These are two blueprints that allow creating automations around the GE double-tap functionality. In zwave-js, these switches are automatically configured to respond to double tap events, so all it takes is using these blueprints.
In both blueprints the manufacturer is filtered to “GE/Jasco”. If you have a Honeywell switch which supports the same functionality, you’ll want to change the filter or remove it.
The first blueprint allows defining any generic set of actions for each double tap operation.
The second blueprint is a specialization for auto-dimming a light entity. I configure all of my GE switches to set their connected load to 100% brightness on double-tap on, and 25% brightness on double tap off. The blueprint allows setting a configurable brightness for each tap. Due to a limitation with blueprints, it cannot automatically select the trigger device as a target, instead a light entity must be chosen (in my case the entity associated with the device).
Generic Blueprint
Import URL: https://gist.github.com/kpine/65e6324a0e6a9d48f9f50f77310ecd7f
blueprint:
name: GE Switch Double Taps
description: Create automations to react to double taps from supporting GE switches.
domain: automation
input:
device:
description: A GE switch that supports double taps.
selector:
device:
integration: zwave_js
manufacturer: GE/Jasco
double_tap_on:
name: Double Tap On
description: Actions to run for a double tap on.
default: []
selector:
double_tap_off:
name: Double Tap Off
description: Actions to run for a double tap off.
default: []
selector:
mode: single
max_exceeded: silent
platform: event
event_type: zwave_js_event
event_data:
device_id: !input device
command_class: 32 # Basic
- variables:
value: "{{ trigger.event.data.value }}"
- choose:
- conditions: "{{ value == 0 }}"
sequence: !input double_tap_off
- conditions: "{{ value == 255 }}"
sequence: !input double_tap_on
Auto-dimming Blueprint
Import URL: https://gist.github.com/kpine/b9a195088098090002cb4999678965c1
blueprint:
name: GE Light Switch Double Taps with Auto Brightness
description: Auto-dim GE light switches that support double taps.
domain: automation
input:
device:
name: Light Switch Device
description: A GE light switch that supports double taps.
selector:
device:
entity:
domain: light
light:
description: The light entity to auto-dim, usually the entity associated with the device.
selector:
entity:
domain: light
off_brightness:
name: Off Brightness
description: The brightness to set for a double tap off.
default: 25
selector:
number:
min: 0
max: 100
unit_of_measurement: "%"
mode: slider
on_brightness:
name: On Brightness
description: The brightness to set for a double tap on.
default: 100
selector:
number:
min: 0
max: 100
mode: slider
mode: single
platform: event
event_data:
- variables:
- choose:
sequence:
- service: light.turn_on
entity_id: !input light
brightness_pct: !input off_brightness
sequence:
brightness_pct: !input on_brightness
