Hi!
I have a NorthQ energy meter: https://www.benext.eu/static/manual/northq/power-reader-NQ-9021-EU.pdf
Background:
After pressing the button once it updates the energy value every 5 seconds (as per the manual).
The device is connected to power and is not using a battery, so energy drain is not a issue.
> Wakeup
> A single click on the Z-Wave button will wake up the device.
*> You can switch the NorthQ Power Reader into Real-time mode by pressing the sensor button once. When NorthQ Power Reader is in real-time mode, consumption data will be transferred from the wireless transmitter to the USB receiver every 5 seconds. This feature is useful if you want to examine your current wattage-consumption, or if you simply don"t want to wait for the collected consumption data to be automatically transferred to your NorthQ Power Reader. NorthQ Power Reader stays in real-time mode for 10 minutes at a time, before reverting to the normal, “power-saving” mode.
After a while the “real time” stops as planned.
Goal:
I want the realtime to be enable indefinatly as im sending the data to my influxdb to graph in grafana.
There seems to be two options:
Parameter 8: Wakeup Interval
like WAKEUP command class
Size: 2 Byte, Default Value: 0000
Parameter 11: Realtime Mode
How many seconds before going out of realtime / always on mode. Can be set to start realtime mode. Will be set by pressing button on device once. (twice clears realtime mode)
If i set the Parameter 8 to, 10 (10 seconds) its written to the device but overwritten somehow the next time the device wakes up.
How do i enable either that the device wakes up and send the update OR set the Parameter 11 to something really high to force the device to never leave real time mode?
