I bought mine in Germany and this shop still has some (according to the website) - send me a PM if you want the link.
I sold mine in favor of a cheaper solution: I use a (used) Mediola v4 gateway to control Elero blinds. The integration into Home Assistant is done with mediola2mqtt (I’m the author of mediola2mqtt).
As far as I understand it is the successor of the Fibaro systems, so really quite similar.
Will be interested if it can be integrated into Home Assistant.
Yubii (by NICE) = Fibaro + Elero,
NICE bought Elero and already owned Fibaro and now creates a new system that can integrate both…
Recently I got 4 Elero bidirectional shutters that I’d like to integrate in HA. I’ve found the Elero Centero USB stick on a German store, however I was wondering if I should buy a mediola A.I.O Gateway V5 instead. What are pros and cons of them? What would you do for my use case?
With the Elero transmitter, you get better position feedback. The Mediola is not constantly on receive, so the state of the shutters is wrong if you use another remote. For me, this is not an issue because I do not use other remotes. From the software side, setting up the mediola implementation might require some more work, depending on how you run Home Assistant.
I got the Elero USB stick and I was able to integrate it, however I’m experiencing a weird behavior in the sense that the commands sometimes lag. It takes a few seconds for the cover to react after I’ve executed the action in HA.
Hello, I’m also experiencing delay, however my stick is brand new (or at least I hope so), moreover if I control the cover from the buttons on the stick it works fine. What else could I try to solve the issue?
Update
I believe I’ve found the cause of the issue. Basically in the configuration.yaml file I configured 4 channels, however I only had 1 channel bound in my stick. I’ve now commented the non-bound 3 channels and the integration started working fine!
My elero blinds are on the first floor. What should I use to get them into Iobroker?
Raspberry PI with HAS in the first floor and Elero USB Transmitter
mediola2mqtt with Mediola AIO Gateway v4? As far as I understand could I install this mediola2mqtt tool into a proxmox container and linkt the signals from the Mediola box direktly by mqtt to iobroker?
I have just started with HASS and therefore iobroker is needed at the moment until I have completely switched to HASS
Update: I ordered a Mediola V4 Gateway and will try mediola2mqtt
Hi all - first many thanks to @istvan.szirtes and the other contributors for the excellent work.
I have an issue on my configuration which I don’t know how to solve.
I have two types of covers: venetian blinds and roller shutter.
On my configuration, when I call cover.open_cover_tilt:
the venetian blind moves to ventilation/tilt state
Having a backup would definitely be a smart idea. Do you know which Mediola product would potentially work with Elero? Can you share a link or exact product name?
Nearly all, IIRC. I have a Mediola v4 and a v4+, the v5 and v6 should also work. I don’t like it and use it for Elero only, but they can be found for 20 Euro second-hand (the v4).
first of all thanks to @istvan.szirtes for the really great work! But now my problem. I know this should be resolved because i found a closed issue but i have a really similar issue. When i press “up”, “down” or whatever, sometimes the shutters need some seconds (4-5) until they get the command and start moving.
This is not all the Time. Sometimes the shutter is getting the command immediatelly. (more or less) I used FHEM before with the same Stick (original Elero Transmitter Stick) and it worked really good without any delays in sending commands.
So my question would be if there is any kind of “sleep” or “timeout” after sending a command until the next can be send? Or other question. Does anyone have the same experience and/or a solution for that?
