Energy : adding pellets and wood to gaz and electricity
I really like the approach developped on energy dashboard (thank you for that) but I think it should be more “inclusive” for alternative energies.
I am thinking first to wood and pellets consumption on which I have already some meters (that could be easyly converted to KWh).
For people like me that are mixing different energies bringing more flexibility in defining additional sources like we have for consumptions wold be great.
I was just looking for the same thing. As my main heating is done with pellets it would be great to be able to add this to the energy tab.
I am just experimenting with adding wood pellets consumption as “gas consumption”.
Its a bit of a hack. I have a REST sensor that reads the total pellet comsumptiion from my ETA pellet burner. Then I add the following:
homeassistant:
  customize:
    # Add an entry for each entity that you want to overwrite.
    sensor.pellets_gesamtverbrauch:
      state_class: total_increasing
      device_class: energy
      unit_of_measurement: kWh
This is a solution for setting the state and device class until there is an integration for ETA or the REST platform supports to set this.
Now I am able to select this entity on the settings page for the energy dashboard. Using kWh is a hack, when I cange it to “kg” I get a warning in the settings dialog - I will see if it works anyway.
But yes, please add wood / pellets (and also oil) consumption in the energy dashboard.
implemented the same hack in the meantime :smiley:
What does this “hack” look like in the energy dashboard?
I would also like to see this added to home assistant. Is there any news about this topic?
it would be fantastic, energy in this era will certainly be generated less and less by gas, there are many thermal power plants that can be integrated with homeassistant, I have an okofen and the custom integration works perfectly through the json protocol.
In my case, in addition to having the daily consumption of pellets directly from the machine, the solar thermal system has an accounting which indicates the thermal kW generated by the solar thermal, both daily and annual.
In the energy dashboard, being able to have the thermal energy generated by the pellets and the consumption and thermal power generated by the thermal panels would be what each of us deserves.
It would be necessary to be able to easily edit the dashboard for heat generators of various types and have a complete picture of all the energy flows that our homes use and consume.
The wood burner shows up at “Gas” - which is not entirely wrong, since the wood burner also burns (wood) gas in the end
grafik
grafik
FYI, I switched to a new ETA pellet burner integration, which does not provide the total energy in kWh, but just the total pellets burned in kg. So I had to add another hack for conversion of pellets kg to energy kWh (which is just a constant factor of about 4.8):
# Convert pellet consumption (kg) to energy consumption (kWh)
template:
  - sensor:
    - name: eta_gesamtenergie
      unique_id: '0a7576cc-d6c1-30ba-1ae1-611518c3497f'
      state: >
        {{ states('sensor.eta_kessel_zahlerstande_gesamtverbrauch') | float(default=0.0) | multiply(4.8) | round(1) }}
Hi, @shell1 , @Batou38 , @kimme1024 , @mmick08 , @TommySharpNZ , @MauzenLi , @lferrucci
Did you you tried to ask to the team if they can add the “pellets” Feature in the dashboard ?
I have the value in m3 :confused:
It yould be nice to have this pellet feature nativ
How much kWh does a m3 wood generate (wouldn’t that be a very “subjective” amount ?
I know my main-source for heating is Wood, Mostly i get for free(and alot of work), sometimes i buy(also includes relative amount of work) On a side-note, the work ofcause also generate “heat/kWh” :slight_smile:
I like the idea , but i “dropped it” , as everything(most) is rather subtile/subtle
Pellets, could be more “precise” than wood, but this “source” is also depended upon i.e density, humidity and quality(sort) etc.
I haven’t found a “reliable” way of measure the amount of kWh 1 m3 wood generates, and ofcause i don’t count the hours i “work” i put in handling this “Source” :slight_smile:
Sure, At the end of “Heating Seasons” i can pretty correctly “estimate” how much Wood i burned this Winter, calculating this would(for me) just be a way of deceiving my self
( Even when i look at the “household” vs “Outside” temperature over time, for past period ) And i don’t coun’t in Wind-direction, outside Humid/Air-pressure as a factor, in this equation, it’s more a “constructional influence”
You can’t compare Wood vs Pellet … You have DIN+ EN+ Wood and allmost allways the same kwh → Kg …
Yeah, one hardly ever count’s wood in kg, and as said Pellets is more “predictable”
NOTE: I was thinking, do you actually measure DIN+ EN+, when you get your “load” in, and over time/season ? , like weekly in your storage, compared to providers sales-spec.
Please stop now your offtopic …
