E-Ink TODO list
Hi!
I’ve been playing with this for quite a while, and am very pleased that it’s working. A number of the problems I solved here seem a bit unusual; hopefully this helps some future folks.
I wrote up a full version here: Building an e-Ink ToDo list | praccu’s blog
Hardware
Name Price
WaveShare 7.5 inch screen $69.99
WaveShare ESP32 Driver Board $14.99
WaveShare Driver HAT $9.99
AdaFruit USB Battery Pack - 10000mAh $39.95
Tindie Power Bank Keep Alive $13.50
HomeAssistant base station (consider ODroid)
A frame that can display 6.5" x 3.9"
Home Assistant config
  - platform: command_line
    scan_interval: 30
    command: >
      echo "{\"tasks\":" $(
      curl -X GET https://api.todoist.com/rest/v2/tasks -H 'Authorization: Bearer REDACTED'
    value_template: >
      {{ value_json.tasks | length }}
    json_attributes:
      - tasks
    unique_id: 'todoist_tasks'
    sensors:
      item0:
        value_template: "{% if states.sensor.todo_list_2.state | int > 0 %} {{states.sensor.todo_list_2.attributes.tasks[0].content }} {% else %} {% endif %}"
      item1:
        value_template: "{% if states.sensor.todo_list_2.state | int > 1 %} {{states.sensor.todo_list_2.attributes.tasks[1].content }} {% else %} {% endif %}"
      item2:
        value_template: "{% if states.sensor.todo_list_2.state | int > 2 %} {{states.sensor.todo_list_2.attributes.tasks[2].content }} {% else %} {% endif %}"
      item3:
        value_template: "{% if states.sensor.todo_list_2.state | int > 3 %} {{states.sensor.todo_list_2.attributes.tasks[3].content }} {% else %} {% endif %}"
      item4:
        value_template: "{% if states.sensor.todo_list_2.state | int > 4 %} {{states.sensor.todo_list_2.attributes.tasks[4].content }} {% else %} {% endif %}"
      item5:
        value_template: "{% if states.sensor.todo_list_2.state | int > 5 %} {{states.sensor.todo_list_2.attributes.tasks[5].content }} {% else %} {% endif %}"
      item6:
        value_template: "{% if states.sensor.todo_list_2.state | int > 6 %} {{states.sensor.todo_list_2.attributes.tasks[6].content }} {% else %} {% endif %}"
      item7:
        value_template: "{% if states.sensor.todo_list_2.state | int > 7 %} {{states.sensor.todo_list_2.attributes.tasks[7].content }} {% else %} {% endif %}"
      item8:
        value_template: "{% if states.sensor.todo_list_2.state | int > 8 %} {{states.sensor.todo_list_2.attributes.tasks[8].content }} {% else %} {% endif %}"
      item9:
        value_template: "{% if states.sensor.todo_list_2.state | int > 9 %} {{states.sensor.todo_list_2.attributes.tasks[9].content }} {% else %} {% endif %}"
ESPHome Config
font:
  - file: "gfonts://Mukta"
    glyphs: "!\"%()+=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz'>?/&"
spi:
  clk_pin: 13
  mosi_pin: 14
text_sensor:
  - platform: homeassistant
    entity_id: sensor.item0
    name: "To-do List 1"
    entity_id: sensor.item1
    name: "To-do List 2"
    entity_id: sensor.item2
    name: "To-do List 3"
    entity_id: sensor.item3
    name: "To-do List 4"
    entity_id: sensor.item4
    name: "To-do List 5"
    entity_id: sensor.item5
    name: "To-do List 6"
    entity_id: sensor.item6
    name: "To-do List 7"
    entity_id: sensor.item7
    name: "To-do List 8"
    entity_id: sensor.item8
    name: "To-do List 9"
    entity_id: sensor.item9
display:
  - platform: waveshare_epaper
    cs_pin: 15
    dc_pin: 27
    busy_pin: 25
    reset_pin: 26
    model: 7.50inV2
    reset_duration: 2ms
    update_interval: 10sec
    lambda: |-
      int x = 36;
      it.printf(x, 0, id(font1), "=> %s", id(todo0).state.c_str());
      it.printf(x, 40, id(font1), "=> %s", id(todo1).state.c_str());
      it.printf(x, 80, id(font1), "=> %s", id(todo2).state.c_str());
      it.printf(x, 120, id(font1), "=> %s", id(todo3).state.c_str());
      it.printf(x, 160, id(font1), "=> %s", id(todo4).state.c_str());
      it.printf(x, 200, id(font1), "=> %s", id(todo5).state.c_str());
      it.printf(x, 240, id(font1), "=> %s", id(todo6).state.c_str());
      it.printf(x, 280, id(font1), "=> %s", id(todo7).state.c_str());
      it.printf(x, 320, id(font1), "=> %s", id(todo8).state.c_str());
      it.printf(x, 360, id(font1), "=> %s", id(todo9).state.c_str());
deep_sleep:
  run_duration: 60s
  sleep_duration: 60min
