Drop-down menu resetting to the top. Can't scroll down
Hello all,
Hopefully this is in the correct location. I have searched with no luck finding anyone with a similar issue.
Anytime I use the UI to setup/edit an automation or a script I am not able to scroll down in the drop-down menu to select an entity. It jumps back to the top. It seems to be a problem ONLY with the “call service” action type.
Example,
Action type = call service
Service = switch.turn_on
Name of entities = switch.bathroom_fan (this is the menu that has the problem)
Has anyone else had this issue?
Running Ubuntu / Docker / Hassio
Thank you,
Sam
With all my searching I somehow missed this post by BigHomie. It looks like it is the same issue.
