Hello everyone,
For the past few weeks, I’ve been dealing with a rather “funny” issue with Home Assistant that has a significant impact on my network.
After every reboot—and then exactly every 60 minutes from that point—my HA instance sends thousands of DNS requests within a few seconds, which causes my entire local network to freeze.
I spent several weeks troubleshooting, starting from the initial symptom (network freeze) all the way to identifying Home Assistant as the root cause. I’m now confident that HA is responsible.
I’ve come across a few posts mentioning similar issues, but the suggested solutions aren’t very clear to me.
This behavior started after one of these changes:
- A Home Assistant Core update
- A Zigbee2MQTT update
- A firmware update on my ASUS router
What I’ve Tried So Far :
Changed HA’s IP (reserved in DHCP) Disabled some HA add-ons (like Music Assistant, Telegram) Switched DNS from Cloudflare to 8.8.8.8 Downgraded router firmware Confirmed no Wake-on-LAN on the network Checked DNS lease time (default: 86400s)
I’d really appreciate your advice on how to properly fix this.
Below, I’ve included a quick diagram of my current network setup, along with logs from both my Asus router and HA itself.
Thank you for your help!
DNS log on HA
> 2025-05-09 09:28:40.595 homeassistant dockerd[627]: time="2025-05-09T09:28:40.595092870Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:56837" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:56837->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t A"
> 2025-05-09 09:28:40.596 homeassistant dockerd[627]: time="2025-05-09T09:28:40.595253535Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:51776" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:51776->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t AAAA"
> 2025-05-09 09:28:43.096 homeassistant dockerd[627]: time="2025-05-09T09:28:43.096672006Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:50273" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:50273->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t AAAA"
> 2025-05-09 09:28:43.097 homeassistant dockerd[627]: time="2025-05-09T09:28:43.096698913Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:50248" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:50248->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t A"
> 2025-05-09 09:28:45.604 homeassistant dockerd[627]: time="2025-05-09T09:28:45.604049062Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:36780" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:36780->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t A"
> 2025-05-09 09:28:45.604 homeassistant dockerd[627]: time="2025-05-09T09:28:45.604060080Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:57390" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:57390->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t AAAA"
> 2025-05-09 09:28:48.105 homeassistant dockerd[627]: time="2025-05-09T09:28:48.105544626Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:39129" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:39129->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t AAAA"
> 2025-05-09 09:28:48.107 homeassistant dockerd[627]: time="2025-05-09T09:28:48.105629625Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:51336" dns-server="udp:9.9.9.9:53" error="read udp 192.168.1.100:51336->9.9.9.9:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t A"
> 2025-05-09 09:28:52.106 homeassistant dockerd[627]: time="2025-05-09T09:28:52.106648686Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:38600" dns-server="udp:192.168.1.1:53" error="read udp 192.168.1.100:38600->192.168.1.1:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t AAAA"
> 2025-05-09 09:28:52.107 homeassistant dockerd[627]: time="2025-05-09T09:28:52.107249531Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:192.168.1.100:37319" dns-server="udp:192.168.1.1:53" error="read udp 192.168.1.100:37319->192.168.1.1:53: i/o timeout" question=";o427061.ingest.sentry.io.\tIN\t A"
Log on asus
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=33277 DF PROTO=TCP SPT=40956 DPT=853 SEQ=356465925 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=12747 DF PROTO=TCP SPT=39974 DPT=853 SEQ=4250102778 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=46327 DF PROTO=TCP SPT=40958 DPT=853 SEQ=2106520644 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=10109 DF PROTO=TCP SPT=40004 DPT=853 SEQ=1953116849 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=21397 DF PROTO=TCP SPT=39992 DPT=853 SEQ=1386308144 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=18371 DF PROTO=TCP SPT=40030 DPT=853 SEQ=2173235087 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.1.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=16400 DF PROTO=TCP SPT=59840 DPT=853 SEQ=2284892309 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB0CB3E990000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=10143 DF PROTO=TCP SPT=39990 DPT=853 SEQ=857774310 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=21735 DF PROTO=TCP SPT=40014 DPT=853 SEQ=4022992539 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478450000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.1.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=47958 DF PROTO=TCP SPT=60006 DPT=853 SEQ=2893571359 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB0CB3E990000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.1.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=45306 DF PROTO=TCP SPT=60606 DPT=853 SEQ=3456848711 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB0CB3EB90000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=40519 DF PROTO=TCP SPT=40196 DPT=853 SEQ=4181429377 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478650000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.1.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=59885 DF PROTO=TCP SPT=59864 DPT=853 SEQ=642377711 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB0CB3EB90000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=14598 DF PROTO=TCP SPT=40046 DPT=853 SEQ=1993664808 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478650000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=9.9.9.9 LEN=82 TOS=0x00 PREC=0x00 TTL=62 ID=44676 DF PROTO=UDP SPT=48396 DPT=53 LEN=62
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.0.0.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=45251 DF PROTO=TCP SPT=41006 DPT=853 SEQ=3076760472 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080A019478C50000000001030307)
16/05/2025 18:54 GT-AC5300-A9C0-8393BAC-C kernel: ACCEPT IN=br0 OUT=eth0 MAC=0c:9d:92:aa:a9:c0:dc:a6:32:c4:57:04:08:00 SRC=192.168.1.80 DST=1.1.1.1 LEN=60 TOS=0x00 PREC=0x00 TTL=62 ID=30685 DF PROTO=TCP SPT=60036 DPT=853 SEQ=2495947027 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AB0CB3F790000000001030307)
System Information
| version | core-2025.5.1 |
| installation_type | Home Assistant OS |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.13.3 |
| os_name | Linux |
| os_version | 6.6.74-haos-raspi |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
Home Assistant Community Store
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| GitHub API Calls Remaining | 5000 |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 1770 |
| Downloaded Repositories | 5 |
Home Assistant Cloud
| logged_in | false |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
Home Assistant Supervisor
| host_os | Home Assistant OS 15.2 |
| update_channel | stable |
| supervisor_version | supervisor-2025.05.1 |
| agent_version | 1.7.2 |
| docker_version | 28.0.4 |
| disk_total | 56.4 GB |
| disk_used | 8.6 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Node-RED (19.0.2), Mosquitto broker (6.5.1), Zigbee2MQTT (2.3.0-1), File editor (5.8.0), Terminal & SSH (9.17.0), Log Viewer (0.17.1) |
Dashboards
| dashboards | 3 |
| resources | 4 |
| views | 6 |
| mode | storage |
Network Configuration
| adapters | lo (disabled), end0 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethd8b4d24 (disabled), veth9566c28 (disabled), vethde5b40d (disabled), veth2b4f503 (disabled), veth8671af4 (disabled), veth0692c0e (disabled), veth4182c2f (disabled), veth1d75b21 (disabled), vethe2d315e (disabled), vethdd74bbb (disabled), vethcd88876 (disabled) |
| ipv4_addresses | lo (127.0.0.1/8), end0 (192.168.1.80/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethd8b4d24 (), veth9566c28 (), vethde5b40d (), veth2b4f503 (), veth8671af4 (), veth0692c0e (), veth4182c2f (), veth1d75b21 (), vethe2d315e (), vethdd74bbb (), vethcd88876 () |
| ipv6_addresses | lo (::1/128), end0 (fe80::94f3:7dab:bcb8:8053/64), docker0 (fe80::d88d:9bff:fef9:987/64), hassio (fe80::80bf:77ff:fe3e:eaed/64), vethd8b4d24 (fe80::5c4b:59ff:fe60:874/64), veth9566c28 (fe80::8872:ddff:fea7:6cab/64), vethde5b40d (fe80::4c00:1dff:fe66:2686/64), veth2b4f503 (fe80::c8c:9eff:fe88:aed2/64), veth8671af4 (fe80::8c78:afff:fe42:2b9b/64), veth0692c0e (fe80::7ce2:d4ff:fe80:b202/64), veth4182c2f (fe80::6c1b:34ff:fe04:fd7a/64), veth1d75b21 (fe80::3407:fdff:fed0:6ae9/64), vethe2d315e (fe80::1cfb:4cff:fea5:6d06/64), vethdd74bbb (fe80::9860:1fff:fea3:71f/64), vethcd88876 (fe80::b036:38ff:fe50:1286/64) |
| announce_addresses | 192.168.1.80, fe80::94f3:7dab:bcb8:8053 |
Recorder
| oldest_recorder_run | May 6, 2025 at 12:47 |
| current_recorder_run | May 16, 2025 at 17:53 |
| estimated_db_size | 67.66 MiB |
| database_engine | sqlite |
| database_version | 3.48.0 |
