I recently upgraded to Home Assistant 2023.8.4 (run in a Docker container). For some reason I keep getting a duplicate HomeKit hub showing up, which is also duplicating all of my devices in Home. I have removed both hubs and re-paired multiple times, but eventually (maybe upon restart?) the phantom hub shows up again. Strangely, it is showing the previous version I was using as the firmware.
I’m configuring via YAML, not the UI; here’s my snippet:
homekit:
ip_address: 192.168.1.72
filter:
include_domains:
- cover
- light
- fan
- switch
- alarm_control_panel
include_entity_globs:
- binary_sensor.*_moisture
- binary_sensor.qolsys_*_detector
exclude_entity_globs:
- switch.basement_*
- switch.gym_*
include_entities:
- climate.basement
- climate.gym
Screenshots
Please help! This is causing lots of devices to show as “no response” and also causing Siri commands to hang (e.g. “turn the basement lights off”).
