What’s up smart homers! I was inspired by this project to create an automation blueprint that helps send text to the Pixoo64. The project referenced uses REST commands to control the Pixoo64, but I had to modify the “Send Text” REST command in order to make this blueprint work the way I wanted. Below is the blueprint, and following that are the all of the REST commands from the original project I referenced, but I’ve modified the “Sent Text” command and I’ve added a couple new ones. You need to add these to your rest_commands.yaml file or configuration.yaml file.
#Note: This blueprint requires rest commands to be set up in your Home Assistant instance.
blueprint:
name: Send Text to Pixoo64
description: Send text to the Pixoo64 - 4 lines, each can be their own color.
source_url: https://community.home-assistant.io/t/divoom-pixoo64-send-text-4-lines/554428
domain: automation
input:
text_line_1:
name: Text Line 1
description: Text to display on Line 1
selector:
text:
default: false
color_line_1:
name: Color Line 1
description: Line 1 text color (RGB value)
selector:
color_rgb:
default: [255, 255, 0]
text_line_2:
name: Text Line 2
description: Text to display on Line 2
selector:
text:
default: false
color_line_2:
name: Color Line 2
description: Line 2 text color (RGB value)
selector:
color_rgb:
default: [0, 255, 255]
text_line_3:
name: Text Line 3
description: Text to display on Line 3
selector:
text:
default: false
color_line_3:
name: Color Line 3
description: Line 3 text color (RGB value)
selector:
color_rgb:
default: [255, 0, 255]
text_line_4:
name: Text Line 4
description: Text to display on Line 4
selector:
text:
default: false
color_line_4:
name: Color Line 4
description: Line 4 text color (RGB value)
selector:
color_rgb:
default: [0, 0, 255]
text_speed:
description: Text speed if the text is long enough where it needs to scroll
selector:
number:
min: 10
max: 100
default: 50
mode: single
max_exceeded: silent
variables:
text_line_1: !input 'text_line_1'
text_line_2: !input 'text_line_2'
text_line_3: !input 'text_line_3'
text_line_4: !input 'text_line_4'
color_line_1: !input 'color_line_1'
rgbc1: >-
{{ "#%02x%02x%02x" | format(color_line_1[0], color_line_1[1], color_line_1[2]) }}
color_line_2: !input 'color_line_2'
rgbc2: >-
{{ "#%02x%02x%02x" | format(color_line_2[0], color_line_2[1], color_line_2[2]) }}
color_line_3: !input 'color_line_3'
rgbc3: >-
{{ "#%02x%02x%02x" | format(color_line_3[0], color_line_3[1], color_line_3[2]) }}
color_line_4: !input 'color_line_4'
rgbc4: >-
{{ "#%02x%02x%02x" | format(color_line_4[0], color_line_4[1], color_line_4[2]) }}
text_speed: !input 'text_speed'
trigger: []
- service: rest_command.pixoo64_reset_gif
- service: rest_command.pixoo64_send_gif
- delay:
milliseconds: 50
- service: rest_command.pixoo64_set_text
y: 2
font: 8
speed: "{{ text_speed }}"
text: "{{ text_line_1 }}"
color: "{{ rgbc1 }}"
- delay:
milliseconds: 50
y: 17
font: 8
text: "{{ text_line_2 }}"
color: "{{ rgbc2 }}"
- delay:
milliseconds: 50
y: 32
font: 8
text: "{{ text_line_3 }}"
color: "{{ rgbc3 }}"
- delay:
milliseconds: 50
y: 47
font: 8
text: "{{ text_line_4 }}"
color: "{{ rgbc4 }}"
I’ve added the rest of the necessary information in a comment because it won’t let me import the blueprint when it’s all in the original post.
