[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
Thank you. Where could I find more information about your mentioned python library?
Google is your friend!
https://www.google.com/search?q=pjsip+python+hassio
Hi guys!
First of all thanks to @sdesalve for the addon and, moreover, for the great supporto here.
I tried to setup the environment and to read the whole topic, but I don’t understand how to call the service to make a phone call to my mobile or if it is possible.
I’m using a Fritz, I’ve configured the IP phone on the interface and I’ve configured the addon and the tts (Picotts).
Just created a test script… but… What should I write as call_sip_uri for a mobile phone number?
Here the log of the addon generated after my first test
[Info] Starting addon...
PJSUA_CUSTOM_OPTIONS = '--ip-addr=192.168.1.10'
PLATFORM_TTS = 'picotts'
[Info] Listening for messages via stdin service call...
[Info] Received messages {"call_sip_uri":"sip:[email protected]:5060","message_tts":"Ciao Sono Io!"}
Converting audio file 'http://192.168.1.10:8123/api/tts_proxy/aebc66490ae73df55e0d940189d10acab54a38d6_it-it_-_picotts.mp3'...
Audio succesfully converted...
Starting SIP Client and calling 'sip:[email protected]:5060'...
This call will be terminated after '50' seconds.
16:04:47.707         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
16:04:47.707         sip_endpoint.c  .Creating endpoint instance...
16:04:47.707                  pjlib  .select() I/O Queue created (0x7fa2292100)
16:04:47.707         sip_endpoint.c  .Module "mod-msg-print" registered
16:04:47.707        sip_transport.c  .Transport manager created.
16:04:47.707           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
16:04:47.718           pjsua_core.c  .pjsua version 2.11.1 for Linux-6.1.63/aarch64 initialized
16:04:47.718            pjsua_app.c  .Turning sound device -99 -99 ON
16:04:47.718                 main.c  Ready: Success
16:04:47.719            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
  [ 0] <sip:192.168.1.10:5060>: does not register
       Online status: Online
  [ 1] <sip:192.168.1.10:5060;transport=TCP>: does not register
 *[ 2] sip:**[email protected]:5060: does not register
Buddy list:
 [ 1] <?>  sip:[email protected]:5060
|       Call Commands:         |   Buddy, IM & Presence:  |     Account:      |
|  m  Make new call            | +b  Add new buddy       .| +a  Add new accnt |
|  M  Make multiple calls      | -b  Delete buddy         | -a  Delete accnt. |
|  a  Answer call              |  i  Send IM              | !a  Modify accnt. |
|  h  Hangup call  (ha=all)    |  s  Subscribe presence   | rr  (Re-)register |
|  H  Hold call                |  u  Unsubscribe presence | ru  Unregister    |
|  v  re-inVite (release hold) |  t  ToGgle Online status |  >  Cycle next ac.|
|  U  send UPDATE              |  T  Set online status    |  <  Cycle prev ac.|
| ],[ Select next/prev call    +--------------------------+-------------------+
|  x  Xfer call                |      Media Commands:     |  Status & Config: |
|  X  Xfer with Replaces       |                          |                   |
|  #  Send RFC 2833 DTMF       | cl  List ports           |  d  Dump status   |
|  *  Send DTMF with INFO      | cc  Connect port         | dd  Dump detailed |
| dq  Dump curr. call quality  | cd  Disconnect port      | dc  Dump config   |
|                              |  V  Adjust audio Volume  |  f  Save config   |
|  S  Send arbitrary REQUEST   | Cp  Codec priorities     |                   |
|  q  QUIT   L  ReLoad   sleep MS   echo [0|1|txt]     n: detect NAT type     |
You have 1 active call
Current call id=0 to sip:[email protected]:5060 [CALLING]
>>> 16:04:48.718            pjsua_app.c  .Turning sound device -99 -99 OFF
16:05:19.719            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
No current call
>>> 16:05:39.225                timer.c  .Dumping timer heap:
16:05:39.225                timer.c  .  Cur size: 0 entries, max: 3070
[Info] Call ended...
add
--no-tcp
Is your Fritz box’s IP 192.168.1.1?
please post here your config and your script…
Yes, 192.168.1.1 is the fritz and 10 is the rasp.
Here the addon config (after your suggestion for --no-tcp):
sip_parameters:
  caller_id_uri: sip:**[email protected]:5060
  realm: "*"
  username: user
  password: passUser
pjsua_custom_options: "--ip-addr=192.168.1.10 --no-tcp"
platform_tts: picotts
I tried also to replace **620 with username
Here the script:
test_chiamata:
  alias: Test_Chiamata
  sequence:
  - service: hassio.addon_stdin
      addon: 89275b70_dss_voip
      input:
        call_sip_uri: "sip:[email protected]:5060"
        message_tts: "Ciao Sono io"
  mode: single
  icon: mdi:cellphone
Have you used _ARM version? Can you try to switch beetween ARM version/standard version?
Hi @sdesalve,
thanks for the addon. I’m having issues with setting it up for my FritzBox.
After I start the addon and execute the service call, the addon stops before the call is started.
Im running hassio on a Raspberry Pi 4 and am using the ARM version of the addon. Fritzbox VoIP call filters are deactivated and I have setup an internal phone number for home assistant.
IP FritzBox: 192.168.178.1
IP Raspberry: 192.168.178.69
Addon config:
sip_parameters:
  caller_id_uri: sip:[email protected]:5060
  realm: "*"
  username: homeassistant
  password: xxxxx
pjsua_custom_options: "--ip-addr=192.168.178.69 --no-tcp"
Service call:
  addon: 89275b70_dss_voiparm
  input:
    call_sip_uri: "sip:**[email protected]:5060"
    audio_file_url: "http:192.168.178.69:8123/local/notification.mp3"
Addon logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: DSS VoIP Notifier for ARM
 VoIP Notifier for Home Assistant (for ARM processors)
 Add-on version: 4.1.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.5  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2024.2.1
 Home Assistant Supervisor: 2024.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
PJSUA_CUSTOM_OPTIONS = '--ip-addr=192.168.178.69 --no-tcp'
[Info] Received messages {"call_sip_uri":"sip:**[email protected]:5060","audio_file_url":"http:192.168.178.69:8123/local/notification.mp3"}
Converting audio file 'http:192.168.178.69:8123/local/notification.mp3'...
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
**622 is the internal number I am trying to call. I have also tried with external phone numbers. The audio file url also works when opening it in a browser.
The SIP user and password are also correct. When I have tried with the sip_server_uri option, I was able to call the call the internal number of the addon to hear the confirmation message that it is running.
Anything else I can try? Thank you!
@sdesalve , no I’m using the standard version not the arm… If you want, I can switch.
there is some issue with your TTS config…
please check your configuration.yaml
yes please…
@sdesalve Almost the same log also with ARM version
21:30:52.501         os_core_unix.c !pjlib 2.9 for POSIX initialized
21:30:52.501         sip_endpoint.c  .Creating endpoint instance...
21:30:52.502                  pjlib  .select() I/O Queue created (0x557d40dc90)
21:30:52.502         sip_endpoint.c  .Module "mod-msg-print" registered
21:30:52.502        sip_transport.c  .Transport manager created.
21:30:52.502           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
21:30:52.511           pjsua_core.c  .pjsua version 2.9 for Linux-6.1.63/aarch64 initialized
21:30:52.511            pjsua_app.c  .Turning sound device -99 -99 ON
21:30:52.511                 main.c  Ready: Success
21:30:52.511            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
 *[ 1] sip:**[email protected]:5060: does not register
Buddy list:
>>> 21:30:53.511            pjsua_app.c  .Turning sound device -99 -99 OFF
21:31:24.511            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
21:31:24.511     pjsua_app_common.c  ....
  [DISCONNCTD] To: sip:[email protected]
    Call time: 00h:00m:00s, 1st res in 32000 ms, conn in 0ms
No current call
P.S. it’s a rasp 5, but I don’t if it could be the problem
you have a typo!!!
http:**//**192.168.178.69:8123/local/notification.mp3
Nothing to do… I see the request sniffing the traffic on my fritz, but same error. @sdesalve any idea?
Could be useful to analyze the sniffing log of the fritz?
Seems that your config it’s not correct
sip_parameters:
  realm: "*"
  username: user
  password: passUser
Also
I don’t know how, but the call is started… The only change I did is to increase the lenght of the username…
The problem now is that the call says wrong thing, It seems an error of the text To speech.
@sdesalve Here the new log:
PJSUA_CUSTOM_OPTIONS = '--ip-addr=192.168.1.10 --no-tcp'
[Info] Received messages {"call_sip_uri":"sip:[email protected]:5060","message_tts":"Ciao Sono Io"}
21:59:25.986         os_core_unix.c !pjlib 2.9 for POSIX initialized
21:59:25.986         sip_endpoint.c  .Creating endpoint instance...
21:59:25.987                  pjlib  .select() I/O Queue created (0x55be111c90)
21:59:25.987         sip_endpoint.c  .Module "mod-msg-print" registered
21:59:25.987        sip_transport.c  .Transport manager created.
21:59:25.987           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
21:59:25.996           pjsua_core.c  .pjsua version 2.9 for Linux-6.1.63/aarch64 initialized
21:59:25.996            pjsua_app.c  .Turning sound device -99 -99 ON
21:59:25.996                 main.c  Ready: Success
21:59:25.996            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
 *[ 1] sip:[email protected]:5060: does not register
Buddy list:
>>> 21:59:26.006        tsx0x55be161aa8  .......Temporary failure in sending Request msg INVITE/cseq=2406 (tdta0x55be158da8), will try next server: Unsupported transport (PJSIP_EUNSUPTRANSPORT)
21:59:26.038            pjsua_app.c  .....Call 0 state changed to EARLY (183 Session Progress)
21:59:37.747            pjsua_app.c  .....Call 0 state changed to CONNECTING
21:59:37.748            pjsua_app.c  .....Call 0 state changed to CONFIRMED
>>> 22:00:15.982            pjsua_app.c  .....Call 0 is DISCONNECTED [reason=200 (Normal call clearing)]
22:00:15.983     pjsua_app_common.c  .....
  [DISCONNCTD] To: sip:[email protected];tag=B8BDA82DABEF8ACE
    Call time: 00h:00m:38s, 1st res in 42 ms, conn in 11752ms
    #0 audio iLBC @8kHz, sendrecv, peer=192.168.1.1:7078
       SRTP status: Not active Crypto-suite:
       RX pt=104, last update:00h:00m:03.945s ago
          total 963pkt 48.1KB (86.6KB +IP hdr) @avg=10.0Kbps/18.1Kbps
          pkt loss=0 (0.0%), discrd=0 (0.0%), dup=0 (0.0%), reord=0 (0.0%)
                (msec)    min     avg     max     last    dev
          loss period:   0.000   0.000   0.000   0.000   0.000
          jitter     :   0.000   1.858   2.000   1.875   0.175
       TX pt=104, ptime=30, last update:00h:00m:10.852s ago
          total 1.0Kpkt 53.1KB (95.6KB +IP hdr) @avg=11.1Kbps/20.0Kbps
          pkt loss=0 (0.0%), dup=0 (0.0%), reorder=0 (0.0%)
          jitter     :   8.125   9.725  10.125  10.125   0.800
       RTT msec      :   0.732   0.835   0.885   0.732   0.062
22:00:16.983            pjsua_app.c  ..Turning sound device -99 -99 OFF
anyway, the configuration seems not stable. 10 tests, 5 failures
>>> 22:43:17.727        tsx0x55a2833aa8  .......Temporary failure in sending Request msg INVITE/cseq=21347 (tdta0x55a282ada8), will try next server: Unsupported transport (PJSIP_EUNSUPTRANSPORT)
22:43:17.756            pjsua_app.c  .....Call 0 state changed to EARLY (183 Session Progress)
>>> 22:44:07.706            pjsua_app.c  .....Call 0 is DISCONNECTED [reason=487 (Request Terminated)]
22:44:07.706     pjsua_app_common.c  .....
and I have to restart the component
Try Google TTS
On NUC it run well.
raspy has less computational power
I don’t know if that is the problem. Monitoring the resouces, the CPU never exceeds 5% and RAM is lower than 2Gb of 8 available…
