Ok I think I correctly followed all instruictions. Created the local addon, got this error
loop[2] find 10 mac and 16 ip
NET_DVR_Login_V30 failed, error code = 7
user_id is the user id of Hikconnect?
user_id = HCNetSDK.NET_DVR_Login_V30( “192.168.1.74”.encode(‘utf-8’), 8000, “admin”.encode(‘utf-8’), “myrealpasswordishere”.encode(‘utf-8’), device_info)
try the script on a x64 based system, it doesnt work on ARM processor
try for example first on a windows PC, download the LIB library from hikvison sdk website, because the added lib folder is for linux only
edit: no you need to enter admin credentials from outdoor station , not hikconnect
not sure what error 7 means, i though it was related to a network issue
192.168.1.74 is your outdoor? is your device where the scrypt isn running on same network? can you reach the device?
Just so I understand correctly, I have to peel off the cable get 2 wires (which are the POE NOT to take?) then soldering to 2 wires that have the doorbell signal?
BTW which are they ??.. Relay ouput I think is to OPEN DOOR?? Or perhaps using this CALL LINKAGE (last picture?)
Ok found the answere on some other forum, from a guy that added a ringer, so its definetely for my purpose too
You need to have ivms 2400 client running on your PC and go to ‘maintenance and management’.
Then ‘Add’ DS-KH6320 TE1 device, with DS-KH6320 TE1 on-line and showing green in ivms 2400.
Go to remote configuration, then go to ‘intercom’, then ‘call linkage’. then ‘enable’ trigger 1 or trigger 2 or both if you need both.
Then go to ‘Relay’ and ‘com1’ and/or ‘com2’ as required. then you are finished there.
At the rear panel of DS-KH6320-TE1, indoor station connect ringer to the relay terminals COM1 and NO1
OTHER QUESTION, POE WIRING
Ok, the standard POE seems to be type A or type B. Anyone knows which is Hikvision uses?
yes, indeed, you need to setup calling linkage with ivms 4200 , tru that first, normally you hear the relay triggering
it uses 802.3af , so only orange/green is needed… just try out with a spare cable
soldering is not needed… when you cut out the other pairs, just extend thel with a dupon cable, that fits on the relay also
I was asking @rafhome which model/firmware he has because I also have DS-KV8213 and want to understand why his ISAPI command doorpress event is working and mine not
