It’s a great idea. I wish though we had support for this in the History Graph or in the excellent mini-graph custom card.
Beyond the time span configuration, it would also be great to be able to have a list of sensors to choose from
@ariel Well it is not that hard to implement, using the initial idea.
You can create a new input select with the sensors you want to show, and then use something like the following:
input_select:
sensors_to_show:
name: Sensors To Show
options:
- sensor.home_temperature
- sensor.watts
- sensor.home_humidity
Very good suggestion. I had implemented the time selector on a page with multiple mini graph cards, I hadn’t even considered also having a selector for data point. Implementing this would allow me to remove several graphs from the page!
Personally I do not have to reload at all. The graphs update whenever i choose a different time span.
However, make sure that you have included the entities: part in your card configuration, as It seems that it’s needed in order for the config-template-card to watch for changes on the input_select and update accordingly.
Thanks for sharing this. Excellent feature. Just out of interest, can you embed the ‘${vars[0]}’ variable in a history graph title, e.g. title: Rain Last ‘${vars[0]}’ hrs (does not work)
Ah, got it working, perfect!
I had my area selection in a separate entity card and I had referenced to that input_select under ‘variable’ but not the entity part of the ‘custom:config-template-card’.
This is pretty cool, thank you
Is there any way of making it show calendar days rather than hours?
I often find it useful not to see the last 72 hours but rather “today”, “yesterday” and two days ago, so 3 calendar days. This gives a nicer info on repeating events.
