:
  - delay: 00:00:01
    entity_id: input_boolean.news
  - delay: 00:00:05
  - service: input_boolean.turn_off
  alias: New Message
  - platform: state
    entity_id: input_text.new_message
Then we have this in ESPhome
text_sensor:
    internal: true
binary_sensor:
    internal: true
    on_press:
        then:
        - lambda: |-
            id(news_bool) = true;
        - delay: 00:01:00
        - lambda: |-
            id(news_bool) = false;
display:
  - platform: max7219digit
    cs_pin: GPIO21
    num_chips: 8
    lambda: |-
      if (id(news_bool)) {
        it.printf(0, 0, id(digitss_font), "%s", id(new_message).state.c_str());
        it.scroll(true,1,30,2000,2000);
        it.invert_on_off(0);
I hope I’ve covered it all.
Thanks, I will try that solution.
But my main problem is that the text sensor is not getting any information from the input_text helper. Whereas if I use the same text sensor but another existinge sensor from HA it works.
So something is weird with the combination of my input_text helper and the sync to the text sensor on esphome.
State is not an attribute.
Thanks @nickrout I think this did the trick :slight_smile: and it makes somehow sense, also why I did not get an error :smiley:
Anyhow, after removing the attribute and also deleting the esphome device from integration and adding it again it “magically” works :smiley:
THANKS
This is the working code not
substitutions:
  devicename: "testing"
  upper_devicename: "Testing"
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
api:
time:
ota:
wifi:
  ap:
captive_portal:
i2c:
  sda: GPIO0
  scl: GPIO2
display:
    dimensions: 16x2
    address: 0x27
    lambda: |-
      it.printf(0, 0, "Data: %s", id(notification_display_l1).state.c_str());
      it.printf(0, 1, "Data: %s", id(notification_display_l2).state.c_str());
text_sensor:
    name: "Notification Display L1"
    entity_id: input_text.notification_display_l1
    name: "Notification Display L2"
    entity_id: input_text.notification_display_l2
