E3DC Remote Storage Control Protocol (RSCP)
Hello Toben,
I have just installed your E3/DC tool, thank you very much for your work, it works really well if you can connect to the house power station.
Initial we had connection problems with the E3/DC S20x pro. The error message was invalid authentication.
After a lengthy search by my son, who is profound with computers, we found out that using an RSCP password (AES key) with 32 characters solved the problem.
We have not found out the exact cause of the error. But maybe we can help other users with this answer.
Best regards
Marco
Hallo Meik, das liegt daran, dass die der Integration zu Grunde liegende pye3dc Bibliothek derzeit keine Option hat, den Port zu wechseln. Sobald das dort unterstützt wird, kann man das recht einfach in die hacs-e3dc einbinden.
Thank you! Great to hear!
Thanks for the feedback. A key of that size is not required to my knowledge, but it must be set, it cannot be ommitted. So if your key was empty/unset, that might be the case. Also, I’d recommend sticking to US-ASCII characters, as I haven’t made any tests if the character encoding is handled correctly by all involved components. So avoid special characters like öäü etc.
Torben
HACS-E3DC 3.10.0 released. It allows you to control the power mode of your E3DC in more detail.
HACS-E3DC 3.11.0-beta.1 open for testing with a bunch of new features:
  • E3DC farm support
  • SSDP discovery support to E3DC config flow
  • SG Ready Integration
  • Optional Battery Pack and Module Devices
Send Feedback to:
3.11.0 Beta 2 fixes farm controller detection
Send Feedback to:
3.11.0 Beta 3 fixes battery pack detecition
Send feedback to
Hallo,
ich benutze die Integration schon länger und sie läuft problemlos.
(Die Beta habe ich noch nicht installiert)
Ich vermisse 2 Punkte oder evtl. übersehe ich auch was.
  1. (hatte ich auch bei GitHub schon mal angefragt aber keine Antwort bekommen)
    Gibt es eine Möglichkeit die PV Leistung von 2 getrennten Panel Feldern (Dachflächen mit unterschiedlicher Ausrichtung) zu sehen?
    Beide werden als separate Leitungen in den S10E geführt und dort als Tracker 1 und Tracker 2 angezeigt.
Kann man irgendwie sehen, ob die Notstrom Funktion aktiv ist?
Ich würde gerne einige Verbraucher abschalten, wenn Notstrom aktiv aber es gibt scheinbar keinen Parameter der definitiv sagt ob Notstrom aktiv oder nicht.
Gruß,
Karsten
I’ve been using the integration for a while now and it’s running well.
(I haven’t installed the beta yet)
I’m missing two things, or perhaps I’m overlooking something.
  1. (I already asked about this on GitHub but didn’t get a response)
    Is there a way to see the PV output of two separate panel arrays (roof surfaces with different orientations)?
    Both are connected to the S10E as separate lines and displayed there as Tracker 1 and Tracker 2.
Is there any way to see if the emergency power function is active?
I’d like to switch off some appliances when emergency power is active, but there doesn’t seem to be a parameter that definitively indicates whether emergency power is active or not.
Regards,
Karsten
Hallo Karsten,
Danke für die Blumen, BTW: 3.11 ist jetzt raus, trifft Dein Thema aber nicht.
Du übersiehst nichts, es ist ein Hobbyprojekt mit grade mal 3 Entwicklern, wir benutzen den E3DC alle, aber es hängt halt immer am Real Life :wink: Meine Zentralverwaltung hier reißt mir sonst irgendwann den Kopf ab :smiley:
Unterstützen tun wir das aktuell nicht, nein.
Aus dem Bauch raus könnte man das sicher implementieren, die RSCP API bietet ein weites Feld an Informationen und Steuerungsmöglichkeiten. Meist scheitert man ein Stück weit an der Dokumentation im Detail, mit etwas Reverse Engineering geht das dann. Die Herausforderung ist, dass man das nur implementieren kann, wenn man ein passendes Setup zu Hause hat. Ich habe nur ein Tracker, könnte also jegliche Änderung in diese Richtung nicht selbst testen.
Das ist auf der Wunschliste, ja: Implement get_system_status · Issue #33 · torbennehmer/hacs-e3dc · GitHub
Viele Grüße
Torben
Version 3.11 has been released with a bunch of major changes:
  • Add E3DC farm support
  • Add SSDP discovery support to E3DC config flow
  • Added SG Ready Integration
  • Add Optional Battery Pack and Module Devices
Also, please be aware that the minimum HA version required is now 2025.8
Please send any comments to the release to this discussion thread on Github:
Guten Abend,
dies ist mein erster Post hier - bitte seht es mir nach, wenn ich noch etwas üben muss.
Erstmal vielen Dank für die tolle Integration, Torben.
Darf ich mich hier melden, wenn ich irgendwo Hilfe brauche, um die E3DC Integration besser zu verstehen und anzuwenden?
Viele Grüße aus Hamburg
Jens
Hello Torben,
I installed your integration some time ago and have been using it for at least 2.5 years now… :blush:
I’ve always wondered why there hasn’t been an update for this integration. Now I’m looking into a problem with this integration and came across this post, and I realize that there havebeen updates all along… :smiley:
Since my integration is still on version 3.10, my first question is, how can I update this integration? This is a point that isn’t clear to me yet.
We have an uninterruptible power supply (UPS) installed in our E3DC system. It switches to emergency power within milliseconds if no external power can be supplied.
Currently, I have not found a way to query this status using this integration.
Furthermore, I would like to query the temperature of the batteries as well; so far I have not found a method for how to do this. Does your integration support this or is it planned for the future?
Many thanks Best regards Micha
Hallo Jens,
Im Zweifel bitte die Discussions auf GitHub benutzen, da lesen außer mir noch ein, zwei andere mit. Ein Discord ist im Aufbau, aber noch nicht ganz fertig.
Hi Micha,
3.11 is compatible to 3.10 (semantic versioning), so just use either HACS internal update mechanism or if manually installed, update manually. hacs-e3dc does not have a separate update mechanism, just use the standard for all HACS components.
This isn’t implemented yet, see Implement get_system_status · Issue #33 · torbennehmer/hacs-e3dc · GitHub
As far as I know the new battery metrics, there is no current temperature. bullit186 implemented this, you may want to raise a feature request about this. I guess the value is available, just not mapped. However, there is no gurantee if and when bullit186 or anyone else get’s around to it.
Torben
Many thanks for this helpful integration!
I was planning to use it to cap the battery charge at 80% during months where I do not need the full battery capacity to get thru the nights.
Unfortunatley I can't get set_power_mode with settings to discharge to run. The error message is:
Die Aktion e3dc_rscp.set_power_mode konnte nicht ausgeführt werden. set_power_mode: must be called with a value above zero for 2.
This is the yaml that has been created:
action: e3dc_rscp.set_power_mode
device_id: 015b.......
power_mode: "2"
Interestingly enough it does work without errors when I select Normal Operation in the UI power Mode choice.
Potentially my mistake but I can't spot it. Any Ideas anyone?
Thanks a lot!
HACS-E3DC 4.0.0 Beta 1 is here with several new features, among others:
  • Enhanced wallbox energy management support
  • Local authentication now configurable, cloud round-trip for auth no longer needed
  • System status flags like PV derating or emergency power are available.
SG-Ready Sensors include a breaking change, check your automations.
Please provide feedback at:
Hi there!
The integration is working fine.
I have a question regarding additional powermeters.
In my installation of the e3dc one there are:
channel 0 - ROOT
channel 6 - ROOT
This is because of a cascade with my heatingpump.
The problem is that i have to substract channel 6 from channel 0 to get the consumption of my heating pump.
But only one meter is showing in homeassistant. The other one is not recognized.
How to get the second ROOT meter in homeassistant?
    "get_powermeters": [
        "index": 0,
        "type": 6,
        "typeName": "PM_TYPE_UNUSED"
        "index": 6,
        "type": 1,
        "typeName": "PM_TYPE_ROOT"
br
