Hello everyone,
I believe I have some good news for Domintell equipment users. As a member of the Domintell board and a Home Assistant enthusiast, I managed to secure a dedicated developer for the creation of an official Domintell/Home Assistant module about a month ago.
We are expecting to have a beta version ready by January 15, 2025. A small update to the master (via Goldengate) will likely be required to retrieve certain data. The module will detect the master unit(s) (DGQ02/04/05) and list the detected devices.
If you have any feature suggestions, please donât hesitate to share them with me! Iâll keep you updated on the progress.
I had a meeting with mr Vryghem in 2023 about HA.
Iâm really thrilled having a board member sharing this view.
Canât wait to connect my Domintell system.
If you need a beta testerâŠ
I see that the lastest version is GoldenGate 20.16 ⊠any new one expected to run HA integration ?
Youâve post on linkedin about consumptions, is that plan to have some Domintell devices like DGQG05 exposing power consumption ?
Hello, thank you so much for this update. This is really the best solution we could hope for.
Which modules are planned for support? Will this be published to homeassistant or github?
As for features, it would be great if it at least supported things that domintell pilot supports. I am not sure if it is possible, but precise controll for blinds would be nice too (close 70% etc.)
I think I have everything set up correctly. Converted the serial numbers of the modules to hex via Decimal to Hex Converter. The connection test with Hercules gave me the complete Domintell config, so thatâs also okay. Yet my Domintell is not responding when I send commands. The slider switch moves to the right briefly and then returns to the left on its own after 2 seconds. The lights do not turn on. Iâm using:
Thank you so much for your support I actually refreshed my setup today with a new DGQ04. Are you still on track for a beta release by tommorow? Will you initially release it via HACS?
@Villersfr2 Hi is there any news on this new custom integration. I am holding off on either upgrading my master and power supply (still on a dgqg1) to use it in a hybrid setup with HA or to completely replace my domintell setup
I have a Domintell installation and upgraded to the new DGQG04 master.
Can I connect my installation to Home assistant?
Iâve sent an e-mail to Domintell support but didnât get an anwser yet.
