Check this example:
type: custom:auto-entities
card:
type: entities
filter:
include:
- entity_id: "switch.*"
options:
card_mod:
style:
hui-generic-entity-row ha-entity-toggle $:
ha-switch $: |
.mdc-switch .mdc-switch__thumb input {
{% if config.entity is search('wol') %}
pointer-events: none;
ha-switch {
--switch-unchecked-button-color: var(--disabled-text-color);
--switch-checked-button-color: var(--disabled-text-color);
sort:
method: name
Assume there are many filters - for “switch”, “automation”, “input_boolean” etc.
And you need to disable one particular switch.
So you need to specify a style for a corresponding filter.
As a result - the “switch.wol_iiyama” is DISABLED.
In your own case - since you need to disable a “Kühlschrank plug”, specify a style for a “plug” filter with a “is search(‘kühlschrank’)” condition - if this word is a part of “entity_id”.
