Okay, thank you… i will try it. I did not thought that parking a call helps the functionality of a doorbell. But it makes sense.
Did somebody got the still picture functionality of a Hikvision Doorstation via REST API working? At the moment i found a way through the ffmpeg platform. But it is too slow for live image processing.
yes, i have a custom .php script running that provides me snapshot urls, i have installed it on the webstation…
But if you already have SS, then just use the DSM integration, that gives you cameras in HA… so you dont need any snapshot url
Good Morning.
I saw this topic when I had already updated my DS-KD8003 to the latest version, 2.2.52. Now I can’t downgrade!
From what I could verify this latest version 2.2.52 still has the problem of not being able to access CallStatus events via ISAPI. “idle” always appears. Can you confirm?
Has anyone ever reported to Hikvision?
What do you advise me to do to be able to access these events?
Through the Hik-Connect app, if registered as hik-connect domain, it was peaceful, but I intend to use it only in the local home assistant. Hikvision’s service, in terms of security, leaves a lot to be desired. It doesn’t even allow you to configure 2FA!
yes, not possible to downgrade
you can run the hikconnect addon i created, its not based on ISAPI, but on the SDK on port 8000
that will give you callstatus, also events like motion/door opened … and its based on push, not polling
Do you think you can help?
If you can help too, can you share a YAML configuration example to capture the CallStatus=ring event? I’m still getting started with HA.
Yap, already work. My confusion betwen config GUI/YAML and the password was wrong.
If you can, share a YAML configuration example to capture the CallStatus=ring event. My idea is to capture the event when someone rings and notify me via app with a photo. For open door use ISAPI.
Thank you
Yes, the sensors template is created but then I don’t know how I’m going to capture the ringing events to integrate into HA in the way I indicated. I’m starting with HA, but I’ll see if I can.
Thanks for the excellent work, both with the Add-On and with the help for those who have these hikvision equipment. Congratulations @pergola.fabio
Early media is not supported any any PBX system when calling to multiple extensions… If you just call to 1 single softphone for example… Then it should work when you add progress() to your dialplan
One more question, I hope it’s the last
Automation, for now, is sending a notification to the ios app. I would like the notification to take an image captured at the moment they click on the 8003. Is it possible?
