Ener-j Smart WiFi Weatherproof Double Socket
That’s annoying, thought all sockets were a standard size !
It is because of the screw-less design, the black back fixing plate was the standard size, the clip on face plate is slightly larger than a standard socket face place would be. I tried offering this upto a couple of others weatherproof 2 gang enclosures from B&Q and Toolstation, I could not find one suitable one without some cutting and hacking either the box or the face plate, not to say there is not one out there.
I have decided to re-deploy this one inside the home, and I shall order the weatherproof one when suppliers have some stock available again.
I guess it is just a case of deleting the device from esphome, and re-flashing with a different device name?
Also thinking that I should be using a more descriptive names for the entities within the esphome yaml config, as I shall end up having a number of left/right socket_2, 3, 4 now I’m planning on buying a few more for inside.
Yes, obviously can’t tuya flash anymore but if you copy all the config to clipboard, delete the node from esphome, create a new one with your new name and then paste the config back in and reflash OTA. You’ll need to reload the browser before you can edit the new node.
Just to throw some ideas around, this is the way I manage my wall sockets with one piece of code.
Therefore, if I update the code to include a new feature or want to change a password, I only have to do it once:
This is my node (I have a few of these)
wallsocket1.yaml
substitutions:
  devicename: wallsocket1
  upper_devicename: Wall Socket 1
<<: !include .wallsocket.yaml
This is my shared config for the wallsocket with credit to @Holdestmade for some bits! All the same type of wallsocket. If you use VSCode addon and rename the file with a ‘.’ (full stop or period) in front, it won’t show up in ESPhome.
.wallsocket.yaml
esphome:
  platform: ESP8266
  board: esp01_1m
<<: !include .common.yaml
  - platform: wifi_signal
    update_interval: 30s
switch:
  - platform: gpio
    pin: GPIO5
    icon: mdi:power-socket-uk
  - platform: gpio
    pin: GPIO12
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO9
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - switch.toggle: socket_1
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        - switch.toggle: socket_2
output:
  - platform: esp8266_pwm
    pin:
      number: GPIO13
      inverted: True
light:
  - platform: monochromatic
    output: op_green_led
    effects:
      - strobe:
      - strobe:
          colors:
            - state: True
              duration: 1000ms
            - state: False
              duration: 1000ms
      - strobe:
          colors:
            - state: True
              duration: 250ms
            - state: False
              duration: 250ms
And this is my common file with all my common settings.
.common.yaml
wifi:
  ssid: !secret ap_ssid
  password: !secret ap_pass
  ap:
    ssid: $upper_devicename Fallback
    password: !secret fallback_pass
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret api_pass
ota:
I also succeeded with this approach. Thanks @levickij and @Holdestmade for posting!
September 2021. Beware of a safety recall in the UK for some related sockets. See this thread.
Thanks, I threw mine away anyway as the front covers fell off. Replaced them with BGHome ones
For anyone (like me) who comes here looking to integrate the EnerJ sockets to Home Assistant and decides they don’t have the equipment and/or knowledge to do the TuyaConvert/ESPhome conversion it’s worth noting that the Tuya cloud integration works out of the box.
So if you are not set on local-only and dont mind using cloud you can get up and running with these sockets in HA in minutes. Just add the sockets to the Tuya smart life app, follow the config guide for the HA Tuya integration and you’re good to go.
Bear in mind these sockets have been recalled due to a safety issue:
