Once 2FA is removed, logon back on to the consumer portal you already have before.
On your Profile Tab - You will have new ‘DEVELOPER’ section.
However… from there you need to create a ‘Fake Application Name.’
The reason is, this is how the API is generated.
Creating Application - I assumed if I chose the PIN metod, Users will be asked to authorize the application by entering a PIN code generated by ecobee. This seemed better than OATH.
STUCK - I successfully generated the app, using PIN, and that created the API.
I then place the API in Home Automation for the ecobee integration. and I get this:
Authorize app on ecobee
Please authorize this app at safwith PIN code: (CODE IS HERE)
Then, press Submit.
Then go back to your ecobee… application or My Applications…
Select NEW APP
and Paste the PIN Code in from HA.
