ESPHome display with to-do list integration
I’d like to use the to-do list integration and display a list on a screen using ESPHome.
Like E-Ink TODO list.
Do you think this is possible?
Regards
Is it a shot in the dark, or did you already try some things?
For now, I’m just asking how to get a todo list from ESPHome.
Well, the project you linked seems to do exactly that, so it’s unclear what you are actually asking for…
It is base on api.todoist.com. I would use home assistant’s local data, not a cloud API.
The project uses a rest integration to get a list from todoist.
To get the items from a Todo list that is already in ha, use the service todo.get_items, for example one of ours is stuff for the forthcoming grandchild, and the service call is
service: todo.get_items
  entity_id: todo.baby
  status:
    - needs_action
    - completed
Response
todo.baby:
  items:
    - summary: maternity pillow
      uid: NTTyY_wak2kJQsOY1wBXoJ
      status: needs_action
    - summary: rocking chair
      uid: JbzVGI-yEw3LYkGLb7gDt5
    - summary: drawers
      uid: Kr5BOMrhk9tIZ2463un4wl
    - summary: changing table
      uid: AuxfZbHi0AkIYRazul7-P-
    - summary: car seat
      uid: LxrNWmTm0J0I0yrx728hL9
    - summary: buggy
      uid: B3-_cYghUSwKnCuclG3m4O
You can call any service from esphome.
First of all, I’d just like to display my list on the console to make sure that my list has been retrieved from HA. But there’s a syntax problem with the example given.
'.' is an invalid character for names. Valid characters are: abcdefghijklmnopqrstuvwxyz0123456789-_ (lowercase, no spaces).
INFO ESPHome 2024.3.0b1
INFO Reading configuration /config/esphome/todo-list.yaml...
Failed config
api: [source /config/esphome/todo-list.yaml:15]
  encryption:
    key: JS+SIL49enfizAJAXS04wFERN7uuWdAyBXU0utXq0oo=
  services:
      [target] is an invalid option for [0]. Please check the indentation.
        entity_id: todo.liste_dachats
      [data] is an invalid option for [0]. Please check the indentation.
        status:
          - needs_action
          - completed
      then:
        logger.log: todo.get_items
esphome config
esphome:
  friendly_name: TODO list
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "JS+SIL49enfizAJAXS04wFERN7uuWdAyBXU0utXq0oo="
  services:
    - service: todo.get_items
        status:
          - needs_action
          - completed
      then:
        logger.log: "todo.get_items"
ota:
  password: "4b359a10a60c6f661615eb63fa3d5943"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Todo-List Fallback Hotspot"
    password: "0FCoWB5cSyjA"
captive_portal:
That is to create a service in home assistant to run code on the esp. i.e. this <
Native API Component — ESPHome>
You want homeassistant.service
https://esphome.io/components/api#homeassistant-service-action
Thanks for the explanation.
So is it possible to retrieve the list in a variable with a service call and store it into a variable?
switch:
  - platform: gpio
    pin: 25
    on_turn_on:
    - logger.log: "Switch Turned On!"
      # https://esphome.io/components/api.html#homeassistant-service-action
    - homeassistant.service:
        # https://www.home-assistant.io/integrations/todo/
          entity_id: todo.personal_tasks
        variables:
          my_variable: |-
            return id(my_sensor).state;
    - logger.log: my_variable
