Display wifi icon based on wifi connection
I’m trying to display an icon based on wifi.connected.
interval:
  - interval: 10s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - lambda: 'id(affichage).printf(20, 20, id(icons), id(my_red), "\U000F05A9");'
        else:
          - lambda: 'id(affichage).printf(20, 20, id(icons), id(my_red), "\U000F05AA");'
I don’t get any errors on the log, the code complies properly, but the icon doesn’t show up. This is my display component, on which lambda is working properly :
display:
  - platform: ili9341
    model: TFT 2.4
    rotation: 180
    cs_pin: 5
    dc_pin: 4
    led_pin: 15
    reset_pin: 22
    lambda: |-
And icons :
  - file: 'materialdesignicons-webfont.ttf'
    glyphs:
      - "\U000F05A9" #mdi:wifi
      - "\U000F05AA" #mdi:wifi-off
      - "\U000F0769" #mdi:ceiling-light
      - "\U000F17C7" #mdi:ceiling-light-outline
      - "\U000F06B5" #mdi:lamp
      - "\U000F17D0" #mdi:lamp-outline
      - "\U000F0CCC" #mdi:shield-lock-outline
      - "\U000F099C" #mdi:shield-off-outline
      - "\U000F0CCB" #mdi:shield-home-outline
      - "\U000F1829" #mdi:shield-moon-outline
Any ideas?
Could it be that you are missing spaces?
    glyphs:
      - "\U000F05A9" # mdi:wifi
      - "\U000F05AA" # mdi:wifi-off
      - "\U000F0769" # mdi:ceiling-light
      - "\U000F17C7" # mdi:ceiling-light-outline
      - "\U000F06B5" # mdi:lamp
      - "\U000F17D0" # mdi:lamp-outline
      - "\U000F0CCC" # mdi:shield-lock-outline
      - "\U000F099C" # mdi:shield-off-outline
      - "\U000F0CCB" # mdi:shield-home-outline
      - "\U000F1829" # mdi:shield-moon-outline
If you talk about what’s after ‘#’, these are just comments.
I do this but in a slightly different way. I go here Material Design Icons and click on the actual icon I want (not the code), it copies it to clipboard.
Then, I paste in the glyphs list, it looks like this:
    glyphs: [
      "󰖩", # mdi-wifi
      "󰶑", # mdi-motion-sensor
      "󰠜", # mdi-door-open
      "󰌵", # mdi-lightbulb
      "󰛚" # mdi-garage-open
Thanks to @makai:
Ah! Of course…
Sorry about that.
Hii, I display wifi icon based on the wifi state like this, I created a template switch that checks for every 10s if wifi is connected. The state of the template switch is used to display whether the wifi is connected.
interval:
  - interval: 10s
    then:
      - if:
          condition:
            wifi.connected:
          then:
            - switch.turn_on: vk5
          else:
            - switch.turn_off: vk5
switch:
    optimistic: true
    restore_state: False
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    pages:
      - id: page1
        lambda: |-
          it.printf(10, 2, id(icon_font), TextAlign::TOP_LEFT, "%s", id(vk5).state ? "\U000F05A9" : "\U000F05AA");
font:
  - file: "_fonts/materialdesignicons-webfont.ttf"
    glyphs: [
      "\U000F05A9", #wifi
      "\U000F05AA", #no wifi
Hope this Helps :grin:
@VarunKumaran30 - Thank you for sharing your YAML. While it worked, I did not want to use or expose a switch to HA and figured I’d try using a variable instead to do the same thing. It appears to work… this is what I did:
Declaring the global variable:
#https://esphome.io/guides/automations.html?highlight=restore_value#bonus-2-global-variables
globals: ##to set default reboot behavior
  - id: wifi_connection
    type: bool
    restore_value: no
    initial_value: "false"
Code to set variable every 10 seconds:
interval:
  - interval: 10s
    then:
      - if:
          condition:
            wifi.connected:
          then:
            - lambda: |-
                id(wifi_connection) = true;
          else:
            - lambda: |-
                id(wifi_connection) = false;
Fonts code:
font:
  - file: "fonts/materialdesignicons-webfont.ttf"
    glyphs: [
      "\U000F05A9", #wifi
Speaking of fonts, I searched the icon font file on google, found the github, downloaded the file, and placed it in a new fonts folder with this path: \HASS_IP\config\esphome\fonts
Code to display the icon in the top right of the 64x128 screen:
it.printf(110, 2, id(icon_font), "%s", id(wifi_connection) ? "\U000F05A9" : "\U000F05AA");
Sharing your code with my modifications as an alternative in case it helps others :slight_smile:
This was very helpful… thank you.
I’m trying to use global variables to be able to perform some string concatenations as follows:
globals:
  - id: valve_icon
    type: std::string
    restore_value: no
    initial_value: '"\U000F058F"'
  - id: wifi_icon
    type: std::string
    restore_value: no
    initial_value: '"\U000F05A9"'
  - id: lineprint
    type: std::string
    restore_value: no
font:
  - file: "/config/esphome/Fonts/materialdesignicons-webfont.ttf"
    glyphs: [
      "\U000F05A9", # mdi-wifi
      "\U000F05AA", # mdi-wifi-off
      "\U000F058F", # mdi-water-pump
display:
    address: 0x3C
    pages:
      - id: intialval
        lambda: |-
          it.printf(3, 2, id(icon_font_16), "%s", id(lineprint));
interval:
  - interval: 10s
    then:
      - if:
          condition:
            wifi.connected:
          then:
            - lambda: |-
                id(wifi_status) = true;
                id(lineprint) = id(wifi_icon) + id(level_icon);
          else:
            - lambda: |-
                id(wifi_status) = false;
but I keep getting the following in the log:
[display:267] Encountered character without representation in font: '&'
01:00:24	[W]	[display:267] Encountered character without representation in font: '�'
and this:
[01:35:15][W][display:267]: Encountered character without representation in font: '\xcc'
[01:35:15][W][display:267]: Encountered character without representation in font: '&'
[01:35:15][W][display:267]: Encountered character without representation in font: '\xfb'
[01:35:15][W][display:267]: Encountered character without representation in font: '?'
[01:35:15][W][display:267]: Encountered character without representation in font: ''
For anyone still looking for a solution, here is mine which is quite simple and also handles displaying the wifi strength in mdi icons
wifi_icon.h
const char * wifi_icon(float wifi_strength) {
    if (isnan(wifi_strength))
			return "󰤮"; // No-wifi
	else if (wifi_strength < 10)
			return "󰤯";  // low-wifi
	else if (wifi_strength < 30)
			return "󰤟"; // wifi-1
	else if (wifi_strength < 50)
			return "󰤢"; // wifi-2
	else if (wifi_strength < 75)
			return "󰤥"; // wifi-3
	else
			return "󰤨"; // wifi-4
esphome:
    includes:
        - wifi_icon.h
  - platform: wifi_signal # Reports the WiFi signal strength in %
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
    update_interval: 60s
    entity_category: "diagnostic"
display:
    lambda: |-
      it.print(0, 0, id(mdi_medium), wifi_icon(id(wifi_signal_pct).state));
font:
  - file: "fonts/materialdesignicons.ttf"
    glyphs: [
        "󰤮", # no-wifi
        "󰤯", # low-wifi
        "󰤟", # wifi-1
        "󰤢", # wifi-2
        "󰤥", # wifi-3
        "󰤨", # wifi-4
@Tofandel, I’d like to use your code with one of my ESP32 projects. Problem is, due to the way the code snippet displays in your post, I can’t tell what (mdi?) characters should be referenced.
Is it safe for me to assume the code should read something like this;
			return "\U000F092B"; // No-wifi
			return "\U000F0920";  // low-wifi
			return "\U000F091F"; // wifi-1
			return "\U000F0922"; // wifi-2
			return "\U000F0925"; // wifi-3
	else
			return "\U000F0928"; // wifi-4
and this;
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs:
      - "\U000F0928" # wifi-4
      - "\U000F0925" # wifi-3
      - "\U000F0922" # wifi-2
      - "\U000F091F" # wifi-1
      - "\U000F0920" # Low-wifi
      - "\U000F092B" # No-wifi
The "󰤮" symbol being replaced with the associated mdi: code.
Edit - I took a chance and added the above file (wifi_icon.h) and code to my configuration. I’m happy to report all is working well. Now all I need to do is figure out how to associate a colour with each WiFi strength. Then I could show green for Hi strength, yellow for Medium and red for Low for no connectivity.
My IDE supports displaying those mdi fonts (phpstorm)
You can just copy paste them straight away from my code and they will work, it preserves the encoding
I simply copied the glyphs from https://pictogrammers.com/library/mdi/icon/wifi-strength-outline/
I’m not sure about the unicode of those
I wasn’t aware of that. Learned something new today. Thank you.
what is wifi_icon.h
and how is it uploaded to esphome?
It’s already in the code I posted
It’s just a C header file, which allows you to define C functions that you can use in your lambdas
Ok I’ll rephrase. Your code contains 2x boxes. The 2nd one is esphome code.
What do I do with the first code box?
Hi, thank you for this wifi icon solution, in the mean time I’ve added color to the wifi icon I’ll share it here if other people are interested.
added a function to the wifi_icon.h file here is the file in full:
#include "esphome/core/color.h"
        else
const Color wifi_color(float wifi_strength) {
                        return Color(127, 127, 127); // No-wifi
                        return Color(255,0,0);  // low-wifi
                        return Color(255,127,0); // wifi-1
                        return Color(255,200,0); // wifi-2
                        return Color(255,255,0); // wifi-3
        else
                        return Color(0,255,0); // wifi-4
for clarity paste the previous code block into a separate file called wifi_icon.h
then in the main display lambda it looks like this:
esphome:
  includes:
    - wifi_icon.h
display:
  - platform: st7789v
    model: Waveshare 1.47in 172X320
    dc_pin: GPIO15
    cs_pin: GPIO14
    reset_pin: GPIO21
    backlight_pin: GPIO22
    update_interval: 1s
    lambda: |-
      it.print(5, 5, id(mdi_medium), "\U000F058E");
      it.printf(50, 5, id(font1), "%.1f %%", id(casadebanhohumidade).state);
      it.print(275, 0, id(mdi_medium), wifi_color(id(wifi_signal_pct).state),  wifi_icon(id(wifi_signal_pct).state));
cheers
