DIY(ish) Smart(ish) door closer for about 30USD - battery operated, USB rechargeable, RF controlled
Sick of your wifi leaking out of the open doors? Hate closing doors but don’t mind opening them? Then this is the perfect gadget for you!
Video of it operating:
Functionality summary:
- Spring loaded door is released by battery operated mechanism that is controlled via RF/433mhz.
- No power cables and recharge via powerbank etc
My main use case:
- Close some doors when heater/air con kicks in.
- Also close door if sunlight is shining on my guitars.
Door closing mechanism
Cabinet lock
Replace motor controller and power supply
The 9V battery USB recharging port is (relatively) accesible post assembly
How the internal mechanisms look when you crack open the cabinent lock.
Materials List:
- Latching mechanism and main enclosure (10USD): https://www.aliexpress.com/item/32995736248.html?spm=a2g0s.9042311.0.0.27424c4dEfC96v
- Door closing mechanism (10 USD) https://www.aliexpress.com/item/33014229079.html?spm=a2g0o.productlist.0.0.75324e32270RQD&algo_pvid=045c6b3b-4dd7-45a8-8407-983fe1ebe543&algo_expid=045c6b3b-4dd7-45a8-8407-983fe1ebe543-4&btsid=0ab6f82215878673063833513e377e&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
- RF 433mhz motor controller (4USD): https://www.aliexpress.com/item/32982568818.html?spm=a2g0s.9042311.0.0.27424c4dD6pZVR
- 9V usb rechargeable battery (4USD): https://www.aliexpress.com/item/4000121654682.html?spm=a2g0s.9042311.0.0.27424c4d8lEfhn
- 9v connector (0.25USD) https://www.aliexpress.com/item/32828564174.html?spm=a2g0s.9042311.0.0.27424c4d8lEfhn
- If you don’t have a Sonoff RF bridge or Broadlink RM pro, you’ll need that for RF 433mhz control. I think they’re great and you really should get one anyway.
Outline of approach:
- Replace RFID motor control board with RF control board
- Replace 2 x AA power supply with 9V USB rechargeable power supply.
Con’s:
- Door may not fully latch close (but this doesn’t necessarily really matter)
- No open sesame, only close sesame.
- A fair bit of hardware mods and plastic cutting etc.
- I 3d printed a holder for the clasp thingo that attaches to the door.
Reliability:
- Will report back on general reliability
- I’m a little suspicious of 9V battery capacity and RF control power usage, but if they do what they say on the tin, I might get say 3 to 6 months between recharges.
Other failed prototypes:
- Use a small latch solenoid. Wouldn’t move - too much side force
- Use a bigger latch solenoid (15N) . Wouldn’t move - too much side force
- Use electro magnets somehow like fire safety doors – too much power consumption.
Will post up a vid of it in operation shortly.
Can provide more detail if there is interest.
