So far, I am loving the energy feature. My dashboard doesn’t show the self consumed solar energy. I am using an Enphase Envoy-S metered, help would be appreciated!
You will probably find your answer here:
Update 21/July/2023 - I have started a new topic that uses a fully manual solution I came up with using just the rest sensor for Enphase Envoy on D7 firmware.
It’s a lengthy guide with lots of explanation.
Hopefully it helps someone else out.
Original guide from August 2021 - I am setting up a new topic here as Energy Management in Home Assistant is getting pretty crowded and hard to follow with over 380 posts.
Ok, so, all of this recent activity started when when Home Assistant 2021.8 laun…
