The degree of self-sufficiency shows to what extent a household can supply itself with electricity from its own solar power system. A degree of self-sufficiency of 100% would therefore mean that a household could completely disconnect itself from the grid operator in order to supply itself with electricity. The degree of self-sufficiency is calculated as follows:
Degree of self-sufficiency [%] = self-consumed solar power / total power consumption.
With a photovoltaic system with an installed capacity of 5 kWp to 20 kWp and an annual consumption of 4,000 kWh, a degree of self-sufficiency of 50% to 60% can be achieved. If a storage system is integrated, the degree of self-sufficiency increases to 75% to almost 100% with usable storage sizes from 3 kWh and with identical solar power and identical annual electricity consumption.
Self-consumption ratio or degree of self-sufficiency? These two values are often used synonymously, but they differ in their calculation: The self-consumption of the photovoltaic system is related to a different basis in each case.
The share of self-used solar electricity in the produced solar electricity is the self-consumption quota.
The share of self-used solar electricity in total electricity consumption is called the self-sufficiency ratio.
The âself-consumption quotaâ you describe already exists in the sidebar of the Energy dashboard and is called âSelf-consumed solar energyâ there, right? (Personally, I donât think this metric is that relevant, the smaller your PV the bigger value youâll get. If you want to achieve 100% there then you should build a PV consisting of a single PV module. Or break your PV such that it produces way less than it could. )
I would be very interested in a gauge that shows the Autarkie (âself-consumption quotaâ), too! Actually, itâs the more relevant metric in my opinion: It is a measure of how well my PV works and how well my home is set-up to use the PV energy (and how much my PV is able to reduce my energy bill).
I am missing this information within the energy dashboard, too.
The way I solved this, was by creating a custom dashboard (with all relevant PV data) and then create custom sensors to calculate such information:
# Sensor zur Autarkie-Kalkulation
solaredge_calculated_self_sufficiency:
friendly_name: 'Autarkie-Grad'
unit_of_measurement: "%"
value_template: >-
{% if is_state('sensor.solaredge_selfconsumption_energy_kwh', '0.0') or is_state('sensor.solaredge_consumption_energy_kwh', '0.0') %}
0.0
{% else %}
{% set selfconsumption = states('sensor.solaredge_selfconsumption_energy_kwh') | float(0) %}
{% set consumption = states('sensor.solaredge_consumption_energy_kwh') | float(0) %}
{{ ((selfconsumption / consumption) * 100) | round(2) }}
{% endif %}
# Sensor zum Nutzungsgrad der PV-Anlage
solaredge_calculated_solar_usage:
friendly_name: 'Nutzungsgrad'
value_template: >-
{% if is_state('sensor.solaredge_energy_today_kwh', '0.0') or is_state('sensor.solaredge_selfconsumption_energy_kwh', '0.0') %}
0.0
{% else %}
{% set production = states('sensor.solaredge_energy_today_kwh') | float(0) %}
{% set consumption = states('sensor.solaredge_selfconsumption_energy_kwh') | float(0) %}
{{ ((consumption / production) * 100) | round(2) }}
{% endif %}
# Sensor zum Berechnung der Netzeinspeisung
solaredge_calculated_energy_export:
friendly_name: 'Netzeinspeisung'
value_template: >-
{% if is_state('sensor.solaredge_energy_today_kwh', '0.0') or is_state('sensor.solaredge_exported_energy_kwh', '0.0') %}
0.0
{% else %}
{% set export = states('sensor.solaredge_exported_energy_kwh') | float(0) %}
{{ ((export / production) * 100) | round(2) }}
{% endif %}
The lack of self-sufficiency is a major shortcoming of the current dashboard. We should orient ourselves to the key figures and values offered by almost all PV inverter manufacturers. Here, self-sufficiency is missing as an essential parameter.
It is precisely the values of self-consumption and self-sufficiency that are crucial for controlling the consumers in a smart home and monitoring the effectiveness of the measures taken so that, depending on the objective, one can switch the consumers on or off, start charging processes for the battery or charging an electric car, set the setpoints for the heating accordingly and so on.
The calculation logic is trivial and the necessary values are all already available in the dashboard: Self-sufficiency = 1 - externally sourced electricity (grid) / total electricity consumed.
This should therefore only be a small finger exercise for standard development, and if the value of self-sufficiency were available, this would enhance the entire dashboard enormously.
EN: These are templates (legacy format) which can be added to your configuration.yaml.
You could also create a new file and include it into your configuration file.
DE: Das sind templates (altes Format) welche z.B. in die configuration.yaml hinzugefĂźgt werden kĂśnnen.
Du kannst diese aber auch in eine separate Datei schreiben und dann in die configuration.yaml einbinden (include)âŚ
EN: Since the above code is in the old legacy template format, it would probably better to write it in the new template format.
DE: Am besten aber wäre es, wenn diese Sensoren nach dem neuen Template Format angelegt werden.
- platform: templates
# sensor to calculate the self sufficiency
- sensor: calculated_self_sufficiency
unique_id: 'calculated_self_sufficiency'
state_class: measurement
state: >-
0.0
{% else %}
{% endif %}
# sensor to calculate the usage of your solar installation
- sensor: calculated_solar_usage:
unique_id: 'calculated_solar_usage'
state: >-
0.0
{% else %}
{% endif %}
# sensor to calculate the grid export percentage
- sensor: calculated_energy_export:
unique_id: 'calculated_energy_export'
state: >-
0.0
{% else %}
{% endif %}
EN: But I havenât tested the new format yet - since Iâm trying to avoid such sensors in my new installation.
The major issue is, that the calculation will be done, whenever one of the source-sensor values change.
That could / will cause issues with the calculation when for example - the value for export does change, but the sensor value for production has not yet changed (or does change just a bit later).
In this case, the calculation will give you wrong values for a short period of time.
DE: Ich habe das neue Format aber selber jetzt noch nicht getestet, da ich in meinem Neuen System grĂśĂten Teils auf diese Sensoren verzichte.
Das Problem mit der Berechnung solcher Werte ist, dass die Berechnung immer dann stattfindet, wenn sich einer der Werte ändert.
Das kann dann dazu fßhren, dass z.B. der Wert fßr Export ändert, der fßr Produktion aber noch nicht - oder erst kurz darauf.
FĂźr eine gewisse Zeit bekommt man dann also ungenauere Werte im System angezeigt.
und btw:
Hier im Forum sollte man am besten englisch schreiben - damit auch andere aus der Community helfen kÜnnen und die Beiträge verstehen
thx for helping me. Sorry, my english isn´t the best.
I have a probplem, the script doesn´t work. I dont no why. I have 3 states, Solarproduktion, Akku entladen and Netzbezug. Thats all. How does it work with this three states?
I cleared the yaml. I have all in packages.
von Batterie = sensor.soyosource_wifi_dongle_battery_power
Netzbezug = sensor.gesamt_verbrauch
Einspeisung = sensor.gesamt_einspeisung
Tagesertrag Solar = sensor.tagesertrag
This are all necessary entities.
I dont now the right funktion.
OK, pls. write me a private message - then we can try to discuss this in german - and maye, it will be easier
The thing here in the forum - since it is public, is that conversation should be in english - so that everyone can have a benefit from it⌠but sure. It does make things a bit difficult sometimes, if your english isnât that good.
I really would love to see this feature as a gauge like the one already present. In addition, it should also be straigt forward to implement the savings from the self consumption using a tarife. Either by using the tarif you would have had to pay If energy was consumed from the net,or (relevant fro some old tarifes in germany, e.g.) additional money you get for self-consumed energy.
Hi there, I created this Bundle Card without even knowing others would like this.
Someone pointed me to this post, so might as well share it now
I submitted a PR to add this card as a default repository to HACS, so shouldnât take too long to have it as default HACS repo
Edit:
This card also displays self-consumption (meaning how much of your produced energy was used by you). The goal is to have a bundle card. If you have an idea for another info to display, feel free to submit it, Iâm open for suggestions
