DIY 8 station irrigation based on ESPhome on KC868-A8 relay board
Project status: Work in progress.
I wanted to replace a very unsmart 24V AC irrigation timer system with something not too expensive and fully controllable by Home Assistant. I initially considered buying OpenSprinkler, but it’s actually not very cheap when you convert $US to AU and add the shipping. However, it’s would save a lot of work :slight_smile:
So when the KC868-A8 ESP32 relay module popped onto AliExpress last year I thought that had great potential as a DIY irrigation controller board, bought one to try out.
So far so good. I have it mounted in a smallish electrical enclosure. It has a 24V AC to 12V DC SMPS to supply regulated 12V DC to the KC868 board. The 24V AC is wired to each relay to drive solenoids.
I’ve added a big 16x2 LCD I had kicking around in my parts box, and also four push buttons for future use for saving the trouble of getting my phone out to do basic stuff.
Update: The system just got commissioned (24-10-2022), just in time for the Aussie summer.
Even when setting it up and then just checking the zones for broken sprayers and pop-ups it became obvious how much time is saves me I can control any zone from my phone while anywhere in the garden…
The initial code I’m testing currently. By no means finished or complete but the basics are running.
# 8 Zone Version and compiled via ESPhome
substitutions:
  devicename: irrigation-controller
esphome:
#  platformio_options:
#    build_flags:
#      - -DCONFIG_ARDUINO_LOOP_STACK_SIZE=16384
#  includes:
#    - irrigation.h
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
#esp32:
#  board: nodemcu-32s
#  variant: esp32
#  framework:
#    type: arduino
#    version: 2.0.4
#    source: https://github.com/espressif/arduino-esp32.git#2.0.4
#    platform_version: https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Irrigation"
    password: !secret ap_password
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
ota:
# I2C bus config
i2c:
  sda: 4
  scl: 5
  scan: true
# I2C I/O expander config
pcf8574:
  - id: 'pcf8574_output_hub'
    address: 0x24
    pcf8575: false
  - id: 'pcf8574_input_hub'
    address: 0x22
# 16x2 LCD config
display:
  - platform: lcd_pcf8574
    dimensions: 16x2
    address: 0x27
    lambda: |-
      // Print the zone switch status
      it.printf(0, 0, "Zone1: %s", id(zone_valve_sw1).state ? "ON" : "OFF");
      it.printf(0, 1, "Remaining: %3.1d", id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60);
      // Print the current time
      //it.strftime(0, 1,"Time %H:%M:%S", id(homeassistant_time).now());
      //it.printf(0, 1, "Duration: %3.1d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(1) / 60);
# Main sprinkler code
sprinkler:
  - id: esp32_sprinkler_ctrlr
    main_switch: "Master Run/Stop"
    auto_advance_switch: "Zones Auto Advance"
    reverse_switch: "Zones Reverse"
    valve_overlap: 1s
    valves:
      - valve_switch: "Zone 1"
        enable_switch: "Zone 1 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw1
      - valve_switch: "Zone 2"
        enable_switch: "Zone 2 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw2
      - valve_switch: "Zone 3"
        enable_switch: "Zone 3 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw3
      - valve_switch: "Zone 4"
        enable_switch: "Zone 4 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw4
      - valve_switch: "Zone 5"
        enable_switch: "Zone 5 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw5
      - valve_switch: "Zone 6"
        enable_switch: "Zone 6 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw6
      - valve_switch: "Zone 7"
        enable_switch: "Zone 7 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw7
      - valve_switch: "Zone 8"
        enable_switch: "Zone 8 Enable"
        run_duration: 900s
        valve_switch_id: zone_valve_sw8
# Valve control outputs config via I/O expander
switch:
  - platform: gpio
    pin:
      pcf8574: pcf8574_output_hub
      # Use pin number 0
      number: 0
      # One of INPUT or OUTPUT
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 1
      number: 1
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 2
      number: 2
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 3
      number: 3
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 4
      number: 4
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 5
      number: 5
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 6
      number: 6
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 7
      number: 7
      mode:
        output: true
      inverted: true
    internal: true
# Configuration to set multiplier via number
number:
    name: "Run Duration Multiplier"
    min_value: 1.0
    max_value: 3.0
    step: 0.1
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).multiplier();"
    set_action:
      - sprinkler.set_multiplier:
          multiplier: !lambda 'return x;'
# Configuration to set valve run duration via number
    name: "Zone 1 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
#    update_interval: 10s
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(0) / 60;"
    set_action:
      - sprinkler.set_valve_run_duration:
          valve_number: 0
          run_duration: !lambda "return x * 60;"
    name: "Zone 2 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(1) / 60;"
    set_action:
          valve_number: 1
    name: "Zone 3 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(2) / 60;"
    set_action:
          valve_number: 2
    name: "Zone 4 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(3) / 60;"
    set_action:
          valve_number: 3
    name: "Zone 5 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(4) / 60;"
    set_action:
          valve_number: 4
    name: "Zone 6 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(5) / 60;"
    set_action:
          valve_number: 5
    name: "Zone 7 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(6) / 60;"
    set_action:
          valve_number: 6
    name: "Zone 8 Duration"
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(7) / 60;"
    set_action:
          valve_number: 7
#Rain Sensor from my HA
  - platform: homeassistant
    entity_id: sensor.daily_rain_rate
# Time source config
time:
    timezone: Australia/Adelaide
    #timezone: CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00
Initially I had tried to run code from the project here but after expanding it out to the 8 zones I needed I ran into trouble. It ran the ESPhome out of resources (stack overflow issues) and also would not compile with ESPhome running on my Home Assistant Rpi4. I had to compile using ESPhome via Python on my desktop Windows 10 machine each time I wanted to work on the code. This was quite a discouragement as it was awkward to use (and setup) so I was happy when ESPhome added a native sprinkler component now.
The top blocks of #commented out code above reflects some of the things I had to add to get it to compile because of the resource issues, and gives context to why I have moved to the native sprinkler component.
Things missing currently are:
Code to use the buttons
Internal or external schedules (easy fix if using HA frontend).
Code to display the actual running zones run time and remaining time on the LCD
@mr.sneezy , great job
can you share some details on schematic/wired connection?
Hi bremby.
I don’t have any schematic as I just build up as I go. The connections are this:
The four buttons share one common ground, and each button goes to an input on ‘IN5 - IN8’.
The 16x2 LCD has a I2C converter attached like found on AliExpress or Ebay.
https://www.aliexpress.com/item/32713904220.html?
It connects to the header designated ‘IIC’ but has ground connected to the spare ground pin on header ‘P2’.
Board power comes from the 24V AC irrigation transformer (black wires seen in the bottom of build image), the transformer is also connected to each relay by ‘daisy chained’ wire links as seen in the image.
The 24V AC is converted to 12V DC for the KC868 board. To do that I used a small 2 Amp bridge rectifier that in turn feeds a 36V DC to 12V DC converter module (which sits at the top behind the LCD). Both are soldered to small Vero board (AKA perf board) strip to make it easy to mount to the box.
My DC-DC module is obsolete, but any module with greater than 36V DC input and at least 12V DC output at 2A or more will be fine…
The 12V DC output is wired direct to the KC868 +12V power input.
Output for the 8x irrigation valves is via the Normally Open contact of each zone relay (not yet connected). Each relay Common contact is connected to one side of the 24V AC transformer via the row of tinned wire links.
KC868A8
This is my code currently below. I’ve added ability to change the LCD display to follow the status of the running zone. I don’t have any internal scheduling yet, and I’m not sure I need too, maybe a default program if HA is off-air and one button assigned to start a manual watering.
Not sure yet if I should use HA automations for scheduling or create of borrow something for Node-Red…
# 8 Zone Version and compiled via ESPhome and Python3.10.4
substitutions:
esphome:
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
wifi:
  ap:
#    password: !secret ap_password
# Enable logging
logger:
api:
  reboot_timeout: 0s
  services:
    - service: pause
      then:
        - sprinkler.pause: esp32_sprinkler_ctrlr
    - service: resume
      then:
        - sprinkler.resume: esp32_sprinkler_ctrlr
ota:
# I2C bus config
i2c:
  sda: 4
  scl: 5
  scan: true
pcf8574:
    address: 0x24
    pcf8575: false
    address: 0x22
# 16x2 LCD config
display:
    dimensions: 16x2
    address: 0x27
    update_interval: 2s
    lambda: |-
        switch (id(esp32_sprinkler_ctrlr).active_valve().value_or(-1)) {
          case 0: //valve0, zone1, internal valve numbers not zone_valve_swX numbers
          it.printf(0, 0, "Front Lawn: %s", id(zone_valve_sw1).state ? "ON" : "OFF");
          if (id(zone_valve_sw1).state) {
          it.printf(0, 1, "Mins: %2d of", id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60);
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(0) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(0) / 60);
          break;
          case 1: //valve1, zone2,
          it.printf(0, 0, "Back Lawn: %s", id(zone_valve_sw2).state ? "ON" : "OFF");
          if (id(zone_valve_sw2).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(1) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(1) / 60);
          break;
          case 2:  //valve2, zone3,
          it.printf(0, 0, "Front middle: %s", id(zone_valve_sw3).state ? "ON" : "OFF");
          if (id(zone_valve_sw3).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(2) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(2) / 60);
          break;
          case 3:  //valve3, zone4
          it.printf(0, 0, "West Fence: %s", id(zone_valve_sw4).state ? "ON" : "OFF");
          if (id(zone_valve_sw4).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(3) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(3) / 60);
          break;
          case 4: //valve4, zone5
          it.printf(0, 0, "Front South: %s", id(zone_valve_sw5).state ? "ON" : "OFF");
          if (id(zone_valve_sw5).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(4) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(4) / 60);
          break;
          case 5:  //valve5, zone6
          it.printf(0, 0, "Back Wall W: %s", id(zone_valve_sw6).state ? "ON" : "OFF");
          if (id(zone_valve_sw6).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(5) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(5) / 60);
          break;
          case 6: //valve6, zone7
          it.printf(0, 0, "Back Wall E: %s", id(zone_valve_sw7).state ? "ON" : "OFF");
          if (id(zone_valve_sw7).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(6) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(6) / 60);
          break;
          case 7:  //valve7, zone8
          it.printf(0, 0, "Verandas: %s", id(zone_valve_sw8).state ? "ON" : "OFF");
          if (id(zone_valve_sw8).state) {
          it.printf(12, 1, "%2d", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(7) / 60);
          } else {
          it.printf(0, 1, "Mins Set %2d     ", id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(7) / 60);
          break;
          case -1:
          it.printf(0, 0, "Watering OFF");
          it.strftime(0, 1,"Time is %H:%M:%S", id(homeassistant_time).now());
          break;
          default:
          break;
sprinkler:
    valve_overlap: 1s
    valves:
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
switch:
  - platform: gpio
    pin:
      # Use pin number 0
      number: 0
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 1
      number: 1
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 2
      number: 2
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 3
      number: 3
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 4
      number: 4
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 5
      number: 5
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 6
      number: 6
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin number 7
      number: 7
      mode:
        output: true
      inverted: true
    internal: true
  - platform: template #this switch doesn't work properly. Can pause via HA frontend, but will not resume...  Via Services does work...
    name: "Pause Irrigation Switch"
    turn_on_action:
      then:
    turn_off_action:
      then:
number:
    min_value: 1.0
    max_value: 3.0
    step: 0.1
    mode: box
    set_action:
    icon: mdi:timer
    unit_of_measurement: Min
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 0
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 1
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 2
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 3
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 4
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 5
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 6
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 7
  - platform: wifi_signal
    name: "ESP Irrigation WiFi Signal Sensor"
    update_interval: 300s
    name: "Zone Time Remaining Sensor"
    icon: mdi:progress-clock
    unit_of_measurement: 'Min'
    lambda: "return id(esp32_sprinkler_ctrlr).time_remaining().value_or(0) / 60;"
    update_interval: 30s
#  - platform: template
#    name: "Zone Active Sensor"
##    unit_of_measurement: ''
#    lambda: "return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN);" #Valves are numbered from 0-7 internally which is an issue when displaying !
#    update_interval: 30s
time:
@mr.sneezy thank you so much,
I worked a little bit around you example and I stolen also something from ESPHome Sprinkler YAML - ESPHome - Home Assistant Community (home-assistant.io)
sharing back where I’m now
ESP Code
# Enable logging
logger:
#####  I/O expander hub definition
mcp23017:
  - id: 'mcp23017_hub'
    address: 0x20
#nodemcu devkit v4.0
i2c:
  sda: 21
  scl: 22
  scan: True
# Enable Home Assistant APIs
api:
  reboot_timeout: 0s
  services:
    - service: set_multiplier
      variables:
        multiplier: float
      then:
            multiplier: !lambda 'return multiplier;'
    - service: start_full_cycle
      then:
        - sprinkler.start_full_cycle: esp32_sprinkler_ctrlr
    - service: start_single_valve
      variables:
        valve: int
      then:
        - sprinkler.start_single_valve:
            valve_number: !lambda 'return valve;'
    - service: next_valve
      then:
        - sprinkler.next_valve: esp32_sprinkler_ctrlr
    - service: previous_valve
      then:
        - sprinkler.previous_valve: esp32_sprinkler_ctrlr
    - service: shutdown
      then:
        - sprinkler.shutdown: esp32_sprinkler_ctrlr
    - service: pause
      then:
    - service: resume
      then:
    - service: resume_or_full_cycle
      then:
        - sprinkler.resume_or_start_full_cycle: esp32_sprinkler_ctrlr
    - service: repeat_2
      then:
        - sprinkler.set_repeat:
            repeat: 2  # would run three cycles
    - service: repeat_3
      then:
            repeat: 3  # would run three cycles
sprinkler:
    valve_open_delay: 2s
    valves:
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
switch:
####### CONTROL SWITCH
    name: "Sprinkler Controller Run"
    optimistic: true
    on_turn_on:
      - text_sensor.template.publish:
          state: "Running"
      - switch.turn_off: esp32_sprinkler_ctrlr_pause
      - switch.turn_off: esp32_sprinkler_ctrlr_stop
    name: "Sprinkler Controller Stop"
    optimistic: true
    on_turn_on:
          state: "Stopped"
      - switch.turn_off: esp32_sprinkler_ctrlr_run
    name: "Sprinkler Controller Pause"
    optimistic: true
    turn_on_action:
      - delay: 500ms
      - lambda: |-
          if(id(esp32_sprinkler_ctrlr_status).state != "Running")
            id(esp32_sprinkler_ctrlr_pause).turn_off();
      - lambda: |-
          if(id(esp32_sprinkler_ctrlr_status).state == "Running")
            id(esp32_sprinkler_ctrlr_status).publish_state("Paused");
            id(esp32_sprinkler_ctrlr).pause();
    on_turn_off:
      lambda: |-
        if(id(esp32_sprinkler_ctrlr_status).state == "Paused")
          id(esp32_sprinkler_ctrlr_status).publish_state("Running");
          id(esp32_sprinkler_ctrlr).resume();
    name: "Sprinkler Controller Resume"
    optimistic: true
####### I/0  SWITCH
  - platform: gpio
    name: "MCP23017 Pin B2"
    pin:
      mcp23xxx: mcp23017_hub
      # Use pin B2
      number: 10
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    name: "MCP23017 Pin B3"
    pin:
      # Use pin B3
      number: 11
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    name: "MCP23017 Pin B4"
    pin:
      # Use pin B4
      number: 12
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    name: "MCP23017 Pin B5"
    pin:
      # Use pin B5
      number: 13
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    name: "MCP23017 Pin B6"
    pin:
      # Use pin B6
      number: 14
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    name: "MCP23017 Pin B7"
    pin:
      # Use pin B7
      number: 15
      mode:
        output: true
      inverted: true
    internal: true
  #- platform: template #this switch doesn't work properly. Can pause via HA frontend, but will not resume...  Via Services does work...
  #  id: pause_switch
  #  name: "Pause Irrigation Switch"
  #  turn_on_action:
  #    then:
  #      - sprinkler.pause: esp32_sprinkler_ctrlr
  #  turn_off_action:
  #    then:
  #      - sprinkler.resume: esp32_sprinkler_ctrlr
number:
    min_value: 1.0
    max_value: 3.0
    step: 0.1
    mode: box
    set_action:
# Configure repeat
    name: "Sprinkler Repeat Cycles"
    min_value: 0
    max_value: 300
    step: 1
    mode: box
    lambda: "return id(esp32_sprinkler_ctrlr).repeat();"
    set_action:
          repeat: !lambda 'return x;'
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 0
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 1
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 2
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 3
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 4
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 5
### SENSORS
    accuracy_decimals: 0
    lambda: |-
      if(id(esp32_sprinkler_ctrlr_status).state != "Paused")
      else
        return {};
    lambda: |-
      if(id(esp32_sprinkler_ctrlr_status).state == "Stopped")
      else
        return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN) + 1;
text_sensor:
      update_interval: 1s
time:
LOVELACE
  - theme: Backend-selected
    title: Sprinkler
    path: sprinkler
    type: panel
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
              - show_name: true
                show_icon: true
                show_state: true
                type: glance
                entities:
                  - entity: sensor.sprinklers_status
                  - entity: sensor.zone_active_sensor
                  - entity: sensor.zone_time_remaining_sensor
                state_color: false
              - type: entities
                entities:
                  - entity: number.run_duration_multiplier
                  - entity: number.sprinkler_repeat_cycles
            cards:
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_1
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_2
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_3
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_4
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_5
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                entity: switch.zone_6
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
            cards:
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_1_enable
                icon: mdi:toggle-switch-outline
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_2_enable
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_3_enable
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_4_enable
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_5_enable
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                entity: switch.zone_6_enable
                show_state: false
                hold_action:
                  action: none
            cards:
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_1_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_2_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_3_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_4_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_5_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                entity: number.zone_6_duration
                icon: ''
                show_state: true
                hold_action:
                  action: none
          - square: false
            columns: 3
            type: grid
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: call-service
                  service: esphome.sprinkler_previous_valve
                  data: {}
                  target: {}
                icon: mdi:skip-previous
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:stop
                show_state: false
                hold_action:
                  action: none
                entity: switch.sprinkler_controller_stop
                tap_action:
                  action: toggle
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  service: esphome.sprinkler_next_valve
                  data: {}
                  target: {}
                icon: mdi:skip-next
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:refresh-auto
                show_state: false
                hold_action:
                  action: none
                entity: switch.zones_auto_advance
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:arrow-collapse-right
                show_state: false
                hold_action:
                  action: none
                entity: switch.sprinkler_controller_run
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:keyboard-tab-reverse
                show_state: false
                hold_action:
                  action: none
                entity: switch.zones_reverse
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:play-pause
                show_state: false
                hold_action:
                  action: none
                entity: switch.sprinkler_controller_resume
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:pause
                show_state: false
                hold_action:
                  action: none
                entity: switch.sprinkler_controller_pause
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: navigate
                  navigation_path: /lovelace/sprinkler-control
                hold_action:
                  action: none
                icon: mdi:dots-horizontal
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  service: esphome.sprinkler_start_single_valve
                  data: {}
                  target: {}
                icon: mdi:sprinkler-variant
                show_state: true
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  service: esphome.sprinkler_repeat_2
                  data: {}
                  target: {}
                icon: mdi:water-sync
                show_state: true
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  service: esphome.sprinkler_repeat_3
                  data: {}
                  target: {}
                show_state: true
                hold_action:
                  action: none
    title: SPRINKLER Control
    path: sprinkler-control
    type: panel
    subview: true
    badges: []
    cards:
      - type: grid
        cards:
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_1_duration
                  - entity: switch.zone_1_enable
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_2_duration
                  - entity: switch.zone_2_enable
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_3_duration
                  - entity: switch.zone_3_enable
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_4_duration
                  - entity: switch.zone_4_enable
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_5_duration
                  - entity: switch.zone_5_enable
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                  - entity: number.zone_6_duration
                  - entity: switch.zone_6_enable
                    state_color: true
AUTOMATION
- id: '1665523175659'
  alias: Sprinkler Controller
  description: ''
  - platform: state
    entity_id:
    - switch.sprinkler_controller_stop
    to: 'on'
  - platform: state
    entity_id:
    - switch.master_run_stop
    to: 'off'
  - platform: state
    entity_id:
    - switch.sprinkler_controller_resume
    to: 'on'
  condition: []
  - if:
    - condition: trigger
    then:
    - delay:
        hours: 0
        minutes: 0
        seconds: 2
        milliseconds: 0
    - type: toggle
      device_id: 2a2143a5268d8661b4ce50e2807dcd62
      entity_id: switch.sprinkler_controller_stop
      domain: switch
  - if:
    - condition: and
      conditions:
      - condition: not
        conditions:
        - condition: state
          entity_id: sensor.sprinklers_status
          state: Paused
    then:
    - type: toggle
      domain: switch
  - if:
    then:
    - type: turn_off
      entity_id: switch.sprinkler_controller_pause
      domain: switch
    - type: turn_off
      entity_id: switch.sprinkler_controller_resume
      domain: switch
  mode: single
Here how it looks like
I have something to fix/understand:
  1. when I disable a zone, if I use the Next or Previous button the zone isn’t skipped. It works if I toggle the switch. any idea where is my error?
  2. I would like to have to total amout cycle remaing time and if i’m running more cycles what is the actual cycle eg 2/3, 3/6, etc
  3. can be possible to pass the zone value with sprinkler.start_single_valve directly by the UI with a drop down list menu? eg. press the single button and then select which valve to control
  4. how to use/interact with the queue (add/remove, see the queue list, etc)
I found a response for point 1
  • The next_valve, previous_valve and start_single_valve actions ignore whether a valve is enabled via its enable switch.
Not sure I can help with points 2, 3, 4 as your Yaml skills are well above mine. Nice frontend cards by the way :slight_smile:
I found an issue with ‘resume’ myself but have not tried to fault find it. I can Pause via GUI but Resume does not work.
Yes it would be better if previous/next did check the valve enable state. Perhaps this should be raised in the ESPhome Sprinkler git issues.
For my build I probably won’t use any Repeat cycle function, as I think the Multiplier is the way I’d change a cycle.
I’m experimenting a little bit with the “challenge” n#2
UI
    title: Sprinkler
    path: sprinkler
    type: panel
    badges: []
    cards:
        cards:
            cards:
              - type: entities
                entities:
                    icon: mdi:list-status
                    secondary_info: none
                  - entity: timer.sprinklercountdown
                    name: Sprinkler Countdown
                    icon: mdi:map-marker-path
                    icon: mdi:history
                state_color: true
              - type: entities
                entities:
                    icon: mdi:chart-multiline
                    icon: mdi:repeat
                state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
            cards:
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: false
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
            cards:
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
              - show_name: false
                show_icon: false
                type: button
                icon: ''
                show_state: true
                hold_action:
                  action: none
          - square: false
            columns: 3
            type: grid
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  data: {}
                  target: {}
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:stop
                show_state: false
                hold_action:
                  action: none
                tap_action:
                  action: toggle
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  data: {}
                  target: {}
                icon: mdi:skip-next
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                icon: mdi:pause
                show_state: false
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: navigate
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  data: {}
                  target: {}
                show_state: true
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  data: {}
                  target: {}
                show_state: true
                hold_action:
                  action: none
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  data: {}
                  target: {}
                show_state: true
                hold_action:
                  action: none
    type: panel
    subview: true
    badges: []
    cards:
      - type: grid
        cards:
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
            cards:
              - show_name: true
                show_icon: true
                type: button
                tap_action:
                  action: toggle
                icon: mdi:sprinkler
                show_state: false
                hold_action:
                  action: none
              - type: entity
              - type: entities
                entities:
                    state_color: true
AUTOMATION
  description: ''
  - platform: state
    entity_id:
    to: 'on'
  - platform: state
    entity_id:
    to: 'off'
  - platform: state
    entity_id:
    to: 'on'
  - platform: state
    entity_id:
    - switch.sprinkler_controller_run
    to: 'on'
    id: Sprinkler Controller Start
  - platform: state
    entity_id:
    - switch.sprinkler_controller_pause
    id: Sprinkler Controller Pause
    to: 'on'
  condition: []
  - choose:
    - conditions:
      sequence:
      - delay:
          hours: 0
          minutes: 0
          seconds: 2
          milliseconds: 0
      - type: toggle
        domain: switch
      - service: timer.finish
        data: {}
          entity_id: timer.sprinklercountdown
    - conditions:
      - condition: and
        conditions:
        - condition: not
          conditions:
          - condition: state
            state: Paused
      sequence:
      - type: toggle
        domain: switch
    - conditions:
      sequence:
      - type: turn_off
        domain: switch
      - type: turn_off
        domain: switch
      - service: timer.start
        data: {}
    - conditions:
      sequence:
          duration: '{{  ( (states(''number.zone_1_duration'')|int*60)+ (states(''number.zone_2_duration'')|int*60)+
            (states(''number.zone_3_duration'')|int*60)+           (states(''number.zone_4_duration'')|int*60)+
            (states(''number.zone_5_duration'')|int*60)+ (states(''number.zone_5_duration'')|int*60)
            )  | timestamp_custom("%H:%M:%S", 0) }}'
    - conditions:
      sequence:
      - service: timer.pause
        data: {}
    alias: SprinklerChoices
  mode: single
Cool. Nothing quite so interesting here. Installed the four physical buttons on the box lid and configured ESPhome to read them. Working fine. Now to do something useful with them.
(also adding a power input fuse to the box from the 24V AC transformer)
thank you @mr.sneezy , as you are some “steps” ahead me… shall you share how you wired the buttons and how configured the inputs?
I will try my best to get to the same page:D
I added four buttons using normally open momentary switches I had in my parts box. Kinconys diagram shows how to wire them. I picked I2C I/O hub inputs 5-8 because they were close to the ground pin which needs to be connected to one side of each button. You could use 1-4 etc to be more logical.
buttons2
Here is a closer image of the wiring as seen on the circuit board showing the 5 wires to the I2C I/O hub inputs.
Here’s a image of the back of the buttons in case it helps, really nothing to see though.
I’ve added a small inline fuse and holder to the main 24V AC input, as the transformer has none. It’s to protect the transformer if a valve cable in the garden is damged (shorted).
Like the LCD mount and the button mount, it’s 3D printed on my old but reliable Prusa i3 clone.
Code associated with the buttons for testing them. Results are seen in the ESPhome logs live view after flashing if you don’t have the LCD…
# I2C bus config
i2c:
  sda: 4
  scl: 5
  scan: true
pcf8574:
    address: 0x24
    pcf8575: false
    address: 0x22
binary_sensor:
  - platform: gpio
    id: button_1 #push button on front of controller enclosure
    pin:
      pcf8574: pcf8574_input_hub
      # Use pin number 4 (starting at 0)
      number: 4
      mode:
        input: true
      inverted: true
    internal: true
    on_click:
    - min_length: 50ms
      max_length: 350ms
      then:
  - platform: gpio
    id: button_2 #push button on front of controller enclosure
    pin:
      # Use pin number 5 (starting at 0)
      number: 5
      mode:
        input: true
      inverted: true
    internal: true
    on_click:
    - min_length: 50ms
      max_length: 350ms
      then:
  - platform: gpio
    id: button_3 #push button on front of controller enclosure
    pin:
      # Use pin number 6 (starting at 0)
      number: 6
      mode:
        input: true
      inverted: true
    internal: true
    on_click:
    - min_length: 50ms
      max_length: 350ms
      then:
  - platform: gpio
    id: button_4 #push button on front of controller enclosure
    pin:
      # Use pin number 7 (starting at 0)
      number: 7
      mode:
        input: true
      inverted: true
    internal: true
    on_click:
    - min_length: 50ms
      max_length: 350ms
      then:
    - min_length: 500ms
      max_length: 2000ms
      then:
Now that the buttons do useful stuff, I need to show that on the LCD (i.e paused status).
The paused valve number apparently is available internally form what I see on Github references, but I will need to make my LCD cases more complex or rethink that method…
paused_valve()
This is awesome! I just finished a basic irrigation controller 4 or 5 months before they introduced the sprinkler component but, doing it over had been on my to do list. Reading through the docs, I’ve been excitedl to take on this challenge and thanks to your awesome post I’ll have something to look st for help. Thank you for taking your time and sharing this with us! I appreciate this very much!
@mr.sneezy , I did something to simplify (I guess) the code for the SWITCH portion; this should safe a lot of rows…, let me know what do you think
lambda: |-
          case -1:
          it.strftime(0, 0, "%a", id(homeassistant_time).now());
          it.strftime(10, 0, "%d-%m-%Y", id(homeassistant_time).now());
          it.strftime(12, 1,"%H:%M:%S", id(homeassistant_time).now());
          it.printf(0, 3, "Status: %s", id(esp32_sprinkler_ctrlr_status).state.c_str());
          if (id(esp32_sprinkler_ctrlr_status).state == "Paused") {
          it.printf(0, 2, "Zone %s", id(zone_active_sensor).state.c_str());
          it.printf(10, 2, "T: %s", id(zone_time_remaining_sensor).state.c_str());
          break;
          default:
          it.printf(0, 0, "Zone %s:", id(zone_active_sensor).state.c_str());
          it.printf(8, 0, "%s", id(zone_active_sensor).state.c_str() ? "ON" : "OFF");
          it.printf(0, 1, "Time Letf: %s", id(zone_time_remaining_sensor).state.c_str());
          break;
I also made the LCD “dimmable” following these instructions from @LUNZ :clap:
[Dimmable PCF8574 LCD Display with ESPHome]
(Dimmable PCF8574 LCD Display with ESPHome)
here is the full code, just in case
# Establish Substitutions
substitutions:
  device_name: sprinkler
  friendly_name: "Sprinkler"
  device_platform: ESP32
  device_board: esp32dev
  device_ip: X.X.X.X
  sensor_update_frequency: 1s
  sprinkler_name: esp32_sprinkler_ctrlr
packages:
  wifi: !include common/device_wifi.yaml
  device_base: !include common/device_base_ESP32.yaml
  home_assistant_api: !include common/device_api.yaml
  sensor_wifi_ip_address: !include common/sensor_wifi_ip_address.yaml
# Enable logging
logger:
mcp23017:
    address: 0x20
i2c:
  sda: 21
  scl: 22
  scan: True
  frequency: 200kHz
# 10x4 LCD config
display:
    dimensions: 20x4
    address: 0x27
    update_interval: 1s
    lambda: |-
          case -1:
          break;
          default:
          break;
output:
  - platform: ledc
    pin: GPIO14
light:
  - platform: monochromatic
    output: sprinkler_backlight
    name: "LCD Display Sprinkler Backlight"
    restore_mode: ALWAYS_ON
api:
  reboot_timeout: 0s
  services:
      variables:
        multiplier: float
      then:
      then:
      variables:
        valve: int
      then:
      then:
      then:
    - service: shutdown
      then:
    - service: pause
      then:
    - service: resume
      then:
      then:
    - service: repeat_2
      then:
    - service: repeat_3
      then:
sprinkler:
    valves:
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
        run_duration: 900s
switch:
    optimistic: true
    on_turn_on:
          state: "Running"
    optimistic: true
    on_turn_on:
          state: "Stopped"
    optimistic: true
    turn_on_action:
      - delay: 500ms
      - lambda: |-
      - lambda: |-
    on_turn_off:
      lambda: |-
    optimistic: true
####### I/0  SWITCH
  - platform: gpio
    pin:
      # Use pin B2
      number: 10
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin B3
      number: 11
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin B4
      number: 12
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin B5
      number: 13
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin B6
      number: 14
      mode:
        output: true
      inverted: true
    internal: true
  - platform: gpio
    pin:
      # Use pin B7
      number: 15
      mode:
        output: true
      inverted: true
    internal: true
  #  id: pause_switch
  #  turn_on_action:
  #    then:
  #  turn_off_action:
  #    then:
number:
    min_value: 1.0
    max_value: 3.0
    step: 0.1
    mode: box
    set_action:
# Configure repeat
    min_value: 0
    max_value: 300
    step: 1
    mode: box
    set_action:
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    update_interval: $sensor_update_frequency
    mode: box
    set_action:
          valve_number: 0
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 1
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 2
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 3
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 4
    icon: mdi:timer
    min_value: 1
    max_value: 120
    step: 1.0
    mode: box
    set_action:
          valve_number: 5
### SENSORS
    name: "Cycle Total Time Sensor"
    lambda: "return id(esp32_sprinkler_ctrlr).valve_run_duration(0)/60 + id(esp32_sprinkler_ctrlr).valve_run_duration(1)/60;"
    #lambda: |-
    #  {% set ns = namespace(states=[]) %}
    #  {% for s in states.sensor %}
    #    {% if s.object_id.startswith('valve_run_') and s.object_id.endswith('_duration') %}
    #      {% set ns.states = ns.states + [ s.state | float ] %}
    #    {% endif %}
    #  {% endfor %}
    #  {{ ns.states | sum | round(2) }}
#    id: zone_active_sensor
#    accuracy_decimals: 0
#    #Valves are numbered from 0-7 internally which is an issue when displaying !
#    lambda: |-
#      if(id(esp32_sprinkler_ctrlr_status).state == "Stopped")
#        return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN);
#      else
#        return id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN) + 1;
#    update_interval: $sensor_update_frequency
    internal: false
text_sensor:
      #unit_of_measurement: ''
      #accuracy_decimals: 0
      lambda: |-
          int zone_active = id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN);
          std::string zone_active_as_string = esphome::to_string(zone_active);
          return zone_active_as_string;
        else
          int zone_active = id(esp32_sprinkler_ctrlr).active_valve().value_or(NAN) + 1;
#  # Expose Valve Progress Percent as a sensor.
      name: "Zone Progress"
      #unit_of_measurement: '%'
      icon: "mdi:progress-clock"
      lambda: |-
        int valve_progress_percent = round(((id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(id(esp32_sprinkler_ctrlr).active_valve().value_or(0)) - id(esp32_sprinkler_ctrlr).time_remaining().value_or(0)) * 100 / id(esp32_sprinkler_ctrlr).valve_run_duration_adjusted(id(esp32_sprinkler_ctrlr).active_valve().value_or(0))));
        std::string valve_progress_percent_as_string = esphome::to_string(valve_progress_percent);
        return valve_progress_percent_as_string;
# # Expose Zone Time Remaining
      #unit_of_measurement: 'Min'
      lambda: |-
          int seconds = round(id(esp32_sprinkler_ctrlr).time_remaining().value_or(0));
          int days = seconds / (24 * 3600);
          seconds = seconds % (24 * 3600);
          int hours = seconds / 3600;
          seconds = seconds % 3600;
          int minutes = seconds /  60;
          seconds = seconds % 60;
          return {
            ((days ? String(days) + "d " : "") +
            (hours ? String(hours) + "h " : "") +
            (minutes ? String(minutes) + "m " : "") +
            (String(seconds) + "s")
            ).c_str()};
        else
          return {};
### Input to managet the display backlight
      entity_id: input_number.sprinklerbacklightlevel
      internal: true
      on_value:
        then:
          - output.turn_on: sprinkler_backlight
          - output.set_level:
              level: !lambda |-
                return atoi(id(display_sprinkler_backlight).state.c_str()) / 100.0;
time:
    timezone: Europe/Rome
@mr.sneezy Very nice implementation of your ESPHome based irrigation system. I have an old RainMachine that is about to die and their replacement is both expensive and old so I think I will build my own. One thing I was curious about your setup is how the time is tracked as I did not see any reference to an RTC on the board. Did you add one? Or is time completely dependent on HA which may be an issue in case the system needs to operate on its own for some time.
I didn’t worry about RTC until it proves necessary yet. So far the network time has been reliable so the watering has been reliable.
Oddly enough I did another recent small project for somebody else that uses a $5 RTC module on an ESP32. I used this one below, but it needed four pull up resistors removed to make the SDA and SCL lines 3.3V compatible. As this module is I2C driven it should be not hard to add to the 8ch relay board in parallel with the LCD if I need too.
RTC Clock & EEPROM Module, I2C, DS1307, AT24C32 - 99Tech
