OK, I added port forwarding on 443 to 8123
But same problem, internally https://philwashere.duckdns.org works
But externally it does not, adding :8123 makes no difference
if you port forward, you don’t want to add 8123. You want to leave it be. How are you port forwarding? Are you sure the port forward is sticking in the router?
Also double check the internal IP address for the port forwarding rule. It should be your hassio host’s network IP address.
Carrier grade network address translation (CGNAT) is a method for dealing with the limited number of IPv4 IP addresses available.
You and a bunch of your ISP’s other customers are assigned an IP address from the non-routable private range. This is then translated to a single routable IPv4 address on their internet connection side. They keep track of connections and ‘translate’ packets to and from this single address to many customers.
It works the same way as using a private network in your home with many devices on the private range all translated to the one public IP address assigned to your router by your ISP.
The easiest way to check if your IPS is using CGNAT is to look at your router’s public (WAN) IP address in its internet connection settings/monitor and compare that with the address reported by your DuckDNS setup page. They should be the same. If they are not, your ISP uses CGNAT and you should request that they turn it off. For some ISPs this request is free.
The other problem is that some ISPs block some common incoming ports. You should check with your ISP about this. I had to request port 443 be opened and it was free.
he’s not on CGNAT if the IP address his domain is resolving to is correct.
It could be port block as Tom says or you have not forwarded 443 to the correct device.
Thanks for the explanation and thank you to everyone for help so far…
I checked router ip and it matches that which DuckDNS is using so no CGNAT
Double checked router settings and correct device is set.
The thing that is really doing my head in is, this all used to work! I had it working internally and externally before I nuc’ed the virtual disk image so there shouldnt be an issue with ISP blocking ports.
Hi @dudester
Dodo is a Vocus company and they generally don’t do CGNAT or port blocking for DSL customers. The issue will most likely be on your end. It looks like you have configured everything on your modem router correctly.
OK, thanks for the tip have removed the images.
Within network PING returns same ip as whatismyip lookup.
Outside of network the same PING says name not found…?
