Back to 0.91.3, no trouble with Alexa but now my Amcrest camera switch has been deprecated. Something else to work on.
Testing is easier said than done, often things like this will pass the automated tests, then get merged without any complaints.
It’s not until it actually gets used by a few people that bugs like these are found, I’m glad new versions are released frequently, so usually bugs like this are patched pretty quickly.
I wouldn’t recommend mixing python files from different versions, while it may work now it could lead to issues later on.
Yes, I understand it passing automated tests, I am more speaking of the code itself not being tested in the real world before making the commit, to ensure it actually works as intended.
In this particular case, this wasn’t a significant change that had to be made (from what I can tell) to ensure the device continued to work, it was an adjustment to provide additional functionality. It wasn’t time sensitive, so could have been real world tested before being merged.
Again, not an attack, just an observation. Perhaps I am wrong in my observation.
This is the nature of the beast. I’ve working in software for 10+ years. It’s impossible to test for all scenarios and intermittent issues will always surface. You also have to remember that emulated hue isn’t just for alexa, it’s to emulate a hue bridge and in regards to testing, it works perfectly. The gets and sets place the correct information in all places and the API works as expected. The interface with Alexa doesn’t need to check to see if the information was set, but it does. That’s all on the alexa side and that is one application out of 100s of possible applications.
I can also confirm the ‘fix’ is working! thanks!
The switches are indeed working, but input_booleans don’t appear to be. They work in 91.4 but not after that as best I can tell. I’ve tried 0.92.2, 0.93.1 and 0.93.2. With the rather limited testing I’ve done Alexa is unable to turn on input_booleans in any of these recent updates.
That’s because you aren’t using the fix listed in this thread. The fix has not been merged in any version yet. Apply the fix in the thread and you won’t get the messages. I’m assuming the fix will be added soon.
By the looks of it this fix should be in 0.93.2
Nope, at least not in the container on docker hub for 0.93.2…
Yep, looks like it will be 0.94.0
Confirmed. Fixed in 0.94.0
I beg to differ…I have upgraded to 0.94 and still have the same issue…
Using Sonoff Plugs with Tasmota 6.1.1c…They all work controlled directly from HassIO but with emulated hue and Alexa I get very strange results
For my setup the issue is fixed with 0.94:
Zigbee / deConz switch Osram smart plug.
Confirmed working for me, Docker on Ubuntu. No issues as yet using a variety of Osram, MQTT, WeMo and Xiaomi products.
But are your strange results what this thread is about? Or are they completely unrelated?
Well the fact they don’t switch on correctly and I guess they must be
Yeah, unrelated. This thread is about them alexa falsely saying that the light is not responding when it in fact does respond. Please ask your question in new post tagging your hardware and your issue.
I get that too. I have flagged a new post about my issue but no response yet…
https://community.home-assistant.io/t/alexa-and-hassio-control-problem/120312
Works fine after upgrade for me
Is there a database in emulated hue that i can reset
