[END OF LIFE - ABANDONED - DISMISSED] DSS VoIP Notifier
Great add on !
Work perfectly with HA 2024.3 + nuc + remote 3cx
Do I understand correctly the message will just keep looping? No way to get it just to play once when the call is answered?
(Why? Because I was hoping to use this with intercom/paging)
yes but you can set this
https://github.com/sdesalve/hassio-addons/tree/master/dss_voip#option-max_call_time-optional
or this
https://github.com/sdesalve/hassio-addons/tree/master/dss_voip#option-call_duration-optional
I have problem with my dss voip notifier arm
[Info] Received messages {"call_sip_uri":"sip:[email protected]","message_tts":"abc"}
Converting audio file 'http://192.168.178.36:8123/api/tts_proxy/a9993e364706816aba3e25717850c26c9cd0d89d_it_-_google_translate.mp3'...
Audio succesfully converted...
Starting SIP Client and calling 'sip:[email protected]'...
This call will be terminated after '50' seconds.
20:45:59.672         os_core_unix.c !pjlib 2.9 for POSIX initialized
20:45:59.676         sip_endpoint.c  .Creating endpoint instance...
20:45:59.677                  pjlib  .select() I/O Queue created (0x55b0dc1c90)
20:45:59.677         sip_endpoint.c  .Module "mod-msg-print" registered
20:45:59.677        sip_transport.c  .Transport manager created.
20:45:59.677           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
20:45:59.722           pjsua_core.c  .pjsua version 2.9 for Linux-6.1.73/aarch64 initialized
20:45:59.726            pjsua_app.c  .Turning sound device -99 -99 ON
20:45:59.727                 main.c  Ready: Success
20:45:59.740            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
  [ 0] <sip:192.168.178.36:5060>: does not register
       Online status: Online
  [ 1] <sip:192.168.178.36:5060;transport=TCP>: does not register
 *[ 2] sip:**[email protected]: does not register
Buddy list:
 [ 1] <?>  sip:[email protected]
|       Call Commands:         |   Buddy, IM & Presence:  |     Account:      |
|  m  Make new call            | +b  Add new buddy       .| +a  Add new accnt |
|  M  Make multiple calls      | -b  Delete buddy         | -a  Delete accnt. |
|  a  Answer call              |  i  Send IM              | !a  Modify accnt. |
|  h  Hangup call  (ha=all)    |  s  Subscribe presence   | rr  (Re-)register |
|  H  Hold call                |  u  Unsubscribe presence | ru  Unregister    |
|  v  re-inVite (release hold) |  t  ToGgle Online status |  >  Cycle next ac.|
|  U  send UPDATE              |  T  Set online status    |  <  Cycle prev ac.|
| ],[ Select next/prev call    +--------------------------+-------------------+
|  x  Xfer call                |      Media Commands:     |  Status & Config: |
|  X  Xfer with Replaces       |                          |                   |
|  #  Send RFC 2833 DTMF       | cl  List ports           |  d  Dump status   |
|  *  Send DTMF with INFO      | cc  Connect port         | dd  Dump detailed |
| dq  Dump curr. call quality  | cd  Disconnect port      | dc  Dump config   |
|                              |  V  Adjust audio Volume  |  f  Save config   |
|  S  Send arbitrary REQUEST   | Cp  Codec priorities     |                   |
|  q  QUIT   L  ReLoad   sleep MS   echo [0|1|txt]     n: detect NAT type     |
You have 1 active call
Current call id=0 to sip:[email protected] [CALLING]
>>> 20:46:00.726            pjsua_app.c  .Turning sound device -99 -99 OFF
20:46:31.740            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
20:46:31.740     pjsua_app_common.c  ....
  [DISCONNCTD] To: sip:[email protected]
    Call time: 00h:00m:00s, 1st res in 32013 ms, conn in 0ms
No current call
[Info] Call ended...
[Info] Listening for messages via stdin service call...
Full addon log?
Addon config?
Have you disabled Fritz VoIP filter?
You are italian? My english languagebits vwry bad :stuck_out_tongue_closed_eyes:
sip_parameters:
  caller_id_uri: sip:**[email protected]
  realm: "*"
  username: myuser
  password: mypsw
pjsua_custom_options: "--ip-addr=192.168.178.36"
Mine It’s worst… :sweat_smile:
But here we need to write in English
(At least, I try to write something that seems English…)
Ok useró google translate:
I configured the addon and script as indicated in the guide.
I think the problem is in the router, but I don’t receive the call on my smartphone.
I created a voip number on fritzbox with username and password but nothing happens. What can it be? Would you be kind to help me?
I would like to use your service to notify me that the house alarm goes off.
Do you have a telegram contact where you can help me so I can solve the problem and then post the solution on the forum?
My telegram contact is @PakyITA
Please check private messages inbox
Setting -1 for max_call_time did the trick! :smiley:
Thanks for this, my supervisor watchdog keeps finding that the addon has failed, is it something you’re aware of? :slight_smile:
If not the watchdog catching the failed state, I get this error:
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[Info] Starting addon...
MAX_CALL_TIME = '-1'
[Info] Received messages {"call_sip_uri":"sip:[redacted]@[redacted]","message_tts":"Hello"}
Converting audio file 'https://[redacted].org:8123/api/tts_proxy/0f7689264bc63373cb9727382a2241632bc1c3d4_en_-_google_translate.mp3'...
Starting SIP Client and calling 'sip:sip:[redacted]@[redacted]'...
This call will be terminated after '3.18' seconds.
20:59:57.103         os_core_unix.c !pjlib 2.9 for POSIX initialized
./run: line 337: echo: write error: Broken pipe
./run: line 337:   413 Exit 1                  ( sleep $MAX_CALL_TIME_VALUE; echo h; sleep 0.5; echo q )
       414 Segmentation fault      (core dumped) | ( pjsua --app-log-level=3 --config-file '/share/dss_voiparm/dss_pjsua.conf' $CALL_SIP_URI_VALUE 2> /share/dss_voiparm/dss_pjsua.log )
[Error] pjsua Exit code: 139
Sometimes it works though!
In the end I succeeded thanks to a user. It works perfectly! In the caller_id_uri I put the username I created when activating the voip on the fritz and not the voip number so the syntax is sip:username@ipfritzbox:5060
Please rephrase in English so everyone can follow the conversation
Sometimes pjsua will raise a segmentation fault. Seems a bug on the bin.
I’ve already searched and google is full for query pjsua segmentation fault, but I haven’t found any solution…
Try to leave some time between each call
Hello and congratulations on this fantastic add-on! I was trying to get it to work to manage the house alarm but unfortunately I can’t receive any calls. I use the add-on with the Irideos-Orchestra VoIP service, I followed the specific guide but was unable to make it work. My configuration is Hassio.os+proxmox+mini pc. The addo-on installs correctly but unfortunately crashes while making the call. I attach the logs to see if you have any advice to give me.
A thousand thanks
[Info] Received messages {"call_sip_uri":"sip:+3934733476**@voip.eutelia.it","message_tts":"Prova messaggio"}
Converting audio file 'http://192.168.1.90:8123/api/tts_proxy/772c970523ed7389b60b2ed1b674b3705d965e37_it_-_google_translate.mp3'...
Starting SIP Client and calling 'sip:+3934733476**@voip.eutelia.it'...
23:54:37.704         os_core_unix.c !pjlib 2.11.1 for POSIX initialized
23:54:37.705         sip_endpoint.c  .Creating endpoint instance...
23:54:37.705                  pjlib  .select() I/O Queue created (0x7fc7ab008100)
23:54:37.705         sip_endpoint.c  .Module "mod-msg-print" registered
23:54:37.705        sip_transport.c  .Transport manager created.
23:54:37.705           pjsua_core.c  .PJSUA state changed: NULL --> CREATED
23:54:37.713           pjsua_core.c  .pjsua version 2.11.1 for Linux-6.6.20/x86_64 initialized
23:54:37.714            pjsua_app.c  .Turning sound device -99 -99 ON
23:54:37.714                 main.c  Ready: Success
23:54:37.716            pjsua_app.c  .......Call 0 state changed to CALLING
Account list:
  [ 0] <sip:172.30.33.8:5060>: does not register
  [ 1] <sip:172.30.33.8:5060;transport=TCP>: does not register
 *[ 2] sip:04186277**@voip.eutelia.it: does not register
Buddy list:
 [ 1] <?>  sip:+3934733476**@voip.eutelia.it
Current call id=0 to sip:+3934733476**@voip.eutelia.it [CALLING]
>>> 23:54:38.715            pjsua_app.c  .Turning sound device -99 -99 OFF
23:54:44.998     tcpc0x7fc7aae61538  TCP connect() error: [code=120113]: Host is unreachable
23:54:44.998      tsx0x7fc7aae776e8  Temporary failure in sending Request msg INVITE/cseq=17067 (tdta0x7fc7aae6eaa8), will try next server: Host is unreachable
23:54:44.998            pjsua_app.c  SIP TCP transport is disconnected from 83.211.227.21:5060: Host is unreachable [status=120113]
23:55:16.999            pjsua_app.c  ....Call 0 is DISCONNECTED [reason=408 (Request Timeout)]
No current call
>>> 23:55:29.236                timer.c  .Dumping timer heap:
23:55:29.236                timer.c  .  Cur size: 0 entries, max: 3070
Questa è la mia configurazione dell’add-on
sip_parameters:
  caller_id_uri: sip:04186277**@voip.eutelia.it
  realm: "*"
  username: "04186277**"
  password: px************
Add
--no-tcp
Option. See above
