Enbrighten Z-Wave Light Switch Mutli Clicks
Description
This blueprint allows the configuration of one, two and three click events for Z-Wave enabled Enlighten Light Switches. Each on and off tap sequences allow you to choose a unique set of actions allowing for up to six total (including both on and off clicks).
Requirements
  • Z-Wave-JS
  • Enbrighten Z-Wave Light Switch
Installation
Click the below button to install the blueprint.
Or import the code into a new file in the blueprints file.
blueprint:
  name: Enbrighten Z-Wave Switch Tap Events
  description: Handle single, double and triple taps for Enlighten light switches.
  domain: automation
  input:
    device:
      description: Enlighten Switch that supports multi taps.
      selector:
        device:
          integration: zwave_js
          manufacturer: Enbrighten
          entity:
            domain: light
    single_tap_on:
      name: Single Tap On
      description: Action(s) performed when on is clicked a single time. (light switch turns on by default)
      default: []
      selector:
        action: {}
    single_tap_off:
      name: Single Tap Off
      description: Action(s) performed when off is clicked a single time. (light switch turns off by default)
      default: []
      selector:
        action: {}
    double_tap_on:
      name: Double Tap On
      description: Action(s) performed when on is clicked a two times. (light switch DOES NOT turn on by default)
      default: []
      selector:
        action: {}
    double_tap_off:
      name: Double Tap Off
      description: Action(s) performed when off is clicked a two times. (light switch DOES NOT turn off by default)
      default: []
      selector:
        action: {}
    triple_tap_on:
      name: Triple Tap On
      description: Action(s) performed when on is clicked a three times. (light switch DOES NOT turn on by default)
      default: []
      selector:
        action: {}
    triple_tap_off:
      name: Triple Tap Off
      description: Action(s) performed when off is clicked a three times. (light switch DOES NOT turn off by default)
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
  platform: event
  event_type: zwave_js_value_notification
  event_data:
    device_id: !input "device"
    command_class: 91
  - variables:
      value_raw: "{{ trigger.event.data.value_raw }}"
      property_key: "{{ trigger.event.data.property_key }}"
  - choose:
      - conditions: '{{ property_key ==  "001" }}'
        sequence:
          - choose:
              - conditions: "{{ value_raw ==  0 }}"
                sequence: !input "single_tap_on"
              - conditions: "{{ value_raw ==  3 }}"
                sequence: !input "double_tap_on"
              - conditions: "{{ value_raw == 4}}"
                sequence: !input "triple_tap_on"
      - conditions: '{{ property_key ==  "002" }}'
        sequence:
          - choose:
                sequence: !input "single_tap_off"
                sequence: !input "double_tap_off"
              - conditions: "{{ value_raw ==  4 }}"
                sequence: !input "triple_tap_off"
Credit
Thank you to @freshcoast for their work on ZWave-JS - GE/Jasco Double Taps blueprint. I used their blueprint for quite a while and used it as a base for this blueprint to learn a bit more about events.
Can this also work for a switch with the manufacturer value of “GE/Enbrighten”? It’s the “neutral-required” version of the switch. Model: GE 46201
