Ok thanks, so for the doorpress i would like to anounce through alexa player if someone pressed the doorbell, any idea how i can do that, through automations or script?
claudio@ubuntu20jitsinuc6:~/test$ python3.7 hik.py
loop[2] find 5 mac and 9 ip
Segmentation fault
I try the route of the hardware. Wish to use a spare Shelly1 instead of an NodeMcu.
The cable COM1 and NO1, should go in I and O of the Shelly1, and then program the Shelly as momentary switch, or?
Can anyone tell me how to change the entity to a cover so I can ask Google to āopenā rather than āturn onā
I am following this guide
@pergola.fabio you think this will not damage the Hikviusion? Which I put in SW and which on L (COM1 to SW and NO1 to L or viceversa?)
Try creating a template cover, or create a routine in google
On indoor or outdoor? On my indoor , when I did calling linkage, there was no voltage, it was just a relay that closedā¦
For the door relay, thatās something else, if you want to trigger a door open, then there is offcourse output voltage, coming from your doorā¦ I believe it was for me 24vā¦ Nodemcu was only 3.3 , so created a voltage divider with resistor to bring it back
Indoor for doorbell press event
ok, thats easy, no voltage on it, just an open/close contact
Shelly1 is not connecting on my WiFi when on 12V ā¦ oh Gosh there is always something.
I found an old Nodemcu, will try that, do you use the ESPHOME? Can you share your code?
Indeed, esphomeā¦ Code? Was just an input sensor, 2 lines of code
A bit rusty, o this, on the nodemcu need to use two GPIO?
COM1 to GND
and
NO1 to GPIO2
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
inverted: true
filters:
# Small filter, to debounce the button press.
- delayed_on: 25ms
- delayed_off: 25ms
Yeah, think so, just test
Ok, it works, thanks for all
Is there a way to make the phone ring instead of a notification?
Thanks for all the great work on this integration. It allows me to easily open my gate from HomeAssistant.
Now, a crazy question:
Iād like to add a button to HomeAssistant which will trigger the doorbell on the HikVision outdoor post, as if someone pressed the button. Why? Weāre trying to train our puppy, and with Covid and all, we donāt get too many people ringing the doorbell So anyone knows the ISAPI call I could make for that?
setup your own PBX server? like asterisk?
Oh right, didnāt think of that. Would that make the indoor unit ring?
Itās just a sip extension, you can call if from any other sip client
Oh right. I use a Fritzbox here for my DECT phones, I guess I should be able to connect that.
yeah, should work, just register your indoor as an extension , then you can call it
