Door sensor configuration with time/light
Hi there,
I’m pretty new out here and i have some questions…
I have a daughter who, when she supposed to be in bed sneaks around, now i have put a door sensor on her door, horrible me :japanese_ogre:.
I want to automate it with te following:
when she goes to bed at 19:00/19:30 and she leaves her room, i want to turn a light in our livingroom in a colour and if we put her in bed again and close the door, i want to turn the light back to it original colour.
this what i have, at this point
   - alias: deur open
     initial_state: true
      - platform: state
        entity_id: binary_sensor.0x00158d00024605ed_contact
        to: 'on'
      - service: light.turn_on
        entity_id: light.hoeklampje
          brightness: 150
          rgb_color: [255, 0, 0]
   - alias: deur dicht
     initial_state: true
      - platform: state
        to: 'off'
          brightness: 150
          rgb_color: [247, 245, 163]
it’s working, but…
these are 2 different automations, is there a way to put in in 1?
the colour in the 2nd automation is not the original colour, where it was, is it possible to do so?
i do not know where i have to put a “timer” in, so the automation is active from 19:00 until 24:00/23:59
door sensors: Xiaomi
via: zigbee2mqtt cc2531
thanks in advance!
Michael
It can probably be combined into one automation, but it’s probably not worth the effort. It would become much more complicated for little pay pack. If it were me, I’d leave it as two automations like you have it (although I tend not to use the from: option with binary_sensor’s.)
To save and restore the light’s state, you could use a python_script I wrote for just this purpose. It is documented here, including an example of how you might use it.
Regarding limiting the time period in which these automations will run, you do that by adding a condition to your automations. E.g.:
    condition:
      condition: time
      after: 19:00:00
      before: 24:00:00
Thanks Phil!
question, where do i put the script in the automation(s)? also, i think i need to remove the homeassistant.turn_on service?
thanks in advance
Michael
Try:
  - alias: deur open
    initial_state: true
      platform: state
      to: 'on'
      - service: python_script.light_store
          store_name: deur
          brightness: 150
and
  - alias: deur dicht
    initial_state: true
      platform: state
      to: 'off'
        store_name: deur
        operation: restore
thanks again Phil,
in my config folder i created a python_scripts folder and there i dropped your light_store.py file and saved it as a python source file.
then i copied the automations wich you suggested, it was a valid config, but no luck.
when i opened and closed the door (didn’t wake my daughter), there was also no change in my entity card.
Did you add python_script: to your configuration? Does the account that is running HA have permission to the folder and script? Do you see python_script.light_store listed in the available services on the Services page? Did you restart HA, or at least run the python_script.reload service?
got it working!
but…when i put the condition in i get the following message:
  - alias: deur dicht
    initial_state: true
      platform: state
      entity_id:  binary_sensor.0x00158d0002460515_contact
      to: 'off'
    condition:
      condition: time
        after: 19:00:00
        before: 24:00:00
        store_name: deur
        operation: restore
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/configuration.yaml”, line 283, column 14
That because @pnbruckner wrote this;
condition:
  condition: time
  after: 19:00:00
  before: 24:00:00
And you did this;
condition:
  condition: time
    after: 19:00:00
    before: 24:00:00
Small but essential difference. If it still fails you probably need to use single quotes as in the docs.
doesn’t work either:
Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘after’]. Got None
extra keys not allowed @ data[‘condition’][0][‘before’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘condition’]. Got None
required key not provided @ data[‘condition’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 261). Please check the docs at https://home-assistant.io/components/automation/
also tried the single quotes, no luck
the time’s should be in quotes;
condition:
  condition: time
  after: '19:00:00'
  before: '24:00:00'
when i try your suggestion
 - alias: deur open
   initial_state: true
     platform: state
     to: 'on'
   condition:
     condition: time
     after: '19:00:00'
     before: '24:00:00'
          store_name: deur
         brightness: 150
Well there is another mistake in the action
      store_name: deur
Must be;
      store_name: deur
You need to watch the indentation very carefully.
it’s a typo in the preformatted tekst, in the yaml file it’s correct. sharp eyes tho…
the yaml line in the error message is the line of the condition in the config.yaml
24 hours is not allowed… It should be 00:00:00
Yep, as @Pippyn wrote. He is the winner :joy:
yep, @Pippyn …you’re the man!
thank guys for helping me out
Next :beer: is on me!
@marinesjeng please put the topic to solved, this might help others.
It seems after some try-outs the condition: time doesn’t work, my mistake i guess. even at 16:00 the lights go to red and back to it original colour.
- alias: deur dicht
  initial_state: true
    platform: state
    to: 'off'
  condition:
    condition: time
    after: '19:00:00'
    before: '23:30:00'
      store_name: deur
      operation: restore
and
- alias: deur open
  initial_state: true
    platform: state
    to: 'on'
  condition:
    condition: time
    after: '19:00:00'
    before: '23:30:00'
        store_name: deur
        brightness: 150
I don’t think that’s necessary, but of course, it doesn’t hurt to have them.
EDIT: Ok, I might be wrong here. I’m pretty sure times for at: in a time trigger don’t need to be quoted, but it does appear that times in a time condition do. Again, doesn’t hurt to quote times in both cases.
Hmm, can’t explain that. Are you sure the clock is set correctly on the system running HA, and the time zone setting in the environment (e.g., OS) and HA agree and are set correctly?
