Ah - I see. So that would work with the load you are using, but not with my ceramic fan heater.
Thanks. Are you going to share your YAML? I would be interested to see how you have implemented this.
Slow PWM should be able to work for you, what kind of ceramic fan heater is this? Any pictures?
And yes, I will be sharing yaml but Iâm a bit embarrassed with how sloppy it is at the moment.
Just a cheap Chinese one, currently controlled via a smart relay connected to my control unit via optocoupler.
I might have to source one of your high voltage SSR and give it a try - thanks.
Some pics - doing some bread and pizza dough. You can see the leg of my smoker poking out on the left - maybe I should convert to electric once you finish your project.
Small heater on bottom right.
Control unit - designed to work under local control as well as via HA, HA is usually just used for monitoring.
Thanks for that link. Itâs got some good info there. I never thought about using an on/off valve to supplement a âpilotâ type needle valve.
I donât mind posting my info here but I donât want to derail @mcarter14777âs thread.
If he doesnât mind I can post up my info. If heâd rather I not then I can either PM you or maybe start another thread.
Final question I promise - what amperage SSR did you use? I can easily source a 40A one, at 240 V that should be more than enough for a heating coil similar to yours?
I donât mind! A grill is a grill!
My heating coil isnât actually very powerful. Itâs 1100W which comes out to about 9.17A on 120V. I chose the 25A ssr as the cheap Chinese ones are suspected of being overrated.
What type of probe did you use for your project?
Mine only operates at room temperature so I just used a Dallas one-wire temperature sensor.
I was thinking if I go your way and electrify my smoker I may try a K-type thermocouple, only issue is if it will read high enough.
Looking forward to more updates to your project, especially your YAML when you are happy with it.
OK then here goesâŚ
I used a nodeMCU to bring in the sensor signals and for the sensors themselves I used a K-type thermocouple for the smoker box temp and a thermistor probe for the food temp. I only have 1 food probe tho so thatâs where this one falls short of the commercial one you are using.
Since the NodeMCU doesnât use much power I can power it from either a USB wall wart charger or from a USB battery pack. As a test I left it running on a 10,000 mah battery pack and the battery finally died four days later.
The Arduino sketch provides an AP (SmokerConnectAP) on initial power up to enter all of your wifi and MQTT connection settings. Once you connect to the AP then go to IP 192.168.1.4 to enter the config. After you save the settings it reboots and connects to your wifi network and MQTT broker provided. Youâll have to search you network for the new IP address that your router provides the sensor.
If you ever take the box somewhere else you can use it on the new network because if it canât find the previous wifi network it defaults back to the AP mode and asks for configuration settings again.
the one thing that got too complicated was figuring out a foolproof way of bypassing the need for connecting to an MQTT broker if you go to a place where you just want to use the wifi but not MQTT. So I actually have two sketches - one that uses MQTT and one that doesnât - so either way it will work. But unfortunately you obviously canât run both sketches at the same time so if you take it âon the roadâ youâll have to re-flash it. I didnât find it to be worth the time to try to get it to work the way I wanted so I gave up on that part since most people will never use it on anyone elseâs network anyway.
Once everything is connected and running the NodeMCU serves up a webpage (that updates every 10 seconds) that I can connect to itâs IP address and view from anywhere on my home network so Iâm not limited by range issues of either Bluetooth or RF signals. Both of the ones I had used previously that used RF connections if I got more than about 20ft away it would lose signal.
It also uses MQTT to communicate to HA; again anywhere on the home wifi network.
The waterproof box I used has openings for the USB power connector, the thermistor connector, the thermocouple connector and three status LEDâs. The status LEDS show the power on state (green) i.e. if the NodeMCU is powered up, the network connection status (blue) to show that itâs connected to both wifi and MQTT and a flashing activity status (red) to indicate that the program is running and each time it takes a reading it will flash on for 1 second.
Obviously the âwaterproofâ box isnât waterproof anymore since I cut all the holes into it but I think it could be made waterproof again by sealing everything up with silicone.
I just now created a github repo to make it easier to download the sketch and the fritzing schematic/wiring diagram.
Here is the parts list along with links to get them on Amazon:
LEDâs â Amazon.com
waterproof box â Amazon.com
USB Power connectors â Amazon.com
thermocouple probe â https://smile.amazon.com/gp/product/B07JL1SN7X
NodeMCU â https://smile.amazon.com/gp/product/B07L8W9SP3
MAX6675 for thermocouple â https://smile.amazon.com/gp/product/B01HT871SO
MAX31855 for thermocouple â https://smile.amazon.com/gp/product/B07T7WY3H8
thermister probe â Amazon.com
Thermister connector â https://smile.amazon.com/gp/product/B01ASF0GWS
panel mount thermocouple connector â Amazon.com
thermocouple male connector â Amazon.com
capacitors â https://smile.amazon.com/gp/product/B07KRTQGL7
USB extension plug â https://smile.amazon.com/gp/product/B00B5HSC20
perf board â https://smile.amazon.com/gp/product/B07QL77SC5/
resistors â https://smile.amazon.com/gp/product/B072BL2VX1
You can likely get them cheaper on someplace like Aliexpress.
The price came out to about $45 total but the initial outlay was more than that since I bought a bunch of the parts above in bulk. But at least now Iâll have plenty of parts for the next project! At least thatâs how I justified it to my wife.
Here are a couple of pics of the end result:
The only thing thatâs different from that show in the pics is that I ended up moving the USB power connector further into the box and the used a short USB extension cable to connect power. I found that the USB connector board couldnât handle the stresses from plugging and unplugging the USB cable and it ended up breaking.
And the schematic:
yaml is up! I still think itâs a mess but now its commented!
This looks REALLY interesting. Thanks for your work on this. Iâm looking to do something along these lines for my kamado charcoal smoker. Does anyone have any ideas on how to modify this to control a 5v or 12v DC fan rather than the 120v AC heating element?
You could most likely just replace the slow PWM output component with either the ESP32 LEDC component or ESP8266 software PWM component depending on your microcontroller. That specified output pin would then control a mosfet or other suitable transistor that would switch the 12v or 5v supply to the fan at a high frequency while modulating the pulse width to vary the amount of power delivered to the fan.
Then comes the fun part, tuning!
I am a little confused. Did you connect the thermocouple probe to the Max31855 and the thermister probe to the MAX6675? On the pictures I only see the Max31855. Any reason why you used a MAX6675 and a Max31855 instead of two of the same? Thanks for your post and for sharing your project!
It seems that he is using a MAX6675 in his project. The MAX6675 is obsolete and the MAX31855 would be a suitable and better alternative. They are both thermocouple amplifiers. You only need one of these chips per thermocouple used.
For the thermistor, it is used as one of the resistors in a voltage divider so that you can read the voltage across the thermistor as it will change in relation to the temperature.
I originally ordered the MAX6675 but the right angled pins on the pre-soldered board didnât allow me to fit it in the box. And when I tried to de-solder the pins to replace them with straight pins I screwed up the traces. So the only boards I could find that didnât come pre-assembled with 90 degree pins were the MAX31855 boards so I ordered those instead.
Iâm really not sure if the MAX31855 is that much better than the MAX6675 for use in this case but thatâs the one I ended up using.
And as @mcarter14777 said above, you only need one of those for the thermocouple for the smoker box temp. the thermistor just gets connected directly to the analog input pin thru the voltage divider circuit.
Be aware that not all thermistors are the same. there are 10K, 100K and 1M thermistors and can be negative co-efficient (NTC) and positive co-efficient (tho Iâve never seen any of those only the negative co-efficient ones).
I tried the 1M thermistor and never got it to work and couldnât find a 10K thermistor so I used the 100K thermistor along with a 99K voltage divider resistor (I just noticed I still have the 1M voltage divider resistor in the schematic).
I am working on a version that uses charcoal and not electricity. I am adding a fan to try to control the temperature. But at this point I am just prototyping as I am waiting for a thermistor to arrive from China.
To control the 12v fan I am using an IRF520 mosfet like this one.
You connect the fan and power like below. The signal pin from the mosfet to a gpio pin on the microcontroller and the ground pin to ground on the microcontroller. In the esphome code just create a gpio switch.
switch:
- platform: gpio
pin: D3
inverted: false
What is your project about?
Hey atomicpapa, I found this thread because I wanted to do the same thing to my Masterbuilt smoker. Mine has the same control as yours. Right now I have a more primitive (not connected to home-assistant) controller I built about a decade ago that uses an industrial PID controller rather than an ESP. Itâs as simple as cranking the masterbuiltâs knob to max and then plugging it into the other controller.
I am trying to do something similar but I want to actually control the smoker. I am presently controlling it with this thing: https://youtu.be/2qsO83_x_7U?t=91
I want to convert the controller to an esp32 so that I can use HassioâŚ
If only there was a visual image of the wiring
I canât figure out your schematicsâŚ
This is what I got so far:
Thank you! You got me motivated to start a project like this for my Weber natural gas grill.
I already rejected Weber iGrill 3 stuff requiring an app. DIY wins again
