DS-KD8003 - DS-KV8113 - DS-KV8213 - DS-KV6113 - DS-KV8413 and .... integration Hikvision HikConnect Video intercom doorbell
ah ok
and what about sdk? did you try?
Not yet since I don’t know how to. I do have a spare raspberry and a VM with Ubuntu
Start easy, best to test on Ubuntu… Just grab the python file from GitHub, see first post, download the SDK from hikvision website, include the lib folder and run it, just change password and ip
Ok but what to do with the SDK, unzip it, and put where in the Ubuntu Vm? . Sorry newb
Hi, how do I downgrade the firmware? I upgraded my doorstation KV8113 to the latest firmware but it broke the card reader functionality I used to unlock my door… :frowning:
just place it in a folder, copy paste the “lib” folder also into it, download the sdk packge first from hikvsion website
then just start the hik?py file with a command like “python3 hik.py”
thats where I put all files (simple copy/paste of ALL SDK, then copy/paste of all files in hikvision-intercom-python-demo-main
Cattura
Received this
claudio@caddy19:~/test$ python3 hik.py
loop[2] find 4 mac and 9 ip
Segmentation fault (core dumped)
I see a problem with python3 version?
claudio@caddy19:~/test$ python3 --version
Python 3.8.10
how to change python version?
Yes, I have that too, I used 3.7
claudio@ubuntu20jitsinuc6:~$ python3 --version
Python 3.7.12
claudio@ubuntu20jitsinuc6:~$ cd /home/claudio/test
claudio@ubuntu20jitsinuc6:~/test$ python3 hik.py
loop[2] find 5 mac and 9 ip
Strange, works for me , try to run with command python3.7 instead of python3
I also was succesfulk on 3.9
Thank you for the answer. I will give it a try today (I am not a developer).
For the segmentation fault, not sure why I doesn’t work on some other python versions, we need @laszlojakab help here… Also created an issue on his GitHub for it
i installed the sdk addon and it i see it in home assistant.
but i can’t find some instruction how to use it?
do you somewhere have al link for this?
can i just run it inside home assistant?
i see some post of testing in windows , the more i read the more i’m not geting it :smiley:
i just want 2 things: door unlock and doorpress event ( get a notification if someone rings the bell)
model ds-kv8113
Try to run python script first manually, grab it from the GitHub Page and include the lib folder, run it and see if your device is supported…
Also if you run the addon, what does the log say?
BTW, the sdk is only for more events possible then ISAPI
if you want to open door, then you need to use the ISAPI command, its not included in the sdk script
I think its my bad luck 5, years and still not able to have a doorpress event :joy:
claudio@ubuntu20jitsinuc6:~/test$ python3.9 --version
Python 3.9.9
claudio@ubuntu20jitsinuc6:~/test$ python3.9 hik.py
Segmentation fault
Try, 3.7 , my addon runs 3.7 too
Hello Everybody,
i have the DS-KV8113 intercom solution.
I want to catch the door-unlock event in Home Assistant. So if someone unlock with a card on the terminal I will catch this event in home assistant.
Is this possible?
I get the doorbell event and I can unlock the door via the curl command.
I have also the SDK running on an windows Computer - in there I see the Unlock Event by the card. Is it possible to trigger from that status?
Have anyone an solution for that.
Best regards
If the SDK works ,the use the addon I posted , that will create a sensor for you
how did you set this up in home assistant, i have the same intercom…
Hello, for the Doorbell event I have created an Rest Sensor - the same as in the first post:
For open the Door, I have testet the HikConnect Custom Integration also from the first post - that works for me:
