Ecobee "local" - HA not seeing thermostat (Solved)
I was looking at this thread - Ecobee Dumped Developer Accounts
I didn’t want to add to it as it was marked as solved. I had a valid API key and it stopped working at some point. I have an ecobee3 and it indeed has homekit in the settings menus so I should be good…
Now I am not in the Apple ecosystem, my daughter has an iPhone but that is all, no hubs, iPads, whatever. I am looking at the HA Ecobee documentation and it says to use homekit, looks super easy, says my device should be waiting to setup. Not the case.
I am seeing conflicting information and it seems to be implied that anytime homekit is mentioned, the user knows they need a hub or that a hub is involved? I don’t get that impression reading the above thread.
I will mention that my HA install is on the same network as the thermostat and there are no firewalls or vlans going on. I purchased the Ecobee because it had API access and HA integration, and then they took it away. I relied heavily on the data it provided and 6 months without it I’m getting really bothered.
My HA install and Ecobee is up to date, there should be nothing in the way unless I actually need a hub to make it work. Should I start with wireshark and see if my unit is broadcasting mDNS or is the documentation lacking/making assumptions? I’d love to get this data back again.
Thanks!
I finally figured this out. If anyone else happens to be stuck and confused here is what I did. On the thermostat itself I went to the settings and pulled up the homekit pairing code, leave this up. I then had to do a full restart of HA, then head over to integrations add homekit device and there it was. I have tried this many times before but without restarting HA. I put in the code displayed on the thermostat (no dashes) and hit ok. Instantly the thermostat went back to standby and it was added. I had to confirm zones for the thermostat and sensors.
This works to get it integrated into Home Assistant (shows up as a HomeKit device in the HomeAssistant list of device and integrates as a thermostat - GREAT!). However, it removed it from my HomeKit app on my iPhone. Any idea how to get it integrated into both?
You cannot. I looked into this. You’ll need to add the device to your Home in iOS by adding it to your HomeKit Bridge from HA.
I know it’s an older post, but I’m unsure what to do. I have an ecobee 3. I can’t get it to be found in HA. I have rebooted my ecobee. I have put it into pairing mode. I have rebooted HA. But it never seems to be found. Any advice how what is going on and why it is not found?
I do not have any Apple devices and never have. So the ecobee has never been paired with any Apple HomeKit.
Thanks in advance for any assistance
