Is there an easy way to add all devices to the energy monitoring dashboard’s " Individual devices" section? or a way to flip it from a whitelist to a blacklist?
for SENSOR in $(find /path/to/homeassistant/configdir/ -type f -print0 | xargs -0 egrep "entity_id.*sensor.*_energy\"" | awk '{ print $3 }' | cut -d \" -f 2 | grep -v "battery" | sort | uniq); do
echo " {";
echo " \"stat_consumption\": \"$SENSOR\"";
echo " },";
done
paste that into the device_consumption
key in /path/to/homeassistant/configdir/.storage/energy
, make sure you didn’t add any sensors you don’t want to be tracked in energy dashboard and restart home assistant.
Is it dirty? Absolutely. Does it save you hours of work? Absolutely.
If you regularly update the file that way, I’d suggest managing your config in Git or at least doing regular backups.
Or put this into developer template, copy all then use some find and replace, to add the proper code
{{ states | selectattr('entity_id', 'search', '_energy') | rejectattr('entity_id', 'search', '_cost') | map(attribute='entity_id') | sort | join('\n') }}
I hereby state this as a feature request, having whitelisting (by default: all supporting devices) and blacklisting (specific ones to exclude) for the energy dashboard´s devices. Please join me by voting for it
Has this been officially turned into a feature request? If so can you point me where I should upvote it?
It was not yet but here you are
