Hello Torben,
many thanks for the great E3DC integration !!!
Is it possible to set a discharge block for the battery via the integration?
I also have an E3DC S21X home power station and am currently asking myself whether it is possible, for example, if the sun is no longer shining and I have charged my battery via my dynamic tariff, but at some times it is still cheaper to draw the electricity directly from the grid and not to discharge the battery with losses first. Is there a setting here, i.e. if no electricity can be generated via solar, the battery should not be drained. For example, if the dynamic current is at 15 ct for 3 hours and the battery is full, it makes no sense to discharge the battery with losses, but only to draw power directly from the grid. Later, when the grid electricity is more expensive again, the battery is discharged again.
Hey,
did anyone solve this issue? Having the same issue with latest hass version:
2024-10-14 13:20:29.766 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /store/repositories - https://github.com/torbennehmer/hacs-e3dc.git is not a valid add-on repository
Hi all,
thanks for the Kudos, even though I tend to react only slowly (real life, as it is). I really appreciate that! Thanks for using my tool!
E3DC does not give us Today-Sensors for everything, unfortunately. The todays you’ve got are queried from its internal time series database, right now, no other sensors are made available there, directly from E3DC. The only thing you could do is create your own template sensor using the Rieman Integration integration (no typo ;-)), which can sumup such measurements. Doing this ourselves is non-trivial, as we’d have to integrate the values over time as well. This is why I haven’t done it yet.
The difference between “additional” and “additional production” has a similar reason. One of it is a default, nondescript sensor, the other one is directly related to the power meter API. Right now, we provide both. The power meter API is the more sophisticated, but those are - again - not in the internal Time Series DB, so no history. I think in current setups, the old-style sensors are disabled by default, only kept for backwards compatibility.
You may want to use the actions/services to set power limits, as described in the README.md. With them, you can block E3DC from discharging (or even charging, if you’d want that). I am using this approach to prevent E3DC discharging the battery when I’m using cheap grid power from Tibber to charge my car, basically looking something like this (YAML mode, for easier transportation into the forum):
alias: "Wallbox aktiv: S10 Entladung sperren"
description: ""
- type: power
platform: device
device_id: 5410...
entity_id: f8da...
domain: sensor
above: 3.8
for:
hours: 0
minutes: 0
seconds: 10
condition: []
- service: e3dc_rscp.set_power_limits
device_id: b004...
max_discharge: 0
mode: single
To clear the limits again, there is another action to clear the limits, basically:
- service: e3dc_rscp.clear_power_limits
device_id: b004...
Using this approach, you can do just about anything except charging the battery from the grid (manual charging does this, but handle with care, again, check README.md for details).
Can you please file an issue, including HACS/HA debug logs of the attempt.
I’ll check this against current HACS/HA, there has been some change here, which I haven’t validated so far. I’m in the process of upgrading to latest HA, but not yet finished, as there were a number of dev blogs I still have to go through before commiting.
But please create the issue, so you’ll be informed when I’ve got something new there, it also reminds me of testing this. ![]()
Torben
Many Thanks for your feedback, I’ll try and come back.
Another question, is it possible to output the values of the individual solar production trackers 1-3?
What do I have to do for this?
I cant connect correctly to my E3DC.
I get this error: Einrichtungsfehler, wird erneut versucht: Configuration not yet ready: Fatal error when talking to E3DC
Any Idea?
The integration currently does not support this, it would need a code change. PRs are always welcome, please check the GitHub page for that, Thanks!
Without further information, I can’t say anything. Check your debug logs. Please head to our Discussions on GitHub for further discussions, do not open an issue for support requests.
Best bets: Wrong account data or RSCP key.
Torben
I installed the E3DC-Integration (version v3.8.0) for the first time and it seems to work without any problems. This is very important for my home automation projects.
Thank you very much Torben for this great work!
Hi @geohut, thanks for the Kudos, always a pleasure.
Hey Torben,
I´ll get the following Error
2024-11-23 15:28:10.987 DEBUG (SyncWorker_6) [custom_components.e3dc_rscp.e3dc_proxy] Fatal error when talking to E3DC: 11 is not a valid PowermeterType
Hi @Yosberto
Please create an issue at the GitHub page, if the integration allows you to, attach a dignostic dump as well. We might have to test a bit around this, as we are unaware of this powermeter type. Could be, that we’ve to forward this to pye3dc.
Also add all known information to your unit to the issue, as I’m not sure what actual setup you’re using there.
Torben
Just published 3.9.0 with upgraded dependencies to HA 25.1
First of all, many thanks for your work! I could add and configure the integration without any issues.
Up until now, I used the ModBus/TCP communication with the E3DC from here: GitHub - MrIceman11/e3dc-homeassistant: ADD e3dc Data to your HomeAssistant
which is of course read-only. But one difference is, that I could easily configure how often I want the data polled. So I set it to 2 seconds to see almost real-time data. With your integration, I suppose it is set to 10 seconds. Are there any plans to be able to increase that time (at least for some values)?
That’s not too hard to implement, open a feature request in the GitHub. Can’t tell when I get around to it (thus: PRs welcome) as real life has me at the moment, but then it’s recorded on my official todo list, otherwise I fear it’d get lost. Thanks!
Thank you, I created a feature request: Allow configuring the scan interval or increase it by default for some · Issue #222 · torbennehmer/hacs-e3dc · GitHub
Hi all,
I have ED3C S10X with inverter limitation (DC/AC) of 12.000 W and my PV Peak is 17.900 W.
For using the PV Power over 12.000 W I am locking the battery from charging in the morning and midday all over 12.000 W will be used autom. to charge the battery while battery is locked.
I would like to handle this process with HA but I am missing a functionality to lock and unlock the battery from charging.
Is it possible to implement a service for locking and unlocking the battery?
power limit will not archive this.
Many thanks!
BR
Steve
Hi!
I have a problem with the initial configuration. When I enter my access data, I immediately get “Invalid authentication”. I have tried both a hostname and the corresponding IP for Host. I have also checked the other access data several times and everything is correct. As a further test, I also installed RSCPgui and used the same access data there and it works straight away. As a further test, I called the bash in the Docker and sent a ping from there to the E3DC-S10 and got a response and also sent a ping to my.e3dc.com and also got a response.
Where is the error?
I would be very grateful for any help.
Greetings
Info:
- E3DC Remote Storage Control Protocol (Git) v3.9.0
- Core 2025.2.5
- Supervisor 2025.02.1
- Operating System
- Frontend 20250221.0
Hi @Roemer,
thanks, I can’t tell when I get around to it, but I’ll see what I can do. The biggest thing here is that we’ll need a configuration interface for that, which the integration does not have yet. Adapting the polling interval isn’t hard in itself.
Hi @Steve-1122, let’s continue the discussion in the GitHub Forum in your thread at lock battery from charging to use PV over 12.000 W via DC/DC to charge battery · torbennehmer/hacs-e3dc · Discussion #223 · GitHub.
Hi @count0,
Generally, what has to work is the direct communication between HA and E3DC. my.e3dc.com is not used by the integration. Ensure that Username, Password AND the RSCP key are correct. Please check the README section about known connection problems as well, there are a few things to be aware of.
If this does not help, please head to my GitHub discussion pages and add debugging logs there, discussion is easier there as in this long thread.
Hello Troben, can you explain where i can change the port for the rscp parameters because I use a farm and have to change the port to 5034 , so I get the complete parameters like pv production an kph grid…thx for a little info greetings meik from Bavaria
Right now, the integration does not expose this part of the configuration, there is an open issue for that:
I don’t have a timeline on this issue, nevertheless you may want to subscribe to it.
Hallo Torben, kannst Du mir sagen warum das nicht bei der e3dc Farm geht, die hat nur einen anderen Port 5034, darüber erhält man die Summendaten der Farm Teilnehmer, aktuell sehe ich aber nur den einzelwert, somit muss man 2 Systeme anlegen und Werte rechnen? Oder mache ich da was falsch ? Hab den rscp bei iobroker laufen da kommen über 5034 die Farmwerte .
Danke Dir für eine kurze RI, sorry bin in dem Thema nur Anwender …![]()
