While migrating my custom installed Home Assistant from Raspbian Stretch on a Raspberry Pi 3 to Hassio on a Raspberry Pi 4 I have difficulties setting up Z-Wave on the hassio installation.
The Z-Wave integration is with endless WARNING: Out of frame flow! (0xc0). Sending NAK.
warnings.
2020-05-13 15:12:36.760 Always, OpenZwave Version 1.4.3469 Starting Up
2020-05-13 15:13:46.279 Info, Setting Up Provided Network Key for Secure Communications
2020-05-13 15:13:46.280 Info, mgr, Added driver for controller /dev/ttyACM0
2020-05-13 15:13:46.280 Info, Opening controller /dev/ttyACM0
2020-05-13 15:13:46.280 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-05-13 15:13:46.283 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-05-13 15:13:46.284 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-13 15:13:46.284 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-13 15:13:46.284 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-13 15:13:46.285 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-13 15:13:46.285 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-13 15:13:46.285 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-13 15:13:46.369 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:47.369 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-13 15:13:47.369 Detail, contrlr, Removing current message
2020-05-13 15:13:47.369 Detail, contrlr, Notification: Notification - TimeOut
2020-05-13 15:13:47.370 Detail,
2020-05-13 15:13:47.370 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-13 15:13:48.279 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:48.280 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:49.280 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-13 15:13:49.280 Detail, contrlr, Removing current message
2020-05-13 15:13:49.280 Detail, contrlr, Notification: Notification - TimeOut
2020-05-13 15:13:49.281 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-13 15:13:49.319 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:49.320 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:50.315 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:51.316 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-13 15:13:51.316 Detail, contrlr, Removing current message
2020-05-13 15:13:51.316 Detail, contrlr, Notification: Notification - TimeOut
2020-05-13 15:13:51.316 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-13 15:13:51.319 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:51.321 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:52.319 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:52.320 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:53.078 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:54.079 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-13 15:13:54.079 Detail, contrlr, Removing current message
2020-05-13 15:13:54.079 Detail, contrlr, Notification: Notification - TimeOut
2020-05-13 15:13:54.079 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-13 15:13:54.132 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:55.133 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-05-13 15:13:55.133 Detail, contrlr, Removing current message
2020-05-13 15:13:55.133 Detail, contrlr, Notification: Notification - TimeOut
2020-05-13 15:13:55.186 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:56.264 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
2020-05-13 15:13:57.318 Warning, WARNING: Out of frame flow! (0xc0). Sending NAK.
...repeat ad nauseam.
The Z-Wave integration has been added through the âIntegrationsâ configuration in the UI. No changes have been made to the config files.
This is on a 2MB Raspberry Pi 4 with an Aeotech Z-Stick Gen 5. hassio version 0.109.6.
Can anyone assist with this issue?
