Since I updated to 0.61, my Emulated Hue config does not work anymore. While I can see the devices in http://:8300/api/pi/lights , Alexa claims she can’t reach any of them. Removing a device and re-discovering it in the Alexa App did not help.
Looking at the release notes of 0.61, there’s a breaking change - config of devices for Alexa moving from customize to the cloud component. But the Emulated Hue page still refers to customize - which of the two is correct?
But no change, Alexa is completely disconnected from my HASS setup. In the meantime I upgraded to 0.62.1, but that also didn’t fix it. Nothing helpful in home-assistant.log either. I’m clueless…
There wasn’t any change to emulated_hue, you read it wrong and everything works just as before. The change was quite rightly to Alexa which refers to the Smart Home Skill.
Is emulated hue somehow storing the IP address of one Alexa device?
I had replaced my main Echo device (a Dot) with an Echo Spot and after that none of my various Echos could reach HASS. Once powering up the Dot again, it works (on all Echos), but taking it down, none of the Echos can reach HASS.
At the same time, Alexa can control my Philips Hue bridge / devices, independently of the Echo Dot being powered on. HASS seems to depend on that Echo Dot device being active, while other smart home devices don’t. Any ideas how to resolve that?
I tried re-booting HASS, all Echos, searched config files for the IP of that Echo Dot (none), nothing helped.
I believe the consensus was that echo hardware and correlating firmware versions, beginning with the spot, are implementing newer versions of the hue API, which are not supported by emulated_hue.
On a RPi, Python software (i.e HA) is not allowed to use port 80. You can configure it but it will not be able to use it.
If you connect to the RPi by using ssh and run the command
Just had a thought on this, may well be irrelevant but…
I use the Kodi component and wanted to use websockets but it didn’t work using 8080. I set it to use port 80 and it works perfectly with no extra command needed. I’m using hassio if that makes a difference.
That’s interesting. I’m also using hassio, and afaik I can’t run any sudo commands on that - right? (It definitely doesn’t work when simply logging in through ssh)
Not sure if I now should start setting up Kodi… sounds like overkill just to get that port “unlocked”.
Interesting… I have connected now an Echo Dot (2nd Gen) which I bought from a friend today afternoon and when the configuration was finished, I saw all of my devices now… very strange…
FWIW, I have a second gen Echo Dot and it stopped working with emulated_hue around November 2016.
@Klaus, may not be worth your time trying to bind to port 80 and set permissions to allow non-root processes to bind there. Your best long term solution may end up being Home Assistant Cloud, or Haaska if you don’t want to pay the monthly fee.
