Energy Dashboard use Wh instead of kWh
is it possible to change the unit for the Energy Dashboard? I want to change the unit form kWh to Wh. I have only a very small solar panel in my garden and it doesn´t make sense to track this in kWh.
grafik
Not that I’m aware of.
You could replace the bar chart with a built-in graph card, Apex Charts or the Mini Graph Card.
There’s also a HACS power flow card (not energy, but there is an energy one I don’t know about) you can consider. It will switch between kW and W as needed.
Thanks for your answer. Now, I know I didn’t overlooked a setting. I think I will add a factor of 1000 to my values and ignore the unit.
You’re welcome.
If I’m you (just my suggestion), I’d keep my sensors true. Personally, I’d try the energy and power cards on HACS. I use the power one and it’s very easy to use. For the bar chart, it should be pretty easy to get a bar chart with the mini graph card going. That one is very popular with many users.
You´re right. The power cards on HACS are very easy to use. Thanks again!
