Looks interesting but no. I’m not a fan of any device that requires an internet connection and a cell phone “app” to work. Same with closed source communications protocols.
I’m using these and they are supported by HA out of the box
Interesting. Any idea if it hooks up to Samsung smartthings? My HA raspberry pi is in such a place where I doubt a zwave stick would ever get a signal.
Shelly has two devices that will monitor your consumption, Shelly EM and Shelly 3EM. The EM is for single phase and 3EM being for 3 phases.
They support both REST and MQTT with the stock firmware and doesn’t require internet.
I have the 3EM but haven’t installed it yet.
There are some plugins/integrations to automatically add Shellys to HA which make it really easy to install.
Shelly EM looks like exactly what I need, but @slovenc are you saying it doesn’t work with HA yet?
I need the 1 phase one but not sure if to get 50 amps or 120 amps as I see a breaker switch for 60 amps in my electric box…
Do you need to flash the tasmota FW on it or it works just fine out of the box since it does have tuya/smart life support.
I want something plug-and-play
you can integrate it with the tuya but if you want to have the consumption values ​​in ha you need tasmota fw
by having tasmota you also turn the pairing button into a button to activate / deactivate the relay
no problem, thanks… Just not sure if this would work with my current fuse box and if it did it would be a bit of a botch job… I want to monitor the lighting circuit and the studio in the garage (has a seperate fuse box)
